0010676 | ParaView | Bug | public | 2010-05-05 10:24 | 2011-06-28 11:21 | ||||
Summary | 0010676: Wireframe for quadratic faces still wrong for client/server | ||||||||
Description | The fix for bug 0009133 does not seem to work correctly in client/server mode. To see the effect, load the quadraticTetra01.vtu file in the ParaView data repository. Then turn on surface with edges or wireframe. You should see only the outline edges, but you also see the internal edges. Also play with the Subdivision level (under the Display tab) and watch how the wireframe grows with subdivision. You should get the same (but smoother) wires with more subdivisions. | ||||||||
Relationships | ||||||
(0026900) Ken Moreland (manager) 2011-06-27 13:13 |
I have discovered that this problem only actually occurs when delivering geometry to the client. When rendering on the server (set remote render threshold to 0MB), it renders fine. |
(0026905) Ken Moreland (manager) 2011-06-28 11:21 |
It's actually a fairly unimportant corner case where this doesn't work. If the data is large enough to bother to run client/server, then it is probably large enough to render remotely. I am closing this unless there is a compelling reason to spend the time to fix it. (Perhaps because of the new multi-core mode, which turns on client/server but turns off remote rendering.) |
2010-05-05 10:24 | Ken Moreland | New Issue | |
2010-05-05 10:24 | Ken Moreland | Relationship added | related to 0009133 |
2010-05-05 10:25 | Ken Moreland | Status | backlog => tabled |
2010-05-05 10:25 | Ken Moreland | Assigned To | => Ken Moreland |
2011-06-27 13:13 | Ken Moreland | Note Added: 0026900 | |
2011-06-28 11:21 | Ken Moreland | Note Added: 0026905 | |
2011-06-28 11:21 | Ken Moreland | Status | expired => closed |
2011-06-28 11:21 | Ken Moreland | Resolution | open => won't fix |
