0011765ParaViewBugpublic2011-01-26 10:492016-08-12 09:58
ReporterPat Marion
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0011765: Python trace bug for heterogeneous multiblock datasets
DescriptionLoad a multiblock dataset with only unstructured grid leafs. Paraview sees a multiblock dataset containing only unstructured grid data, so it creates an unstructured grid display. Next you enable more blocks, so that multiblock dataset now contains unstructured grid and polydata leafs. Save the python trace now. The trace script records volume rendering properties of the unstructured grid display. When the trace script is replayed, paraview sees the multiblock dataset has unstructured grid and polydata leafs, so it creates a geometry display instead of an unstructured grid display. The geometry display lacks the volume rendering properties.
You could reproduce this bug using an extract block filter with an input multiblock dataset that contains unstructured grid and polydata.
TagsNo tags attached.
Project
Topic Name
Type
 Relationships
  Notes
(0037915)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2011-01-26 10:49 Pat Marion New Issue
2016-08-12 09:58 Kitware Robot Note Added: 0037915
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
