For another project, please consult its home page to locate the current issue tracker.
0012079 | ParaView | (No Category) | public | 2011-04-13 17:17 | 2012-02-08 17:27 | ||||
Reporter | Rich | ||||||||
Assigned To | Robert Maynard | ||||||||
Platform | x86_64 | OS | Linx | OS Version | RHEL 5 | ||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012079: MILI reader does not install properly | ||||||||
Description | Turning on PARAVIEW_USE_VISITBRIDGE, VISIT_BUILD_READER_Mili, MILI_INCLUDE_DIR, MILI_LIBRARY, and doing make install does not install a working MILI reader. The CMakeCache.txt file is included in this report. | ||||||||
Steps To Reproduce | Run ccmake Enable PARAVIEW_USE_VISITBRIDGE, VISIT_BUILD_READER_Mili, MILI_INCLUDE_DIR, MILI_LIBRARY appropriately. Run make install Cry a little. | ||||||||
Attached Files | CMakeCache.txt [^] (228,763 bytes) 2011-04-13 17:17 [Show Content] [Hide Content]# This is the CMakeCache file. # For build in directory: /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build # It was generated by CMake: /usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/bin/cmake # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Value Computed by CMake AVT_DATABASE_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/avt/Database //Value Computed by CMake AVT_DATABASE_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/avt/Database //Value Computed by CMake AVT_DBATTS_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/avt/DBAtts //Value Computed by CMake AVT_DBATTS_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/avt/DBAtts //Value Computed by CMake AVT_MATH_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/avt/Math //Value Computed by CMake AVT_MATH_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/avt/Math //Value Computed by CMake AVT_PIPELINE_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/avt/Pipeline //Value Computed by CMake AVT_PIPELINE_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/avt/Pipeline //Dependencies for the target AnalyzeReader_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Dependencies for the target AnalyzeWriter_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Build the documentation (Doxygen). BUILD_DOCUMENTATION:BOOL=OFF //Build ParaView examples. BUILD_EXAMPLES:BOOL=OFF //Build IceT with shared libraries. BUILD_SHARED_LIBS:BOOL=ON //Build the testing tree. BUILD_TESTING:BOOL=ON //Path to a program. BZRCOMMAND:FILEPATH=BZRCOMMAND-NOTFOUND //Path to a file. Boost_INCLUDE_DIR:PATH=/usr/include/boost //Boost library directory Boost_LIBRARY_DIRS:FILEPATH=/usr/lib64 //Path to a file. CGNS_INCLUDE_DIR:PATH=/usr/gapps/visit/cgns/3.0.8/linux-x86_64_gcc-4.1/include;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/include //Path to a library. CGNS_LIBRARY:FILEPATH=/usr/gapps/visit/cgns/3.0.8/linux-x86_64_gcc-4.1/lib/libcgns.a;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;/usr/lib64/libz.so //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar //For backwards compatibility, what version of CMake commands and // syntax should this version of CMake try to support. CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4 //Choose the type of build. CMAKE_BUILD_TYPE:STRING=Debug //Enable/Disable color output during build. CMAKE_COLOR_MAKEFILE:BOOL=ON //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/usr/local/bin/mpiCC //Path to a program. CMAKE_CXX_COMPILER_WITH_PATH:FILEPATH=/usr/local/bin/mpiCC //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/usr/local/bin/mpicc //Path to a program. CMAKE_C_COMPILER_WITH_PATH:FILEPATH=/usr/local/bin/mpicc //Flags used by the compiler during all build types. CMAKE_C_FLAGS:STRING= //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Use HP pthreads. CMAKE_HP_PTHREADS:BOOL= //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib CMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON //Path to a program. CMAKE_LINKER:FILEPATH=/usr/local/bin/ld //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/gmake //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_NM:FILEPATH=/usr/bin/nm //Path to a program. CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy //Path to a program. CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump //Value Computed by CMake CMAKE_PROJECT_NAME:STATIC=ParaView //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING= //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //If set, runtime paths are not added when using shared libraries. CMAKE_SKIP_RPATH:BOOL=NO //Path to a program. CMAKE_STRIP:FILEPATH=/usr/bin/strip //Thread library used. CMAKE_THREAD_LIBS:STRING=-lpthread //Use the pthreads library. CMAKE_USE_PTHREADS:BOOL=1 //If true, cmake will use relative paths in makefiles and projects. CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //Use sproc libs. CMAKE_USE_SPROC:BOOL= //Use the win32 thread library. CMAKE_USE_WIN32_THREADS:BOOL= //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=TRUE //X11 extra flags. CMAKE_X_CFLAGS:STRING= //Libraries and options used in X11 programs. CMAKE_X_LIBS:STRING=/usr/lib64/libSM.so;/usr/lib64/libICE.so;/usr/lib64/libX11.so;/usr/lib64/libXext.so //Path to program used to compress files for transfer to the dart // server COMPRESSIONCOMMAND:FILEPATH=/bin/gzip //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/usr/bin/gcov //Enable to build Debian packages CPACK_BINARY_DEB:BOOL=OFF //Enable to build NSIS packages CPACK_BINARY_NSIS:BOOL=OFF //Enable to build RPM packages CPACK_BINARY_RPM:BOOL=OFF //Enable to build STGZ packages CPACK_BINARY_STGZ:BOOL=ON //Enable to build TBZ2 packages CPACK_BINARY_TBZ2:BOOL=OFF //Enable to build TGZ packages CPACK_BINARY_TGZ:BOOL=ON //Enable to build TZ packages CPACK_BINARY_TZ:BOOL=ON //Enable to build TBZ2 source packages CPACK_SOURCE_TBZ2:BOOL=ON //Enable to build TGZ source packages CPACK_SOURCE_TGZ:BOOL=ON //Enable to build TZ source packages CPACK_SOURCE_TZ:BOOL=ON //Enable to build ZIP source packages CPACK_SOURCE_ZIP:BOOL=OFF //How many times to retry timed-out CTest submissions. CTEST_SUBMIT_RETRY_COUNT:STRING=3 //How long to wait between timed-out CTest submissions. CTEST_SUBMIT_RETRY_DELAY:STRING=5 //Path to a program. CVSCOMMAND:FILEPATH=/usr/bin/cvs //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Value Computed by CMake Cosmo_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/Cosmo //Dependencies for the target Cosmo_LIB_DEPENDS:STATIC=general;vtksys;general;vtkCommon;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Value Computed by CMake Cosmo_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/Cosmo //Limit of reported errors, -1 reports all. DART_BUILD_ERROR_REPORT_LIMIT:BOOL=OFF //Limit of reported warnings, -1 reports all. DART_BUILD_WARNING_REPORT_LIMIT:BOOL=OFF //If you have Dart installed, where is it located? DART_ROOT:PATH=DART_ROOT-NOTFOUND //Maximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Show the actual output of the build, or if off show a . for each // 1024 bytes. DART_VERBOSE_BUILD:BOOL=OFF //Should Dart server send email when build errors are found in // Continuous builds? DELIVER_CONTINUOUS_EMAIL:BOOL=Off //Value Computed by CMake DICOMParser_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/DICOMParser //Value Computed by CMake