0011733 | ParaView | Bug | public | 2011-01-20 12:53 | 2016-08-12 09:58 | ||||
Reporter | albert3 | ||||||||
Platform | Windows | OS | Vista | OS Version | |||||
Product Version | 3.8.1 | ||||||||
Summary | 0011733: Error reading EnSight sos file | ||||||||
Description | I installed Paraview 3.8.1 (ParaView-3.8.1-Win64-x86_MPI.exe) and I tried to load an EnSight Server of Server file. This results in the error messages: ========================================================== ERROR: In ..\..\..\..\src\Servers\Filters\vtkGenericEnSightReader2.cxx, line 356 vtkGenericEnSightReader2 (0000000007B96730): Unable to open file: D:\2_proc\NO_Measured_data\/Case02_v10023_DOM_0.case ERROR: In ..\..\..\..\src\Servers\Filters\vtkGenericEnSightReader2.cxx, line 874 vtkGenericEnSightReader2 (0000000007B96730): Error determining EnSightVersion ERROR: In ..\..\..\..\src\VTK\Filtering\vtkExecutive.cxx, line 756 vtkCompositeDataPipeline (00000000076F3BC0): Algorithm vtkGenericEnSightReader2(0000000007B96730) returned failure for request: vtkInformation (0000000007C30E80) Debug: Off Modified Time: 76728 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ERROR: In ..\..\..\..\src\Servers\Filters\vtkGenericEnSightReader2.cxx, line 356 vtkGenericEnSightReader2 (0000000007B96490): Unable to open file: D:\2_proc\NO_Measured_data\/Case02_v10023_DOM_1.case ERROR: In ..\..\..\..\src\Servers\Filters\vtkGenericEnSightReader2.cxx, line 874 vtkGenericEnSightReader2 (0000000007B96490): Error determining EnSightVersion ERROR: In ..\..\..\..\src\VTK\Filtering\vtkExecutive.cxx, line 756 vtkCompositeDataPipeline (00000000076F3AE0): Algorithm vtkGenericEnSightReader2(0000000007B96490) returned failure for request: vtkInformation (0000000007C32640) Debug: Off Modified Time: 76776 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ERROR: In ..\..\..\..\src\Servers\Filters\vtkPVEnSightMasterServerReader2.cxx, line 255 vtkPVEnSightMasterServerReader2 (0000000006451F00): Error reading case file on at least one node. ERROR: In ..\..\..\..\src\VTK\Filtering\vtkExecutive.cxx, line 756 vtkCompositeDataPipeline (0000000007CA00E0): Algorithm vtkPVEnSightMasterServerReader2(0000000006451F00) returned failure for request: vtkInformation (0000000007C30D80) Debug: Off Modified Time: 76681 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ========================================================== My sos file looks like: # # Example Server-of-server case file # parts in <> have to be filled in by the user # FORMAT type: master_server gold SERVERS number of servers: 2 #Server 1 machine id: PCAME2 executable: "D:\Program Files (x86)\CEI\bin\ensight92_server.bat" casefile: D:\2_proc\NO_Measured_data\DOM_0\Case02_v10023_DOM_0.case #Server 2 machine id: PCAME2 executable: "D:\Program Files (x86)\CEI\bin\ensight92_server.bat" casefile: D:\2_proc\NO_Measured_data\DOM_1\Case02_v10023_DOM_1.case ========================================================== The both case files are located according to the plce as defined in the sos file. Loading the data in EnSight is no problem. | ||||||||
Steps To Reproduce | try to read EnSight sos file | ||||||||
(0024967) Robert Maynard (developer) 2011-01-20 15:30 |
The issue is that the current ensight reader presumes the SOS file is in the same directory as the case files that it references. |
(0024968) albert3 (reporter) 2011-01-20 15:45 |
Did a small other test, setting data_path and casefile, so sos file is: # # Example Server-of-server case file # parts in <> have to be filled in by the user # FORMAT type: master_server gold SERVERS number of servers: 2 #Server 1 machine id: PCAME2 executable: "D:\Program Files (x86)\CEI\bin\ensight92_server.bat" data_path: D:\2_proc_multiple\3D_EnSight\DOM_0 casefile: Case_DOM_0.case #Server 2 machine id: PCAME2 executable: "D:\Program Files (x86)\CEI\bin\ensight92_server.bat" data_path: D:\2_proc_multiple\3D_EnSight\DOM_1 casefile: Case_DOM_1.case This results in the same error meaage: ERROR: In ..\..\..\..\src\Servers\Filters\vtkGenericEnSightReader2.cxx, line 356 vtkGenericEnSightReader2 (00000000079F24B0): Unable to open file: D:\2_proc_multiple\3D_EnSight\/Case_DOM_0.case |
(0024970) albert3 (reporter) 2011-01-20 15:58 |
Had a quick look at the code. In the function vtkPVEnSightMasterServerReader2::ParseMasterServerFile() of "vtkPVEnSightMasterServerReader2.cxx" the data_path is not read at all. In the function vtkGenericEnSightReader2::DetermineEnSightVersion of file "vtkGenericEnSightReader2.cxx" the variable this->FilePath is used. I think the variable this->FilePath should be replaced with the variable containing the data_path as read in vtkPVEnSightMasterServerReader2::ParseMasterServerFile() |
(0037912) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-01-20 12:53 | albert3 | New Issue | |
2011-01-20 15:30 | Robert Maynard | Note Added: 0024967 | |
2011-01-20 15:45 | albert3 | Note Added: 0024968 | |
2011-01-20 15:58 | albert3 | Note Added: 0024970 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037912 | |
