0010488ParaViewBugpublic2010-03-30 09:492011-05-17 20:35
ReporterDavid Doria
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product VersionDevelopment
Target VersionFixed in Version3.12
Summary0010488: XML plugins not loaded at startup
DescriptionI added some paths to my PV_PLUGIN_PATH. When I start Paraview, in the
plugin manager I see the .so plugins in those paths, but not the .xml
plugins.
Bu ".so plugin" I mean I have a .h, .cxx, and .xml file that I have compiled
into a .so file. By ".xml plugin" I ONLY have a .xml file that is using
existing vtk .cxx/.h files. In the plugin manager, when you load a new
plugin, you have to change the file type drop down box to ".xml" to
load an xml file directly.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0026473)
2011-05-09 17:13
commit 18120623b8890fdc78190112b20817caf9412e25
Date: Mon May 9 17:06:55 2011 -0400
    Added support to load XML-only plugins.
    Using same path for xml plugins as the compiled plugins. This fixes BUG 0012165,
    BUG 0010488 and BUG 0010835.
(0026527)
Alan Scott (manager)
2011-05-17 20:35
Taking Utkarsh's word for it.
 Issue History
2010-03-30 09:49 David Doria New Issue
2011-05-09 17:13 Utkarsh Ayachit Note Added: 0026473
2011-05-09 17:13 Utkarsh Ayachit Status backlog => @80@
2011-05-09 17:13 Utkarsh Ayachit Fixed in Version => 3.12
2011-05-09 17:13 Utkarsh Ayachit Resolution open => fixed
2011-05-09 17:13 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2011-05-17 20:35 Alan Scott Note Added: 0026527
2011-05-17 20:35 Alan Scott Status @80@ => closed