DICOMParser_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/DICOMParser //Path to a program. GITCOMMAND:FILEPATH=/usr/bin/git //Path to gunzip executable GUNZIPCOMMAND:FILEPATH=/bin/gunzip //Dependencies for the target H5PartReader_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Value Computed by CMake HDF5_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkhdf5 //Build HDF5 C++ Library HDF5_BUILD_CPP_LIB:BOOL=OFF //Build HIGH Level HDF5 Library HDF5_BUILD_HL_LIB:BOOL=OFF //HDF5 C++ Wrapper compiler. Used only to detect HDF5 compile // flags. HDF5_CXX_COMPILER_EXECUTABLE:FILEPATH=HDF5_CXX_COMPILER_EXECUTABLE-NOTFOUND //HDF5 Wrapper compiler. Used only to detect HDF5 compile flags. HDF5_C_COMPILER_EXECUTABLE:FILEPATH=HDF5_C_COMPILER_EXECUTABLE-NOTFOUND //Path to a file. HDF5_C_INCLUDE_DIR:PATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/include //HDF5 file differencing tool. HDF5_DIFF_EXECUTABLE:FILEPATH=HDF5_DIFF_EXECUTABLE-NOTFOUND //Disable compiler warnings HDF5_DISABLE_COMPILER_WARNINGS:BOOL=ON //Enable datasets larger than memory HDF5_ENABLE_HSIZET:BOOL=ON //Enable support for large (64-bit) files on Linux. HDF5_ENABLE_LARGE_FILE:BOOL=ON //Enable parallel build (requires MPI) HDF5_ENABLE_PARALLEL:BOOL=OFF //Use SZip Filter HDF5_ENABLE_SZIP_SUPPORT:BOOL=OFF //Enable Zlib Filters HDF5_ENABLE_Z_LIB_SUPPORT:BOOL=ON //Securely clear file buffers before writing to file HDF5_Enable_Clear_File_Buffers:BOOL=ON //Instrument The library HDF5_Enable_Instrument:BOOL=OFF //(This variable does not exist and should not be used) HDF5_INCLUDE_DIR:PATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/include;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/include //HDF5 library compiled with parallel IO support HDF5_IS_PARALLEL:BOOL=FALSE //Path to a library. HDF5_LIBRARY:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;/usr/lib64/libz.so //Enable metadata trace file collection HDF5_METADATA_TRACE_FILE:BOOL=OFF //Value Computed by CMake HDF5_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkhdf5 //Value Computed by CMake HDF5_SRC_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkhdf5/src //Value Computed by CMake HDF5_SRC_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkhdf5/src //Whether to perform strict file format checks HDF5_STRICT_FORMAT_CHECKS:BOOL=OFF //Use the HDF5 1.6.x API by default HDF5_USE_16_API_DEFAULT:BOOL=OFF //Use the FLETCHER32 Filter HDF5_USE_FILTER_FLETCHER32:BOOL=ON //Use the NBIT Filter HDF5_USE_FILTER_NBIT:BOOL=ON //Use the SCALEOFFSET Filter HDF5_USE_FILTER_SCALEOFFSET:BOOL=ON //Use the SHUFFLE Filter HDF5_USE_FILTER_SHUFFLE:BOOL=ON //Use the PACKED BITS feature in h5dump HDF5_USE_H5DUMP_PACKED_BITS:BOOL=ON //IF data accuracy is guaranteed during data conversions HDF5_WANT_DATA_ACCURACY:BOOL=ON //exception handling functions is checked during data conversions HDF5_WANT_DCONV_EXCEPTION:BOOL=ON //The HDF5_hdf5 library HDF5_hdf5_LIBRARY:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;/usr/lib64/libz.so //Path to a library. HDF5_hdf5_LIBRARY_DEBUG:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;/usr/lib64/libz.so //Path to a library. HDF5_hdf5_LIBRARY_RELEASE:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;/usr/lib64/libz.so //The HDF5_hdf5_hl library HDF5_hdf5_hl_LIBRARY:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5_hl.a;/usr/lib64/libz.so //Path to a library. HDF5_hdf5_hl_LIBRARY_DEBUG:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5_hl.a;/usr/lib64/libz.so //Path to a library. HDF5_hdf5_hl_LIBRARY_RELEASE:FILEPATH=/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5_hl.a;/usr/lib64/libz.so //Path to a program. HGCOMMAND:FILEPATH=/usr/bin/hg //Value Computed by CMake ICET_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/IceT //Build and run the IceT tests. ICET_BUILD_TESTING:BOOL=OFF //Value Computed by CMake ICET_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/IceT //Build MPI communication layer for IceT. ICET_USE_MPI:BOOL=ON //Build OpenGL support layer for IceT. ICET_USE_OPENGL:BOOL=ON //Value Computed by CMake ICE_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/Xdmf2/Ice //Path to a file. ICE_HAVE_FCNTL:PATH=/usr/include //Path to a file. ICE_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. ICE_HAVE_NETINET:PATH=/usr/include/netinet //Value Computed by CMake ICE_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/Xdmf2/Ice //Dependencies for the target IceTCore_LIB_DEPENDS:STATIC=general;m;general;m; //Dependencies for the target IceTGL_LIB_DEPENDS:STATIC=general;m;general;IceTCore;general;/usr/lib64/libGLU.so;general;/usr/lib64/libGL.so;general;/usr/lib64/libSM.so;general;/usr/lib64/libICE.so;general;/usr/lib64/libX11.so;general;/usr/lib64/libXext.so; //Dependencies for the target IceTMPI_LIB_DEPENDS:STATIC=general;m;general;IceTCore;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Path to java command, used by the Dart server to create html. JAVACOMMAND:FILEPATH=/usr/bin/java //Value Computed by CMake KWCommon_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Common/KWCommon //Enable testing in KWCommon (if BUILD_TESTING is ON as well). KWCommon_BUILD_TESTING:BOOL=ON //Dependencies for the target KWCommon_LIB_DEPENDS:STATIC=general;vtkCommon;general;vtksys; //Value Computed by CMake KWCommon_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Common/KWCommon //Command to build the project MAKECOMMAND:STRING=/usr/bin/gmake -i //Value Computed by CMake MAPREDUCE_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/mrmpi //Value Computed by CMake MAPREDUCE_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/mrmpi //Path to the memory checking command, used for memory error detection. MEMORYCHECK_COMMAND:FILEPATH=/usr/local/bin/purify //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Path to a file. MILI_INCLUDE_DIR:PATH=/usr/gapps/visit/mili/1.10.0/linux-x86_64_gcc-4.1/include;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/include //Path to a library. MILI_LIBRARY:FILEPATH=/usr/gapps/visit/mili/1.10.0/linux-x86_64_gcc-4.1/lib/libmili.a;;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;/usr/lib64/libz.so //Executable for running MPI programs. MPIEXEC:FILEPATH=/usr/local/bin/mpirun //Maximum number of processors available to run MPI applications. MPIEXEC_MAX_NUMPROCS:STRING=2 //Flag used by MPI to specify the number of processes for MPIEXEC; // the next option will be the number of processes. MPIEXEC_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIEXEC. MPIEXEC_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by MPIEXEC. MPIEXEC_PREFLAGS:STRING= //MPI compiler. Used only to detect MPI compilation flags. MPI_COMPILER:FILEPATH=/usr/local/bin/mpiCC //MPI compilation flags MPI_COMPILE_FLAGS:STRING= -DUSE_STDARG -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STDARG_H=1 -DUSE_STDARG=1 -DMALLOC_RET_VOID=1 //Extra MPI libraries to link against MPI_EXTRA_LIBRARY:STRING=MPI_EXTRA_LIBRARY-NOTFOUND //MPI include path MPI_INCLUDE_PATH:STRING=/usr/local/tools/mvapich-gnu/include //MPI library to link against MPI_LIBRARY:FILEPATH=/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so //MPI linking flags MPI_LINK_FLAGS:STRING= -Wl,-rpath,/usr/local/tools/mvapich-gnu/lib/shared //Dependencies for the target