0011829 | ParaView | Bug | public | 2011-02-09 11:30 | 2016-08-12 09:58 | ||||
Reporter | Stephane P | ||||||||
Platform | linux | OS | ubuntu | OS Version | 10.10 | ||||
Summary | 0011829: post-filtering interpolated array visible as output of the filter | ||||||||
Description | When an array is interpolated from cell to points to be used later in the pipeline, it can sometimes be seen as outputed by the filter, which is not true. | ||||||||
Steps To Reproduce | activate post-filtering create wavelet point data to cell data (do not pass point data) --> at his point, volume representation is not available (no point-centered data...) create isosurface --> this uses the post-filtering to create the point-centered array needed by the contouring filter at this point, volume representation is available on the "point data to cell data" filter, which is not logical. set the representation to volume, then switch back to surface --> it is now possible to color the "point data to cell data" by the point-centered array. | ||||||||
Project | ParaViS | ||||||||
(0037920) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-02-09 11:30 | Stephane P | New Issue | |
2011-06-23 11:43 | Utkarsh Ayachit | Project | => ParaViS |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037920 | |
