View Issue Details [ Jump to Notes ] | [ Print ] |
0012067 | ParaView | Bug | public | 2011-04-11 04:59 | 2016-08-12 09:58 |
Reporter | Mattijs | |
Assigned To | Kitware Robot | |
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | moved | |
Platform | | OS | linux | OS Version | ubuntu10.04 |
Product Version | 3.8 | |
Target Version | | Fixed in Version | | |
Summary | 0012067: scanning extension to determine reader to use |
Description | use a user-defined reader plugin with e.g. extension '.OpenFOAM'. Now have a file with in there another extension of a built-in format, e.g. '.foam' e.g.
paraview --data=cavity.foam.OpenFOAM
I seems to load in the 'OpenFOAM' plugin (seen by setting PV_PLUGIN_DEBUG) but still starts up the built-in 'foam' reader.
Attached the terminal output.
Tags | No tags attached. |
Project | |
Topic Name | |
Type | |
Attached Files | log.paraFoam [^] (10,719 bytes) 2011-04-11 04:59 |
