0011272ParaViewBugpublic2010-09-28 13:242010-12-20 16:29
ReporterAlan Scott
Assigned ToDavid Partyka
PriorityhighSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.10
Summary0011272: Windows .avi files look like 8 bit color.
Descriptionthis shows with the 3.8.0 and 3.8.1 release. Local server, windows.
Open can.exo.
Save Animation to a .avi file.
Save Animation to .png files.
Compare them. They are different.
Since movies are one of our main products, I am marking this as high priority. It must be fixed for 3.10. Since it is in 3.8.0 (and had not been found), not holding the 3.8.1 release for it.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0023165)
David Partyka (developer)
2010-11-11 08:21
I did some experimentation with the vtkAviWriter and can conclude that what we are seeing are compression artifacts due to the small variations in the grey color of the can. If you color by some array it does look a bit better.
That said, If I disable all compression in vtkAviWriter and write out raw avi it looks perfect but produces around 6MB of video per second resulting in a 255MB file. With compression we get a 2MB file.
The only built in codec Windows provides is MJPEG wich isn't a very code codec. Perhaps we should leverage this to provide an option to save animations using the oggtheora library in vtk which I assume performs much better. Though the trade off is that it may not play out of the box without the user installing the necessary codec.
(0023172)
2010-11-11 10:04
After further discussion with Utkarsh I am going to change the default compressor that vtkAviWriter uses to be DIB instead of MSVC. This produces better quality images but at the expense of a fair amount of diskspace. Please try it out and let us know what you think.
(0023287)
2010-11-16 10:11
Resolving this for now. Feel free to reopen.
(0024301)
Alan Scott (manager)
2010-12-20 16:29
I think this is good enough. If we get any complaints, we will reopen.
tested Windows client, remote server, trunk.
 Issue History
2010-09-28 13:24 Alan Scott New Issue
2010-11-05 13:37 Utkarsh Ayachit Status backlog => tabled
2010-11-05 13:37 Utkarsh Ayachit Assigned To => David Partyka
2010-11-11 08:21 David Partyka Note Added: 0023165
2010-11-11 08:21 David Partyka Status tabled => @80@
2010-11-11 08:21 David Partyka Resolution open => fixed
2010-11-11 10:04 David Partyka Note Added: 0023172
2010-11-11 10:04 David Partyka Status @80@ => @20@
2010-11-11 10:04 David Partyka Resolution fixed => reopened
2010-11-16 10:11 David Partyka Note Added: 0023287
2010-11-16 10:11 David Partyka Status @20@ => @80@
2010-11-16 10:11 David Partyka Fixed in Version => 3.10.shortlist
2010-11-16 10:11 David Partyka Resolution reopened => fixed
2010-12-01 15:31 Utkarsh Ayachit Fixed in Version 3.10.shortlist => 3.10
2010-12-20 16:29 Alan Scott Note Added: 0024301
2010-12-20 16:29 Alan Scott Status @80@ => closed
