0011382 | ParaView | Bug | public | 2010-10-29 17:39 | 2010-11-02 18:30 | ||||
Priority | urgent | Severity | crash | Reproducibility | always | ||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011382: Client/server crashes with trunk | ||||||||
Description | ParaView trunk is not making connections client/server. Trunk ParaView as of October 29 afternoon. Windows client. Tested 3.8.1, this works (thus, probably not a system problem) Waiting for server... ERROR: In ..\..\..\..\src\ParaView3\Servers\Common\vtkProcessModuleConnection.cxx, line 140 vtkServerConnection (061CD0C0): Internal ParaView Error: Socket Communicator received wrong tag: 0 ERROR: In ..\..\..\..\src\ParaView3\Servers\Common\vtkServerConnection.cxx, line 66 vtkServerConnection (061CD0C0): Server Connection Closed! ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06822CE0): Error getting array settings from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06822B78): Error getting array settings from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMIntArrayInformationHelper.cxx, line 70 vtkSMIntArrayInformationHelper (0681F698): Error getting array from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06822A10): Error getting array settings from server. | ||||||||
(0022766) Alan Scott (manager) 2010-11-01 21:27 edited on: 2010-11-01 21:35 |
I am trying to narrow this down, so until we understand, I will keep notes in this bug. I was asked to try to make something that can be replicated, and think I may be able to repeat a bug. I am not sure if this is related to the bug listed above, but I think it is. ParaView master, as of November 1, 2010 early afternoon. Windows 7 build, Visual 2008. Cmake changes - PARAVIEW_ENABLE_PYTHON. Make ParaView, debug build. Both client and server will be run from this Windows box. ../bld/ParaView3/bin/Debug/paraview.exe --server=Manual --connect-id=111 -- Note that there is a default-servers.pvsc in the bin directory. It includes the following ( note reverse connection): <Server name="Manual" owner="user" resource="csrc://localhost" > <ManualStartup/> </Server> ../bld/ParaView3/bin/Debug/pvserver.exe -rc --connect-id=111 ParaView will start. Edit/Settings/ Render View/ Server/ Remote Rendering Parameters - set to 0 MBytes. A black window will pop up, labeled Visualization Toolkit - Win32OpenGL #1. I have never seen this before, and don't think it belongs here. I have been able to replicate a black window on some other clusters, right before it crashes a very bad death. In this simple case I cannot create a crash, but can every single time when running on any of numerous clusters. There are no output error prints from the server side, but the client says the following. This was a totally new build from scratch. This occurs when connecting from Windows to cluster, or Linux to cluster, or cygwin ssh'ing to Linux to cluster. ERROR: In ..\..\..\..\src\ParaView3\Servers\Common\vtkProcessModuleConnection.cxx, line 140 vtkServerConnection (0A68D810): Internal ParaView Error: Socket Communicator received wrong tag: 0 ERROR: In ..\..\..\..\src\ParaView3\Servers\Common\vtkServerConnection.cxx, line 66 vtkServerConnection (0A68D810): Server Connection Closed! ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06661DD0): Error getting array settings from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06661098): Error getting array settings from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMIntArrayInformationHelper.cxx, line 70 vtkSMIntArrayInformationHelper (0665F8B0): Error getting array from server. ERROR: In ..\..\..\..\src\ParaView3\Servers\ServerManager\vtkSMStringArrayHelper.cxx, line 83 vtkSMStringArrayHelper (06661C20): Error getting array settings from server. |
(0022767) Alan Scott (manager) 2010-11-01 21:31 |
Oh - one more detail. When I got rid of my Paraview state files in .config on Linux, or on Windows, ParaView seemed to become stable until I changed the Remote Rendering Parameters to 0 MB. I wonder if the problem isn't triggered by remote rendering, on any platform. |
(0022773) Utkarsh Ayachit (administrator) 2010-11-02 10:27 |
Alan, Just to clarify about the black window. You'll always see the black window on the server processes when remote-rendering is enabled (and server is not compiled with offscreen mesa). That's the server-side render window in which the rendering happens. Originally, the window would show the renderings too since there were unnecessary buffer swaps which I removed so you only see a black window now. |
(0022806) Utkarsh Ayachit (administrator) 2010-11-02 14:26 |
commit 4d63e146662d2d406bbf8dc6ca9b24d5f7139a26 Merge: 0714b9a 1ffab55 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 2 14:25:17 2010 -0400 Merge topic 'paraview_views_refactoring' 1ffab55 BUG 0011382. Fixed errors when client-server with 32-64 bit. ba1d2c5 Forwarding VTK to bring in paraview_views_refactoring branch merge. |
(0022810) Alan Scott (manager) 2010-11-02 18:30 |
Yep, Utkarsh found the bug. Works like a champ. Tested windows client, blackrose and redsky servers. |
2010-10-29 17:39 | Alan Scott | New Issue | |
2010-11-01 21:27 | Alan Scott | Note Added: 0022766 | |
2010-11-01 21:31 | Alan Scott | Note Added: 0022767 | |
2010-11-01 21:35 | Alan Scott | Note Edited: 0022766 | |
2010-11-02 10:33 | Utkarsh Ayachit | Note Added: 0022773 | |
2010-11-02 14:26 | Utkarsh Ayachit | Note Added: 0022806 | |
2010-11-02 14:26 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-11-02 14:26 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-02 14:26 | Utkarsh Ayachit | Resolution | open => fixed |
2010-11-02 14:26 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-11-02 18:30 | Alan Scott | Note Added: 0022810 | |
2010-11-02 18:30 | Alan Scott | Status | @80@ => closed |
