0011622 | ParaView | Bug | public | 2010-12-17 15:29 | 2016-08-12 09:58 | ||||
Target Version | 3.10.1 | Fixed in Version | |||||||
Summary | 0011622: Contour - Generate normals, gradients and scalars doesn't do anything | ||||||||
Description | Local server, windows client, trunk. Open disk_out_ref.exo. Contour. I am contouring on temp, 400 degrees. Select Generate Normals, Generate Gradients, and Generate Scalars. I don't see anything appear normal wise, gradient wise or scalar wise... | ||||||||
(0024264) Ken Moreland (manager) 2010-12-19 10:19 |
Those options only have effect on structured data. For unstructured data like disk_out_ref, a different internal algorithm is used. The unstructured data algorithm always generates scalars and normals but never gradients. |
(0024289) Alan Scott (manager) 2010-12-20 12:50 |
OK, that makes sense. But shouldn't the checkbox be grayed out then? Options that do nothing or don't work should not be available... |
(0025397) Utkarsh Ayachit (administrator) 2011-02-11 14:46 |
commit f3238a2ec8de0ae34c04d1117c5dc19a5729a1e6 Merge: e093262 55ebea3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Feb 11 14:44:54 2011 -0500 Merge topic '11622_contour_panel' 55ebea3 BUG 0011622. Disabling widgets on panel available only for structured data. |
(0025519) Alan Scott (manager) 2011-02-18 20:38 |
tested local server, window, trunk. |
(0027462) Andy Bauer (developer) 2011-09-09 14:01 |
This behavior is still funky for multiblock datasets that have both structured and unstructured grids in them. All options are grayed out in the gui but the default of Compute Normals being checked and Compute Scalars not being checked is wrong for this since for the unstructured grids the normals aren't computed and scalars are. |
(0037910) Kitware Robot (administrator) 2016-08-12 09:58 |
2010-12-17 15:29 | Alan Scott | New Issue | |
2010-12-19 10:19 | Ken Moreland | Note Added: 0024264 | |
2010-12-20 12:50 | Alan Scott | Note Added: 0024289 | |
2011-02-11 14:46 | Utkarsh Ayachit | Note Added: 0025397 | |
2011-02-11 14:46 | Utkarsh Ayachit | Status | backlog => @80@ |
2011-02-11 14:46 | Utkarsh Ayachit | Fixed in Version | => 4.0 |
2011-02-11 14:46 | Utkarsh Ayachit | Resolution | open => fixed |
2011-02-11 14:46 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-02-18 20:38 | Alan Scott | Note Added: 0025519 | |
2011-02-18 20:38 | Alan Scott | Status | @80@ => closed |
2011-07-29 10:43 | Utkarsh Ayachit | Fixed in Version | 4.0 => 3.12 |
2011-09-09 14:01 | Andy Bauer | Note Added: 0027462 | |
2011-09-09 14:01 | Andy Bauer | Status | closed => backlog |
2011-09-09 14:01 | Andy Bauer | Resolution | fixed => reopened |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037910 | |
2016-08-12 09:58 | Kitware Robot | Fixed in Version | 3.12 => |
2016-08-12 09:58 | Kitware Robot | Resolution | reopened => moved |
