0010745 | ParaView | Bug | public | 2010-05-21 16:07 | 2016-08-12 09:58 | ||||
Summary | 0010745: Visibility is bad for clip type objects | ||||||||
Description | ParaView trunk, local server, Windows. Open the spcta_a.[0-3] dataset. Create a threshold, clip by scalar, amrContour and isoVolume from this dataset. Bug - every single filter should turn the visibility of the original dataset off. I believe that the only one that does is the clip. | ||||||||
(0036395) Alan Scott (manager) 2016-07-13 14:50 |
This is still a bug. Note that we are not using amrContour anymore - it has been depricated for Extract CTH Parts (which does the correct thing). |
(0037828) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-05-21 16:07 | Alan Scott | New Issue | |
2010-06-09 17:01 | Utkarsh Ayachit | Status | backlog => tabled |
2010-06-09 17:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
2016-07-13 14:50 | Alan Scott | Note Added: 0036395 | |
2016-07-13 14:50 | Alan Scott | Status | expired => backlog |
2016-07-13 14:50 | Alan Scott | Resolution | open => reopened |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037828 | |
2016-08-12 09:58 | Kitware Robot | Resolution | reopened => moved |
