0011438 | ParaView | Bug | public | 2010-11-10 11:29 | 2010-11-11 16:04 | ||||
Reporter | dorsey | ||||||||
Assigned To | |||||||||
Priority | normal | Severity | crash | Reproducibility | always | ||||
Product Version | 3.8.1 | ||||||||
Summary | 0011438: Paraview freezes on splash screen | ||||||||
Description | When loading Paraview 3.8.1 on Windows 7 Ultimate x64, the program freezes on the splash screen. I have to kill it with Task Manager. This wasn't an issue as of yesterday evening. No changes have been made in the setup of the machine; I just came in and booted this morning and Paraview is not working. I have been trying to enable the output window from the command line but I can't find the options; when i run 'paraview.exe --help' the options disappear instantly. If I put in garbage parameters to force paraview to bring up the output window with the help options ('paraview.exe --foo') it shows, but then freezes behind the splash screen and I can't scroll or read anything. | ||||||||
Additional Information | Dell Precision T7500 2x Intel Xeon X5670 six-core processors 48GB DDR3 RAM 2x Nvidia Quadro 5000, SLI disabled 1x Nvidia GeForce GTX 480 driving a Samsung 3D HDTV 3x Asus VG236 3D monitors w/ Nvidia 3D Vision kit | ||||||||
(0023138) Utkarsh Ayachit (administrator) 2010-11-10 11:49 |
Try running paraview with "-dr" command line option, maybe your configuration files got corrupted or something. |
(0023140) dorsey (reporter) 2010-11-10 12:08 |
Didn't work, unfortunately; running 'paraview -dr' froze up like before. Is there a log file written out that I can check somewhere? |
(0023142) Utkarsh Ayachit (administrator) 2010-11-10 13:01 |
Nope, there isn't any log file written. Can you try running any other OpenGL based application? The mailing list maybe a better venue to debug this issue. |
(0023185) dorsey (reporter) 2010-11-11 14:52 |
Good call, a random OpenGL demo I found at http://magnum.dimajix.de/download/demos.shtml [^] exhibited the same symptoms. I am proceeding now with the assumption that this is an OpenGL on Windows 7 issue. Thanks for your insight :) |
(0023187) dorsey (reporter) 2010-11-11 15:48 |
Just a note for anyone who might have this issue on an Nvidia system, I did the following to resolve: 1) Open Nvidia Control Panel. Go to "Manage 3D Settings". 2) Select the setting "OpenGL Rendering GPU". Change it from "Auto-select" to the GPU you're currently using. Then change it back to "Auto-select". 3) Hit apply. Run your OpenGL app. for some reason this fixed the issue I as having. |
2010-11-10 11:29 | dorsey | New Issue | |
2010-11-10 11:49 | Utkarsh Ayachit | Note Added: 0023138 | |
2010-11-10 11:49 | Utkarsh Ayachit | Status | backlog => @20@ |
2010-11-10 12:08 | dorsey | Note Added: 0023140 | |
2010-11-10 13:01 | Utkarsh Ayachit | Note Added: 0023142 | |
2010-11-11 14:52 | dorsey | Note Added: 0023185 | |
2010-11-11 15:48 | dorsey | Note Added: 0023187 | |
2010-11-11 16:04 | Utkarsh Ayachit | Status | @20@ => closed |
2010-11-11 16:04 | Utkarsh Ayachit | Resolution | open => no change required |
