0010727 | ParaView | Bug | public | 2010-05-17 19:25 | 2010-07-07 17:31 | ||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0010727: Pipeline not updating properly | ||||||||
Description | The paraview pipeline is not updating correctly. ParaView trunk, local server. Sources/ Sphere. Apply. Display tab - change scale to 5,5,1 Slice filter. Apply. Now, in the Pipeline Browser, click on the Sphere. Display tab, change scale to 1,1,1. It doesn't propagate to the 3d view. | ||||||||
(0020825) Utkarsh Ayachit (administrator) 2010-05-26 14:04 |
Not sure this is a bug. When we applied slice, the "scale" from sphere was copied over to the slice. Now when you went back and changed "scale" for the sphere, we don't expect the slice's scale to be affected. If you want to change the slice's scale, you should update the scale for the "slice" filter. |
(0020890) Alan Scott (manager) 2010-06-01 21:28 |
Answer accepted. |
2010-05-17 19:25 | Alan Scott | New Issue | |
2010-05-26 14:04 | Utkarsh Ayachit | Note Added: 0020825 | |
2010-05-26 14:04 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-05-26 14:04 | Utkarsh Ayachit | Fixed in Version | => 3.8.2 |
2010-05-26 14:04 | Utkarsh Ayachit | Resolution | open => no change required |
2010-05-26 14:04 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-06-01 21:28 | Alan Scott | Note Added: 0020890 | |
2010-06-01 21:28 | Alan Scott | Status | @80@ => closed |
2010-06-15 09:45 | Utkarsh Ayachit | Fixed in Version | 3.8.2 => 3.8.1 |
2010-06-15 09:45 | Utkarsh Ayachit | Target Version | 3.10 => 3.8.1 |
2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
2010-07-07 17:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
