0011415 | ParaView | Bug | public | 2010-11-08 11:19 | 2010-12-16 18:15 | ||||
Reporter | Stephane P | ||||||||
Summary | 0011415: surface of quadratic cells in multiblock is extracted before applying slice | ||||||||
Description | When loading a multibloc data composed of quadratic cells (VTK_QUADRATIC_TETRA in this case, but it is visible for other non-linear types), applying the slice filter produces the slice of the skin of the object, not the slice of the interior of the cells as it should. It is as if an intermediate "Extract surface" filter was added between the input filter and the slice filter. | ||||||||
Additional Information | To reproduce the bug : *load the tetra10.vtk attached file *apply the "Group Datasets" filter to create a multibloc dataset composed of only this quadratic tetra *apply the slice filter --> only the edges of the triangle are displayed, instead of the filled triangle. | ||||||||
Project | ParaViS | ||||||||
Attached Files | tetra10.vtk [^] (325 bytes) 2010-11-08 11:19 | ||||||||
(0023062) Stephane P (reporter) 2010-11-08 11:31 |
After some tests, it appears that you may have to load the tetra10.vtk twice and group the two instance in the "Group Datasets" filter to see the bug. And this is not a pb of the slice filter, applying the "Cell centers" filter with Vertex Cells on produces 4 points (or 8 if you have 2 instances), it should only produce 1. |
(0024209) Berk Geveci (administrator) 2010-12-16 10:24 |
This is not fixed in master. Please verify and close the bug. |
(0024221) Berk Geveci (administrator) 2010-12-16 17:18 |
Duh! I meant to say "this is now fixed in master" not "this is not fixed in master". |
(0024223) Alan Scott (manager) 2010-12-16 18:14 |
Tested local server, Windows client, trunk. |
2010-11-08 11:19 | Stephane P | New Issue | |
2010-11-08 11:19 | Stephane P | File Added: tetra10.vtk | |
2010-11-08 11:31 | Stephane P | Note Added: 0023062 | |
2010-11-08 14:10 | Utkarsh Ayachit | Status | backlog => tabled |
2010-11-08 14:10 | Utkarsh Ayachit | Assigned To | => Berk Geveci |
2010-12-16 10:24 | Berk Geveci | Note Added: 0024209 | |
2010-12-16 10:24 | Berk Geveci | Status | tabled => @80@ |
2010-12-16 10:24 | Berk Geveci | Resolution | open => fixed |
2010-12-16 17:18 | Berk Geveci | Note Added: 0024221 | |
2010-12-16 18:14 | Alan Scott | Note Added: 0024223 | |
2010-12-16 18:14 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