MapReduceMPI_LIB_DEPENDS:STATIC=general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Value Computed by CMake MaterialLibrary_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/MaterialLibrary //Value Computed by CMake MaterialLibrary_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/MaterialLibrary //Dependencies for the target Moments_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Disable compiler warnings NETCDF_DISABLE_COMPILER_WARNINGS:BOOL=ON //Dependencies for the target NIfTIReader_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Dependencies for the target NIfTIWriter_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Path to a file. OPENGL_INCLUDE_DIR:PATH=/usr/include //Path to a library. OPENGL_gl_LIBRARY:FILEPATH=/usr/lib64/libGL.so //Path to a library. OPENGL_glu_LIBRARY:FILEPATH=/usr/lib64/libGLU.so //Path to a file. OPENGL_xmesa_INCLUDE_DIR:PATH=/usr/include //Build ParaView with enforced secure connection (--connect-id) PARAVIEW_ALWAYS_SECURE_CONNECTION:BOOL=OFF //Build Reader for *.bp files based on Adios PARAVIEW_BUILD_PLUGIN_AdiosReader:BOOL=OFF //Build Reader/Writer for Analyze and NIfTI. PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter:BOOL=ON //Build Plugin for creating python coprocessing scripts PARAVIEW_BUILD_PLUGIN_CoProcessingScriptGenerator:BOOL=OFF //Build EyeDomeLighting PARAVIEW_BUILD_PLUGIN_EyeDomeLighting:BOOL=OFF //Build Override time requests PARAVIEW_BUILD_PLUGIN_ForceTime:BOOL=OFF //Build Reader for *.h5part files PARAVIEW_BUILD_PLUGIN_H5PartReader:BOOL=ON //Build Manta ray traced rendering PARAVIEW_BUILD_PLUGIN_Manta:BOOL=OFF //Build Filters for Flux and Circulation Fields PARAVIEW_BUILD_PLUGIN_Moments:BOOL=ON //Build NetDMF file format reader PARAVIEW_BUILD_PLUGIN_NetDMFReader:BOOL=OFF //Build Testing plugin PARAVIEW_BUILD_PLUGIN_PacMan:BOOL=ON //Build Point Sprites PARAVIEW_BUILD_PLUGIN_PointSprite:BOOL=ON //Build Prism PARAVIEW_BUILD_PLUGIN_Prism:BOOL=ON //Build SLACTools PARAVIEW_BUILD_PLUGIN_SLACTools:BOOL=ON //Build SierraPlotTools PARAVIEW_BUILD_PLUGIN_SierraPlotTools:BOOL=ON //Build Streaming View PARAVIEW_BUILD_PLUGIN_StreamingView:BOOL=ON //Build SurfaceLIC PARAVIEW_BUILD_PLUGIN_SurfaceLIC:BOOL=ON //Build Virtual Reality Private Network (VRPN) tracker PARAVIEW_BUILD_PLUGIN_VRPNPlugin:BOOL=OFF //Build Virtual Reality User Interface (VRUI) tracker PARAVIEW_BUILD_PLUGIN_VRUIPlugin:BOOL=OFF //Build Plugin to read NCAR VDF files PARAVIEW_BUILD_PLUGIN_VaporPlugin:BOOL=OFF //Build Standard ParaView Client PARAVIEW_BUILD_ParaView:BOOL=ON //Build ParaView Qt Client. This requires Qt. PARAVIEW_BUILD_QT_GUI:BOOL=ON //Build ParaView against the PVAdaptor private source library. // Requires Kitware License PARAVIEW_BUILD_WITH_ADAPTOR:BOOL=OFF //Turn on/off client tests that involve separate data and render // servers. PARAVIEW_CLIENT_RENDER_SERVER_TESTS:BOOL=ON //Path to a file. PARAVIEW_DATA_ROOT:PATH=PARAVIEW_DATA_ROOT-NOTFOUND //Disable VTK Testing PARAVIEW_DISABLE_VTK_TESTING:BOOL=OFF //Enable/Disable the CoProcessing library. PARAVIEW_ENABLE_COPROCESSING:BOOL=OFF //Build ParaView with Floating Point Exceptions turned on PARAVIEW_ENABLE_FPE:BOOL=OFF //Enable/Disable Python scripting support. PARAVIEW_ENABLE_PYTHON:BOOL=OFF //Path to a cmake file containing calls to build additional plugins // external to ParaView. PARAVIEW_EXTERNAL_PLUGINS_FILE:FILEPATH= //Extra modules that ParaView will try to import. The modules have // to provide ParaViewImport.cmake file. PARAVIEW_EXTRA_EXTERNAL_MODULES:STRING= //Path to site-specific install rules for ParaView. PARAVIEW_EXTRA_INSTALL_RULES_FILE:FILEPATH= //Directories for FixupBundle to search for dependencies PARAVIEW_FIXUP_BUNDLE_SEARCH_PATHS:STRING=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib //Turn on to ensure that the documentation for filters/sources/readers // and writers is built. PARAVIEW_GENERATE_PROXY_DOCUMENTATION:BOOL=OFF //Install ParaView plugin development files. PARAVIEW_INSTALL_DEVELOPMENT:BOOL=OFF //Include the MPI executable in an installation. PARAVIEW_INSTALL_MPIEXEC:BOOL=OFF //Enable installation of third party libraries such as Qt and FFMPEG. PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES:BOOL=OFF //Compile paraview for minimum image PARAVIEW_MINIMAL_BUILD:BOOL=OFF //Build Python Testing support if PARAVIEW_ENABLE_PYTHON is ON PARAVIEW_TESTING_WITH_PYTHON:BOOL=ON //Path to a file. PARAVIEW_USERS_GUIDE:FILEPATH=PARAVIEW_USERS_GUIDE-NOTFOUND //Use IceT multi display manager PARAVIEW_USE_ICE_T:BOOL=ON //Build ParaView with MPI support PARAVIEW_USE_MPI:BOOL=ON //Use MPI synchronous-send commands for communication PARAVIEW_USE_MPI_SSEND:BOOL=OFF //Use VisIt Bridge PARAVIEW_USE_VISITBRIDGE:BOOL=ON //Value Computed by CMake PQGUI_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt //Value Computed by CMake PQGUI_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt //Does an external project define proj_list or should libproj4 // define it? PROJ_LIST_EXTERNAL:BOOL=OFF //Should libproj4 include projection code that relies on GSL? PROJ_USE_GSL:BOOL=OFF //Should libproj4 be built as a thread-friendly library? PROJ_USE_PTHREADS:BOOL=OFF //Disable compiler warnings PROTOBUF_DISABLE_COMPILER_WARNINGS:BOOL=ON //Value Computed by CMake PVClientServerCore_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore/ClientServerCore //Value Computed by CMake PVClientServerCore_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore/ClientServerCore //Value Computed by CMake PVCommmandLineExecutables_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/CommandLineExecutables //Value Computed by CMake PVCommmandLineExecutables_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/CommandLineExecutables //Value Computed by CMake PVCommon_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore/Common //Value Computed by CMake PVCommon_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore/Common //Value Computed by CMake PVFilters_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Servers/Filters //Value Computed by CMake PVFilters_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Servers/Filters //Value Computed by CMake PVServerCommon_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Servers/Common //Value Computed by CMake PVServerCommon_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Servers/Common //Value Computed by CMake PVServerImplementation_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore/ServerImplementation //Value Computed by CMake PVServerImplementation_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore/ServerImplementation //Value Computed by CMake PVServerManager_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore/ServerManager //Value Computed by CMake PVServerManager_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore/ServerManager //Value Computed by CMake PVServer_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Servers //Value Computed by CMake PVServer_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Servers //Value Computed by CMake PVServers_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Servers/Executables //Value Computed by CMake PVServers_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Servers/Executables //Value Computed by CMake PVVTKExtensions_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore/VTKExtensions //Value Computed by CMake PVVTKExtensions_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore/VTKExtensions //Command to run after a failed test to cleanup processes. Example: // "killall -9 rsh paraview" PV_TEST_CLEAN_COMMAND:STRING= //Node which serves as the client node, used to connect from the // server side in reverse connection mode. PV_TEST_CLIENT:STRING=localhost //Command to run before a test begins. Multiple commands are separated // by ';'. PV_TEST_INIT_COMMAND:STRING= //Node which serves as the root node for the cluster when testing // in parallel PV_TEST_SERVER_ROOT:STRING=localhost //Path to a program. PYTHON_EXECUTABLE:FILEPATH=/usr/local/bin/python2.6 //Dependencies for the target PacMan_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Value Computed by CMake ParaViewCore_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/ParaViewCore //Value Computed by CMake ParaViewCore_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/ParaViewCore //Value Computed by CMake ParaView_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build //Value Computed by CMake ParaView_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView //Value Computed by CMake PointSpritePlugin_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Plugins/PointSprite //Value Computed by CMake PointSpritePlugin_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Plugins/PointSprite //Dependencies for the target PointSprite_Graphics_LIB_DEPENDS:STATIC=general;vtkGraphics; //Dependencies for the target PointSprite_Plugin_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager;general;PointSprite_Rendering;general;PointSprite_Graphics; //Dependencies for the target PointSprite_Rendering_LIB_DEPENDS:STATIC=general;vtkHybrid;general;vtkRendering;general;vtkImaging;general;/usr/lib64/libGL.so; //Value Computed by CMake PrismClientPlugin_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Plugins/PrismPlugins/Client //Dependencies for the target PrismClientPlugin_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Value Computed by CMake PrismClientPlugin_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Plugins/PrismPlugins/Client //Dependencies for the target PrismServerPlugin_LIB_DEPENDS:STATIC=general;vtkPVServerManager; //Path to a program. QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qdbuscpp2xml //Path to a program. QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qdbusxml2cpp //Path to a program. QT_DESIGNER_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/designer //The location of the Qt docs QT_DOC_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/doc //qhelpgenerator used to compile Qt help project files QT_HELP_GENERATOR:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qhelpgenerator //The location of the Qt imports QT_IMPORTS_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/imports //Path to a program. QT_LINGUIST_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/linguist //Path to a program. QT_LRELEASE_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/lrelease //Path to a program. QT_LUPDATE_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/lupdate //The location of the Qt mkspecs containing qconfig.pri QT_MKSPECS_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/mkspecs //Path to a program. QT_MOC_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/moc //Path to a file. QT_PHONON_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/phonon //The Qt PHONON library QT_PHONON_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libphonon.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libphonon.so //Path to a library. QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_PHONON_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libphonon.so //The location of the Qt plugins QT_PLUGINS_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/plugins //Path to a program. QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qcollectiongenerator //The qmake executable for the Qt installation to use QT_QMAKE_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qmake //Path to a file. QT_QT3SUPPORT_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/Qt3Support //The Qt QT3SUPPORT library QT_QT3SUPPORT_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQt3Support.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQt3Support.so //Path to a library. QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQt3Support.so //Path to a file. QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANTCLIENT library QT_QTASSISTANTCLIENT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANT library QT_QTASSISTANT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND //The Qt QTCLUCENE library QT_QTCLUCENE_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCLucene.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCLucene.so //Path to a library. QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCLucene.so //(This variable does not exist and should not be used) QT_QTCORE_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtCore //The Qt QTCORE library QT_QTCORE_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so //Path to a library. QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so //Path to a file. QT_QTDBUS_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtDBus //The Qt QTDBUS library QT_QTDBUS_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDBus.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDBus.so //Path to a library. QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDBus.so //Path to a file. QT_QTDECLARATIVE_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtDeclarative //The Qt QTDECLARATIVE library QT_QTDECLARATIVE_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDeclarative.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDeclarative.so //Path to a library. QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=QT_QTDECLARATIVE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDeclarative.so //Path to a file. QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtDesigner //The Qt QTDESIGNERCOMPONENTS library QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesignerComponents.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesignerComponents.so //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesignerComponents.so //Path to a file. QT_QTDESIGNER_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtDesigner //The Qt QTDESIGNER library QT_QTDESIGNER_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesigner.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesigner.so //Path to a library. QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtDesigner.so //Path to a file. QT_QTGUI_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtGui //The Qt QTGUI library QT_QTGUI_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so //Path to a library. QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so //Path to a file. QT_QTHELP_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtHelp //The Qt QTHELP library QT_QTHELP_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so //Path to a library. QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTHELP_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so //Path to a file. QT_QTMOTIF_INCLUDE_DIR:PATH=QT_QTMOTIF_INCLUDE_DIR-NOTFOUND //The Qt QTMOTIF library QT_QTMOTIF_LIBRARY:STRING= //Path to a library. QT_QTMOTIF_LIBRARY_DEBUG:FILEPATH=QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMOTIF_LIBRARY_RELEASE:FILEPATH=QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtMultimedia //The Qt QTMULTIMEDIA library QT_QTMULTIMEDIA_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtMultimedia.