0010482 | ParaView | Bug | public | 2010-03-30 02:07 | 2010-04-20 17:14 | ||||
Reporter | Takuya OSHIMA | ||||||||
Assigned To | Robert Maynard | ||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Summary | 0010482: Changing representation after Disconnect crashes ParaView | ||||||||
Description | Open blow.vtk, File->Disconnect, Click Yes, change Representation to whatever else. ParaView crashes. | ||||||||
Additional Information | One more problem is that the array names remain in the Color by selection combo box after Disconnect. The box should be cleared. | ||||||||
(0020030) Takuya OSHIMA (reporter) 2010-03-30 02:14 |
Correction to the replication procedure: Open blow.vtk, Apply, File->Disconnect, Click Yes, change Representation to whatever else. (Hit Apply after opening blow.vtk) |
(0020291) Robert Maynard (developer) 2010-04-20 16:51 |
The widget will be disabled after a disconnection. SHA: 3b20b01c7f1773f3c6dbef5ef81bb50096ce794c |
(0020293) Alan Scott (manager) 2010-04-20 16:57 |
Nope, it still crashes for me. Steps to crash it are as follows: Trunk, Windows, local server. * Open blow.vtk, OK, apply. * Change representation to wireframe. * Disconnect, yes. * Change wireframe to surface. |
(0020294) Robert Maynard (developer) 2010-04-20 17:00 |
Currently it is fixed locally, and I just pushed the fix to master. If it is still failing with the latest head could I get what OS you are using, please. |
(0020299) Alan Scott (manager) 2010-04-20 17:14 |
Tested local server, trunk, Windows. |
2010-03-30 02:07 | Takuya OSHIMA | New Issue | |
2010-03-30 02:14 | Takuya OSHIMA | Note Added: 0020030 | |
2010-04-20 14:46 | Robert Maynard | Status | backlog => tabled |
2010-04-20 14:46 | Robert Maynard | Assigned To | => Robert Maynard |
2010-04-20 16:51 | Robert Maynard | Note Added: 0020291 | |
2010-04-20 16:51 | Robert Maynard | Status | tabled => @80@ |
2010-04-20 16:51 | Robert Maynard | Resolution | open => fixed |
2010-04-20 16:57 | Alan Scott | Note Added: 0020293 | |
2010-04-20 16:57 | Alan Scott | Status | @80@ => @20@ |
2010-04-20 16:57 | Alan Scott | Resolution | fixed => reopened |
2010-04-20 17:00 | Robert Maynard | Note Added: 0020294 | |
2010-04-20 17:14 | Alan Scott | Note Added: 0020299 | |
2010-04-20 17:14 | Alan Scott | Status | @20@ => closed |
2010-04-20 17:14 | Alan Scott | Resolution | reopened => fixed |
