0011802 | ParaView | Bug | public | 2011-02-04 23:41 | 2011-07-29 10:43 | ||||
Reporter | Stephane P | ||||||||
Platform | linux | OS | ubuntu | OS Version | 10.10 64bit | ||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0011802: point sprite plugin python trace not functionnal | ||||||||
Description | Dumping a python script using the trace functionnality creates a script that does not reproduce the same result when re-executed, especially when using the texture mode. | ||||||||
Steps To Reproduce | load point sprite plugin, start trace, create wavelet source, set represetation to point sprite, texture mode and sphere texture, stop trace, save python script. clean pipeline (Edit --> delete all), run script (python shell --> run script) The representation does not use the sphere texture as it should. | ||||||||
Additional Information | attached is the python script generated by the above steps, that can also be run by pvpython. | ||||||||
Project | ParaViS | ||||||||
Attached Files | test.py [^] (12,022 bytes) 2011-02-04 23:41 | ||||||||
Relationships | ||||||
(0025318) Utkarsh Ayachit (administrator) 2011-02-07 14:46 |
Merge: 650dc6a 6b305eb Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Feb 7 14:45:21 2011 -0500 Merge topic '11802_point_sprite_python_tracing' 6b305eb Fixed BUG 0011802. Fixed tracing issues with point sprites. |
(0026411) Alan Scott (manager) 2011-05-02 21:30 |
Tested local server, Windows, trunk. |
2011-02-04 23:41 | Stephane P | New Issue | |
2011-02-04 23:41 | Stephane P | File Added: test.py | |
2011-02-07 10:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-02-07 10:16 | Utkarsh Ayachit | Status | backlog => tabled |
2011-02-07 14:46 | Utkarsh Ayachit | Note Added: 0025318 | |
2011-02-07 14:46 | Utkarsh Ayachit | Status | tabled => @80@ |
2011-02-07 14:46 | Utkarsh Ayachit | Fixed in Version | => 4.0 |
2011-02-07 14:46 | Utkarsh Ayachit | Resolution | open => fixed |
2011-02-11 14:00 | Utkarsh Ayachit | Relationship added | has duplicate 0011702 |
2011-05-02 21:30 | Alan Scott | Note Added: 0026411 | |
2011-05-02 21:30 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
2011-07-29 10:43 | Utkarsh Ayachit | Fixed in Version | 4.0 => 3.12 |