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtMultimedia.so //Path to a library. QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtMultimedia.so //Path to a file. QT_QTNETWORK_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtNetwork //The Qt QTNETWORK library QT_QTNETWORK_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so //Path to a library. QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so //Path to a file. QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND //The Qt QTNSPLUGIN library QT_QTNSPLUGIN_LIBRARY:STRING= //Path to a library. QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtOpenGL //The Qt QTOPENGL library QT_QTOPENGL_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtOpenGL.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtOpenGL.so //Path to a library. QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtOpenGL.so //Path to a file. QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtScriptTools //The Qt QTSCRIPTTOOLS library QT_QTSCRIPTTOOLS_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScriptTools.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScriptTools.so //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScriptTools.so //Path to a file. QT_QTSCRIPT_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtScript //The Qt QTSCRIPT library QT_QTSCRIPT_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScript.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScript.so //Path to a library. QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtScript.so //Path to a file. QT_QTSQL_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtSql //The Qt QTSQL library QT_QTSQL_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so //Path to a library. QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so //Path to a file. QT_QTSVG_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtSvg //The Qt QTSVG library QT_QTSVG_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSvg.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSvg.so //Path to a library. QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSvg.so //Path to a file. QT_QTTEST_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtTest //The Qt QTTEST library QT_QTTEST_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtTest.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtTest.so //Path to a library. QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtTest.so //Path to a file. QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtUiTools //The Qt QTUITOOLS library QT_QTUITOOLS_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a //Path to a library. QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a //Path to a file. QT_QTWEBKIT_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtWebKit //The Qt QTWEBKIT library QT_QTWEBKIT_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtWebKit.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtWebKit.so //Path to a library. QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtWebKit.so //Path to a file. QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtXmlPatterns //The Qt QTXMLPATTERNS library QT_QTXMLPATTERNS_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXmlPatterns.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXmlPatterns.so //Path to a library. QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXmlPatterns.so //Path to a file. QT_QTXML_INCLUDE_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include/QtXml //The Qt QTXML library QT_QTXML_LIBRARY:STRING=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so //Path to a library. QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXML_LIBRARY_RELEASE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so //Path to a program. QT_RCC_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/rcc //Delay between invocation of each testing event. QT_TESTING_EVENT_PLAYBACK_DELAY:STRING=100 //Install Qt Testing development files. QT_TESTING_INSTALL_DEVELOPMENT:BOOL=OFF //The location of the Qt translations QT_TRANSLATIONS_DIR:PATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/translations //Path to a program. QT_UIC3_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/uic3 //Path to a program. QT_UIC_EXECUTABLE:FILEPATH=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/uic //Dependencies for the target QVTKWidgetPlugin_LIB_DEPENDS:STATIC=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so; //Dependencies for the target QVTK_LIB_DEPENDS:STATIC=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtWebKit.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtWebKit.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXmlPatterns.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXmlPatterns.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;general;vtkRendering;general;vtkGraphics;general;vtkImaging;general;vtkCommon;general;vtkViews; //Value Computed by CMake QtTesting_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/Testing //Dependencies for the target QtTesting_LIB_DEPENDS:STATIC=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so; //Value Computed by CMake QtTesting_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/Testing //Value Computed by CMake QtWidgets_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/Widgets //Value Computed by CMake QtWidgets_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/Widgets //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Path to a file. SILO_INCLUDE_DIR:PATH=/usr/gapps/visit/silo/4.8/linux-x86_64_gcc-4.1/include;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/include;/usr/gapps/visit/mili/1.10.0/linux-x86_64_gcc-4.1/include //Path to a library. SILO_LIBRARY:FILEPATH=/usr/gapps/visit/silo/4.8/linux-x86_64_gcc-4.1/lib/libsiloh5.a;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;/usr/lib64/libz.so //Name of the computer/site where compile is being run SITE:STRING=edge84 //Dependencies for the target SLACTools_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Path to the SLURM sbatch executable SLURM_SBATCH_COMMAND:FILEPATH=/usr/bin/sbatch //Path to the SLURM srun executable SLURM_SRUN_COMMAND:FILEPATH=/usr/bin/srun //Path to a program. SVNCOMMAND:FILEPATH=/usr/global/tools/subversion/chaos_4_x86_64_ib/subversion-1.5.4/bin/svn //Value Computed by CMake ServerManager_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Servers/ServerManager //Value Computed by CMake ServerManager_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Servers/ServerManager //Dependencies for the target SierraPlotTools_LIB_DEPENDS:STATIC=general;pqComponents; //Dependencies for the target StreamingView_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager;general;vtkStreamingCS; //Dependencies for the target SurfaceLIC_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManager; //Location of Tcl library imported from