0011922ParaViewBugpublic2011-03-03 07:412016-08-12 09:58
ReporterMattijs
Assigned ToKitware Robot
StatusclosedResolutionmoved
Platformubuntu10.04OSlinuxOS Version10.04
Product VersionDevelopment
Summary0011922: STL file reading only reads first solid
DescriptionAttached a simple stl file with a dummy first solid. When reading this reports 7 points, 0 cells. If I remove the dummy first solid it reads fine (8 points, 12 cells).
I don't know what you want the stl reader to do. My preference (high to low):
- read all solids. Have 'solid' field I can colour triangles with.
- read all solids but bung them into one bunch. If I want to select on different solids I can always write a simple utility to split them.
- fix current behaviour (i.e. stop reading after first endsolid)
Regards,
Mattijs
TagsNo tags attached.
Project
Topic Name
Type
Attached Files? file icon testVTKreading.stl [^] (1,506 bytes) 2011-03-03 07:41
 Relationships
  Notes
(0025636)
Mattijs (reporter)
2011-03-03 11:09
Just noticed: the problem is not the multiple solids - this works ok. It seems that it does not handle zero-sized solids.
(0037931)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2011-03-03 07:41 Mattijs New Issue
2011-03-03 07:41 Mattijs File Added: testVTKreading.stl
2011-03-03 11:09 Mattijs Note Added: 0025636
2016-08-12 09:58 Kitware Robot Note Added: 0037931
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
