0011776 | ParaView | Feature | public | 2011-01-28 15:09 | 2012-10-29 17:04 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0011776: 2d axis needs enhancing | ||||||||
Description | We need to enhance the 2d axis. I am using sources/ mandlebrot as an example. I can think of a few options, such as: * Lock the axis to reasonable numbers. With mandelbrot, use a Y range from -1.5 to 1.5. * Let the user to select the range, and thus the size of the axis. * Allow user to add a grid pattern. * Allow user to turn on/off different axes (for instance, upper and right.) | ||||||||
Project | Sandia | ||||||||
Attached Files | bug11776.solution.png [^] (152,462 bytes) 2012-09-05 16:16
2d-remoteServer-cubeAxis.png [^] (66,177 bytes) 2012-09-19 20:42 | ||||||||
Relationships | ||||||
(0029132) Utkarsh Ayachit (administrator) 2012-09-05 16:16 |
This is no longer an issue. ParaView now presents the same cube axes as the 3D view for the 2D view. In fact, 2D view is not just mode for the 3D view and one can toggle in and out of it by clicking the "2D" or "3D" button on the top of the view. Attached is a screenshot showing the grid lines along x axis in 2D view. |
(0029141) Utkarsh Ayachit (administrator) 2012-09-07 14:50 |
merged in master if applicable |
(0029316) Utkarsh Ayachit (administrator) 2012-10-03 16:17 |
Based on email conversation, the issue shown in the image 2d-remoteServer-cubeAxis.png was captured by BUG 0013469. |
(0029358) Alan Scott (manager) 2012-10-10 21:37 |
Spectacular. Tested local server, master, Linux. |
2011-01-28 15:09 | Alan Scott | New Issue | |
2011-09-01 10:56 | Utkarsh Ayachit | Project | => Sandia |
2012-05-31 10:27 | Utkarsh Ayachit | Status | backlog => todo |
2012-09-05 16:16 | Utkarsh Ayachit | Note Added: 0029132 | |
2012-09-05 16:16 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-09-05 16:16 | Utkarsh Ayachit | Resolution | open => no change required |
2012-09-05 16:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-09-05 16:16 | Utkarsh Ayachit | File Added: bug11776.solution.png | |
2012-09-07 14:50 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-09-07 14:50 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-07 14:50 | Utkarsh Ayachit | Note Added: 0029141 | |
2012-09-19 20:42 | Alan Scott | File Added: 2d-remoteServer-cubeAxis.png | |
2012-09-24 16:49 | Utkarsh Ayachit | Status | customer review => todo |
2012-10-03 16:15 | Utkarsh Ayachit | Relationship added | related to 0013469 |
2012-10-03 16:17 | Utkarsh Ayachit | Note Added: 0029316 | |
2012-10-03 16:17 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-10-03 16:17 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-10 21:37 | Alan Scott | Note Added: 0029358 | |
2012-10-10 21:37 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