VTK. This may mean your // project is depending on VTK to get this setting. Consider using // FindTCL.cmake. TCL_LIBRARY:FILEPATH= //Location of Tk library imported from VTK. This may mean your // project is depending on VTK to get this setting. Consider using // FindTCL.cmake. TK_LIBRARY:FILEPATH= //Build the 2007 Verdict User Manual VERDICT_BUILD_DOC:BOOL=OFF //Should tests of the VERDICT library be built? VERDICT_ENABLE_TESTING:BOOL=OFF //Mangle verdict names for inclusion in a larger library? VERDICT_MANGLE:BOOL=ON //VTK requires the verdict prefix to be vtk VERDICT_MANGLE_PREFIX:STRING=vtk //VTK requires doubles VERDICT_USE_FLOAT:BOOL=OFF //Build VisIt Reader CGNS VISIT_BUILD_READER_CGNS:BOOL=ON //Build VisIt Reader Mili VISIT_BUILD_READER_Mili:BOOL=ON //Build VisIt Reader Silo VISIT_BUILD_READER_Silo:BOOL=ON //Disable compiler warnings VISIT_DISABLE_COMPILER_WARNINGS:BOOL=ON //Path to a library. VLI_LIBRARY_FOR_VP1000:FILEPATH=VLI_LIBRARY_FOR_VP1000-NOTFOUND //Value Computed by CMake VPIC_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/VPIC //Dependencies for the target VPIC_LIB_DEPENDS:STATIC=general;vtksys;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Value Computed by CMake VPIC_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/VPIC //Value Computed by CMake VTKCS_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VTKClientServer //Value Computed by CMake VTKCS_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VTKClientServer //Value Computed by CMake VTKEXPAT_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkexpat //Value Computed by CMake VTKEXPAT_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkexpat //Value Computed by CMake VTKFREETYPE_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFREETYPE_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkfreetype //Value Computed by CMake VTKFTGL_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/ftgl //Value Computed by CMake VTKFTGL_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/ftgl //Value Computed by CMake VTKJPEG_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKJPEG_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkjpeg //Value Computed by CMake VTKNETCDF_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKNETCDF_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtknetcdf //Value Computed by CMake VTKPNG_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkpng //Value Computed by CMake VTKPNG_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkpng //Value Computed by CMake VTKSQLite_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtksqlite //Value Computed by CMake VTKSQLite_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtksqlite //Value Computed by CMake VTKTIFF_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtktiff //Value Computed by CMake VTKTIFF_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtktiff //Value Computed by CMake VTKZLIB_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkzlib //Value Computed by CMake VTKZLIB_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkzlib //Value Computed by CMake VTK_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK //Path to a file. VTK_DATA_ROOT:PATH=VTK_DATA_ROOT-NOTFOUND //Build leak checking support into VTK. VTK_DEBUG_LEAKS:BOOL=OFF //Add compiler flags to do stricter checking when building debug. VTK_EXTRA_COMPILER_WARNINGS:BOOL=OFF //Location of the OpenGL extensions header file (glext.h). VTK_GLEXT_FILE:FILEPATH=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/ParseOGLExt/headers/glext.h //Location of the GLX extensions header file (glxext.h). VTK_GLXEXT_FILE:FILEPATH=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/ParseOGLExt/headers/glxext.h //Ignore BTX and ETX in header files. VTK_IGNORE_BTX:BOOL=ON //Path to a file. VTK_LARGE_DATA_ROOT:PATH=VTK_LARGE_DATA_ROOT-NOTFOUND //Remove all legacy code completely. VTK_LEGACY_REMOVE:BOOL=OFF //Silence all legacy code messages. VTK_LEGACY_SILENT:BOOL=OFF //; separated directories to search for materials/shaders VTK_MATERIALS_DIRS:STRING=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/MaterialLibrary/Repository //Max number of threads vktMultiThreader will allocate. VTK_MAX_THREADS:STRING=64 //Path to a program. VTK_MPIRUN_EXE:FILEPATH=/usr/local/bin/mpirun //Maximum number of processors available to run parallel applications. // (see /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMakeLists.txt // for more info.) VTK_MPI_MAX_NUMPROCS:STRING=2 //Flag used by mpi to specify the number of processes, the next // option will be the number of processes. (see /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMakeLists.txt // for more info.) VTK_MPI_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIRun.(see /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMakeLists.txt // for more info.) VTK_MPI_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by VTK_MPIRUN_EXE. (see /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMakeLists.txt // for more info.) VTK_MPI_PREFLAGS:STRING= //These flags will be directly before the number of processess // flag (see /nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMakeLists.txt // for more info.) VTK_MPI_PRENUMPROC_FLAGS:STRING= //Disable multithreading support in the Python bindings VTK_NO_PYTHON_THREADS:BOOL=OFF //The opengl library being used supports off screen Mesa calls. VTK_OPENGL_HAS_OSMESA:BOOL=OFF //Option to use QT Webkit VTK_QT_USE_WEBKIT:BOOL=ON //Value Computed by CMake VTK_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK //Locale for VTK C++ tests. Example fr_FR.utf8, empty string for // env variable. VTK_TESTING_LOCALE:STRING= //VTK tests call vtkFloatingPointExceptions::Enable() VTK_TESTING_USE_FPE:BOOL=ON //VTK c++ tests will start with specified locale. VTK_TESTING_USE_LOCALE:BOOL=OFF //Build VTK with 64 bit ids VTK_USE_64BIT_IDS:BOOL=OFF //Use Boost libraries for graph algorithms - www.boost.org. VTK_USE_BOOST:BOOL=OFF //Build pixel and vertex shader support for Cg. VTK_USE_CG_SHADERS:BOOL=OFF //Build VTK chart support (OpenGL based) VTK_USE_CHARTS:BOOL=ON //Turn this option off and tests and warning/error macros will // not popup windows VTK_USE_DISPLAY:BOOL=ON //If the FFMPEG library is available, should VTK use it for saving // .avi animation files? VTK_USE_FFMPEG_ENCODER:BOOL=OFF //Use GCC visibility support if available. VTK_USE_GCC_VISIBILITY:BOOL=ON //Build the vtkGeovis kit. Needed for performing geographic visualization. VTK_USE_GEOVIS:BOOL=ON //Build VTK with gl2ps support. VTK_USE_GL2PS:BOOL=OFF //Build pixel and vertex shader support for GLSL. VTK_USE_GLSL_SHADERS:BOOL=ON //Use Gnu R interface for VTK. Requires Gnu R installation. VTK_USE_GNU_R:BOOL=OFF //Build VTK with GUI Support VTK_USE_GUISUPPORT:BOOL=1 //Build the vtkInfovis kit. Needed for performing information // visualization. VTK_USE_INFOVIS:BOOL=ON //Use mangled Mesa with OpenGL. VTK_USE_MANGLED_MESA:BOOL=OFF //Use Matlab Engine and Matlab Mex files. Requires valid Matlab // installation. VTK_USE_MATLAB_MEX:BOOL=OFF //Build metaio VTK_USE_METAIO:BOOL=ON //Enable use of the patented mpeg2 library. You are solely responsible // for any legal issues associated with using patented code in // your software. VTK_USE_MPEG2_ENCODER:BOOL=OFF //Build the MySQL driver for