0011996 | ParaView | Bug | public | 2011-03-21 16:16 | 2016-08-12 09:58 | ||||
Summary | 0011996: Disable LOD when doing stereo | ||||||||
Description | Users report that when stereo is enabled, switching LOD decimation on and off when interacting can be very distracting to see. Maybe by default LOD should be off when stereo is enabled. | ||||||||
(0025852) Ken Moreland (manager) 2011-03-21 16:41 |
As an alternative, perhaps the LOD threshold should be set much higher. I believe the default is set to 5 MB worth of polygons. Even software rendering has no trouble rendering that much. Maybe 30 MB would be more appropriate. |
(0037941) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-03-21 16:16 | Utkarsh Ayachit | New Issue | |
2011-03-21 16:41 | Ken Moreland | Note Added: 0025852 | |
2011-04-01 11:08 | Utkarsh Ayachit | Summary | Disable LOD when doing 3D => Disable LOD when doing stereo |
2011-04-01 11:08 | Utkarsh Ayachit | Description Updated | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037941 | |
