0011197 | ParaView | Bug | public | 2010-09-01 10:34 | 2016-08-12 09:58 | ||||
Summary | 0011197: PlotEdges does not handle the case where different processes have non-null leaves at different locations. | ||||||||
Description | PlotEdges does not handle the case where different processes have non-null leaves at different locations. The culprit is line 625: if (inputPolyData == NULL) { // this is bad!!! this is assuming that all processes have non-null // nodes at the same location, which is true with exodus, but nothing // else. BUG # continue; } | ||||||||
(0037877) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-09-01 10:34 | Utkarsh Ayachit | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037877 | |
2016-08-12 09:58 | Kitware Robot | Status | expired => closed |