vtkSQLDatabase. VTK_USE_MYSQL:BOOL=OFF //Use NVIDIAs X server extension NVCONTROL. VTK_USE_NVCONTROL:BOOL=OFF //Add support for arbitrary-dimension sparse and dense arrays. VTK_USE_N_WAY_ARRAYS:BOOL=ON //Build the ODBC database interface VTK_USE_ODBC:BOOL=OFF //Build experimental Ogg/Theora support VTK_USE_OGGTHEORA_ENCODER:BOOL=OFF //Build the PostgreSQL driver for vtkSQLDatabase. VTK_USE_POSTGRES:BOOL=OFF //Build Qt support VTK_USE_QT:BOOL=ON //Build Qt based charts - DEPRECATED VTK_USE_QTCHARTS:BOOL=OFF //Use QtOpenGL in QVTK VTK_USE_QVTK_QTOPENGL:BOOL=OFF //Use the system's expat library. VTK_USE_SYSTEM_EXPAT:BOOL=OFF //Use the system's freetype library. VTK_USE_SYSTEM_FREETYPE:BOOL=OFF //Use the system's hdf5 library. VTK_USE_SYSTEM_HDF5:BOOL=ON //Use the system's jpeg library. VTK_USE_SYSTEM_JPEG:BOOL=OFF //Use the system's proj4 library. VTK_USE_SYSTEM_LIBPROJ4:BOOL=OFF //Use the system's libxml2 library. VTK_USE_SYSTEM_LIBXML2:BOOL=OFF //Use the system's png library. VTK_USE_SYSTEM_PNG:BOOL=OFF //Use the system's tiff library. VTK_USE_SYSTEM_TIFF:BOOL=OFF //Use the system's zlib library. VTK_USE_SYSTEM_ZLIB:BOOL=OFF //Use 3Dconnexion device VTK_USE_TDX:BOOL=OFF //Build the vtkTextAnalysis kit. Needed for performing text analysis. VTK_USE_TEXT_ANALYSIS:BOOL=OFF //Build the vtkViews kit. Needed for creating packaged and linked // views. VTK_USE_VIEWS:BOOL=ON //Enable support for VolumePro 1000. VTK_USE_VOLUMEPRO_1000:BOOL=OFF //Location of the WGL extensions header file (wglext.h). VTK_WGLEXT_FILE:FILEPATH=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/ParseOGLExt/headers/wglext.h //Path to a file. VTK_WRAP_HINTS:FILEPATH=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Wrapping/hints //Wrap VTK classes into the Java language. VTK_WRAP_JAVA:BOOL=OFF //Make python wrapped classes available to SIP/PyQt. VTK_WRAP_PYTHON_SIP:BOOL=OFF //Value Computed by CMake VisItBridgePlugin_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge //Value Computed by CMake VisItBridgePlugin_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge //Value Computed by CMake VisItNETCDF_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/NETCDF //Value Computed by CMake VisItNETCDF_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF //Path to a file. X11_ICE_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_ICE_LIB:FILEPATH=/usr/lib64/libICE.so //Path to a library. X11_SM_LIB:FILEPATH=/usr/lib64/libSM.so //Path to a file. X11_X11_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_X11_LIB:FILEPATH=/usr/lib64/libX11.so //Path to a file. X11_XShm_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XTest_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_XTest_LIB:FILEPATH=/usr/lib64/libXtst.so //Path to a file. X11_Xaccessrules_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xaccessstr_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xau_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xau_LIB:FILEPATH=/usr/lib64/libXau.so //Path to a file. X11_Xcomposite_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcomposite_LIB:FILEPATH=/usr/lib64/libXcomposite.so //Path to a file. X11_Xcursor_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcursor_LIB:FILEPATH=/usr/lib64/libXcursor.so //Path to a file. X11_Xdamage_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdamage_LIB:FILEPATH=/usr/lib64/libXdamage.so //Path to a file. X11_Xdmcp_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdmcp_LIB:FILEPATH=/usr/lib64/libXdmcp.so //Path to a library. X11_Xext_LIB:FILEPATH=/usr/lib64/libXext.so //Path to a file. X11_Xfixes_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xfixes_LIB:FILEPATH=/usr/lib64/libXfixes.so //Path to a file. X11_Xft_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xft_LIB:FILEPATH=/usr/lib64/libXft.so //Path to a file. X11_Xi_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xi_LIB:FILEPATH=/usr/lib64/libXi.so //Path to a file. X11_Xinerama_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinerama_LIB:FILEPATH=/usr/lib64/libXinerama.so //Path to a file. X11_Xinput_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinput_LIB:FILEPATH=/usr/lib64/libXi.so //Path to a file. X11_Xkb_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xkblib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xlib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xpm_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xpm_LIB:FILEPATH=/usr/lib64/libXpm.so //Path to a file. X11_Xrandr_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrandr_LIB:FILEPATH=/usr/lib64/libXrandr.so //Path to a file. X11_Xrender_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrender_LIB:FILEPATH=/usr/lib64/libXrender.so //Path to a file. X11_Xscreensaver_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xscreensaver_LIB:FILEPATH=/usr/lib64/libXss.so //Path to a file. X11_Xshape_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xt_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xt_LIB:FILEPATH=/usr/lib64/libXt.so //Path to a file. X11_Xutil_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xv_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xv_LIB:FILEPATH=/usr/lib64/libXv.so //Path to a library. X11_Xxf86misc_LIB:FILEPATH=/usr/lib64/libXxf86misc.so //Path to a file. X11_dpms_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86misc_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86vmode_INCLUDE_PATH:PATH=/usr/include //Build Xdmf Utilities XDMF_BUILD_UTILS:BOOL=OFF //XDMF has Network Distributed Global Memory (NDGM) XDMF_HAS_NDGM:BOOL=OFF //Path to a file. XDMF_HAVE_FCNTL:PATH=/usr/include //Path to a file. XDMF_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. XDMF_HAVE_NETINET:PATH=/usr/include/netinet //Use bzip2 XDMF_USE_BZIP2:BOOL=OFF //Build GZip Compression XDMF_USE_GZIP:BOOL=OFF //Build Support for MySQL DataItems XDMF_USE_MYSQL:BOOL=OFF //Build a C# wrapping interface XDMF_WRAP_CSHARP:BOOL=OFF //Value Computed by CMake Xdmf_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/Xdmf2 //Dependencies for the target Xdmf_LIB_DEPENDS:STATIC=general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so;general;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;vtklibxml2; //Value Computed by CMake Xdmf_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/Xdmf2 //Path to a file. ZLIB_INCLUDE_DIR:PATH=/usr/include //Path to a library. ZLIB_LIBRARY:FILEPATH=/usr/lib64/libz.so //Value Computed by CMake alglib_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkalglib //Value Computed by CMake alglib_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkalglib //Dependencies for the target avtdatabase_par_LIB_DEPENDS:STATIC=general;visitcommon;general;avtdbatts;general;avtpipeline_par;general;visit_vtk; //Dependencies for the target avtdatabase_ser_LIB_DEPENDS:STATIC=general;visitcommon;general;avtdbatts;general;avtpipeline_ser;general;visit_vtk; //Dependencies for the target avtdbatts_LIB_DEPENDS:STATIC=general;visitcommon; //Dependencies for the target avtivp_LIB_DEPENDS:STATIC=general;avtmath;general;visitcommon;general;visit_vtk;general;vtkCommon;general;vtkFiltering; //Dependencies for the target avtmath_LIB_DEPENDS:STATIC=general;visitcommon;general;vtkCommon; //Dependencies for the target