0011191 | ParaView | Bug | public | 2010-08-30 20:47 | 2016-08-12 09:58 | ||||
Summary | 0011191: isovolume wrong for cth amr point data | ||||||||
Description | ParaView trunk, local server, Windows. Open the spcta_a.[0-3] dataset. Cell to Point filter. isoVolume. Bug - notice that the object is hollow, and has bad normals (bad lighting). This needs to be fixed for 3.10. | ||||||||
(0036424) Alan Scott (manager) 2016-07-13 18:21 |
Changing to backlog. This is still a bug. The root cause of the problem is that the Iso Volume filter is keeping data from equal to or greater than a min, and less than (but not equal to a max.) We need to make it less than or equal to max. |
(0037876) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-08-30 20:47 | Alan Scott | New Issue | |
2010-11-09 09:42 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2016-07-13 18:21 | Alan Scott | Assigned To | => Alan Scott |
2016-07-13 18:21 | Alan Scott | Note Added: 0036424 | |
2016-07-13 18:21 | Alan Scott | Status | expired => backlog |
2016-07-13 18:21 | Alan Scott | Resolution | open => reopened |
2016-07-13 19:06 | Alan Scott | Assigned To | Alan Scott => |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037876 | |
2016-08-12 09:58 | Kitware Robot | Resolution | reopened => moved |
