0010453 | ParaView | Bug | public | 2010-03-24 10:26 | 2010-04-06 17:29 | ||||
Reporter | Stephane P | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0010453: impossible to replay a trace with ArrayListProperty properties | ||||||||
Description | When the trace is dumped, the ArrayListProperty contents are dumped as a list of string : ['name0', 'name1'] when loading, it seems that the ArrayListProperty expecs a list of string interleaved with the associated values : ['name0', '1', 'name1', '1'] (the 1 indicates that is it selected). | ||||||||
Additional Information | To reproduce the bug : start paraview, start the trace, load the test file 'box.ex2', dump the trace to a file. Then restart paraview, and run the dumped trace --> a lot of errors appear in the python shell, and the blocks are not selected as they should. | ||||||||
Project | ParaViS | ||||||||
(0020006) Utkarsh Ayachit (administrator) 2010-03-25 10:40 |
Stephane, feel free to reopen if you can reproduce this. |
(0020082) Alan Scott (manager) 2010-04-06 17:29 |
Works for me. I have seen this type of behavour when the version of python is different between the build of ParaView and the running of ParaView.... Tested 3.8.0 branch, local server, Windows |
2010-03-24 10:26 | Stephane P | New Issue | |
2010-03-25 10:40 | Utkarsh Ayachit | Note Added: 0020006 | |
2010-03-25 10:40 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-03-25 10:40 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2010-03-25 10:40 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-04-06 17:29 | Alan Scott | Note Added: 0020082 | |
2010-04-06 17:29 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
