0011941 | ParaView | Bug | public | 2011-03-08 12:58 | 2011-04-05 17:17 | ||||
Reporter | Paul Edwards | ||||||||
Platform | Linux | OS | Ubuntu | OS Version | 10.04 | ||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0011941: Bug with selection in chart view | ||||||||
Description | If you select an area in the line chart view that does not contain any points it causes a segfault. | ||||||||
Steps To Reproduce | 1) Create Wavelet 2) Extract Surface 3) Plot On Intersection Curves 4) Drag middle mouse button around a region that doesn't have any points | ||||||||
Additional Information | patch to fix: diff --git a/Qt/Core/pqContextView.cxx b/Qt/Core/pqContextView.cxx index db7fc09..a3356b5 100644 --- a/Qt/Core/pqContextView.cxx +++ b/Qt/Core/pqContextView.cxx @@ -445,6 +445,10 @@ void pqContextView::selectionChanged() } vtkIdTypeArray *arr = vtkIdTypeArray::SafeDownCast(node->GetSelectionList()); + if (!arr) + { + return; + } ids.clear(); for (vtkIdType i = 0; i < arr->GetNumberOfTuples(); ++i) { | ||||||||
(0025694) Paul Edwards (reporter) 2011-03-08 13:01 |
Sorry - I'm using an older version of the source and this has been fixed now. Please close this issue. |
(0026021) Utkarsh Ayachit (administrator) 2011-04-01 11:20 |
Marking closed by users request. |
(0026102) Alan Scott (manager) 2011-04-05 17:17 |
Tested Linux, local server, trunk. (And , the reporter says to close it!) |
2011-03-08 12:58 | Paul Edwards | New Issue | |
2011-03-08 13:01 | Paul Edwards | Note Added: 0025694 | |
2011-04-01 11:20 | Utkarsh Ayachit | Note Added: 0026021 | |
2011-04-01 11:20 | Utkarsh Ayachit | Status | backlog => @80@ |
2011-04-01 11:20 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-04-01 11:20 | Utkarsh Ayachit | Resolution | open => fixed |
2011-04-01 11:20 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-04-05 17:17 | Alan Scott | Note Added: 0026102 | |
2011-04-05 17:17 | Alan Scott | Status | @80@ => closed |