avtpipeline_par_LIB_DEPENDS:STATIC=general;visitcommon;general;avtmath;general;avtdbatts;general;lightweight_visit_vtk;general;vtkGraphics; //Dependencies for the target avtpipeline_ser_LIB_DEPENDS:STATIC=general;visitcommon;general;avtmath;general;avtdbatts;general;lightweight_visit_vtk;general;vtkGraphics; //Value Computed by CMake libproj4_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtklibproj4 //Value Computed by CMake libproj4_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtklibproj4 //Value Computed by CMake lightweight_visit_vtk_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/visit_vtk/lightweight //Dependencies for the target lightweight_visit_vtk_LIB_DEPENDS:STATIC=general;visitcommon;general;vtkCommon;general;vtkFiltering;general;vtkIO; //Value Computed by CMake lightweight_visit_vtk_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/visit_vtk/lightweight //Dependencies for the target mpistubs_LIB_DEPENDS:STATIC=general;vtksys; //Value Computed by CMake pqApplicationComponents_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/ApplicationComponents //Dependencies for the target pqApplicationComponents_LIB_DEPENDS:STATIC=general;pqComponents; //Value Computed by CMake pqApplicationComponents_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/ApplicationComponents //Value Computed by CMake pqComponents_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/Components //Dependencies for the target pqComponents_LIB_DEPENDS:STATIC=general;pqCore;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so; //Value Computed by CMake pqComponents_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/Components //Value Computed by CMake pqCore_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/Core //Dependencies for the target pqCore_LIB_DEPENDS:STATIC=general;QtTesting;general;pqWidgets;general;QVTK;general;vtkCharts;general;vtkPVServerManager;general;vtkInfovisCS; //Value Computed by CMake pqCore_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/Core //Value Computed by CMake pqWidgetsTest_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Qt/Widgets/Testing //Value Computed by CMake pqWidgetsTest_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Qt/Widgets/Testing //Dependencies for the target pqWidgets_LIB_DEPENDS:STATIC=optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtUiTools.a;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtHelp.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtXml.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtNetwork.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so; //Dependencies for the target protobuf-lite_LIB_DEPENDS:STATIC=general;-lpthread; //Value Computed by CMake protobuf_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/protobuf //Enable and build protobuf tests protobuf_ENABLE_TESTING:BOOL=OFF //Dependencies for the target protobuf_LIB_DEPENDS:STATIC=general;-lpthread;general;/usr/lib64/libz.so; //Value Computed by CMake protobuf_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/protobuf //Dependencies for the target protoc_LIB_DEPENDS:STATIC=general;-lpthread;general;protobuf; //Value Computed by CMake verdict_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/verdict //Value Computed by CMake verdict_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/verdict //Value Computed by CMake visit_vtk_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/visit_vtk/full //Dependencies for the target visit_vtk_LIB_DEPENDS:STATIC=general;lightweight_visit_vtk;general;vtkGraphics;general;vtkImaging;general;vtktiff; //Value Computed by CMake visit_vtk_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/visit_vtk/full //Value Computed by CMake visitcommon_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/common //Dependencies for target visitcommon_LIB_DEPENDS:STATIC= //Value Computed by CMake visitcommon_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/common //Dependencies for the target vtkChartsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCharts;general;vtkViewsCS;general;vtkRenderingCS; //Dependencies for the target vtkCharts_LIB_DEPENDS:STATIC=general;vtkViews;general;vtkftgl;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so; //Dependencies for the target vtkClientServer_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommon; //Dependencies for the target vtkCommon_LIB_DEPENDS:STATIC=general;vtksys;general;-lm;general;-lpthread;general;dl; //Dependencies for target vtkDICOMParser_LIB_DEPENDS:STATIC= //Value Computed by CMake vtkExodus2_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkexodus2 //Value Computed by CMake vtkExodus2_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkexodus2 //Dependencies for the target vtkFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltering;general;vtkCommonCS; //Dependencies for the target vtkFiltering_LIB_DEPENDS:STATIC=general;vtkCommon; //Dependencies for the target vtkGenericFilteringCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGenericFiltering;general;vtkFilteringCS; //Dependencies for the target vtkGenericFiltering_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkGraphics; //Dependencies for the target vtkGeovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkViews;general;vtkproj4; //Dependencies for the target vtkGraphicsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkGraphics;general;vtkFilteringCS;general;vtkIOCS; //Dependencies for the target vtkGraphics_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkverdict; //Dependencies for the target vtkHybridCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkHybrid;general;vtkRenderingCS;general;vtkParallelCS; //Dependencies for the target vtkHybrid_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;vtkParallel;general;vtkexoIIc;general;vtkftgl; //Dependencies for the target vtkIOCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIO;general;vtkFilteringCS; //Dependencies for the target vtkIO_LIB_DEPENDS:STATIC=general;vtkFiltering;general;vtkDICOMParser;general;vtkNetCDF;general;vtkNetCDF_cxx;general;vtkmetaio;general;vtksqlite;general;vtkpng;general;vtkzlib;general;vtkjpeg;general;vtktiff;general;vtkexpat;general;vtksys; //Dependencies for the target vtkImagingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImaging;general;vtkFilteringCS; //Dependencies for the target vtkImaging_LIB_DEPENDS:STATIC=general;vtkFiltering; //Dependencies for the target vtkInfovisCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInfovis;general;vtkFilteringCS;general;vtkRenderingCS;general;vtkParallelCS; //Dependencies for the target vtkInfovis_LIB_DEPENDS:STATIC=general;vtkWidgets;general;vtkParallel;general;vtklibxml2;general;vtkalglib; //Dependencies for target vtkNetCDF_LIB_DEPENDS:STATIC= //Dependencies for the target vtkNetCDF_cxx_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for the target vtkPVClientServerCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVClientServerCore;general;vtkPVVTKExtensionsCS; //Dependencies for the target vtkPVClientServerCore_LIB_DEPENDS:STATIC=general;vtkPVVTKExtensions;general;vtkPVVTKExtensionsCS;general;IceTCore;general;IceTMPI;general;IceTGL;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Dependencies for the target vtkPVCommandOptions_LIB_DEPENDS:STATIC=general;vtkIO; //Dependencies for the target vtkPVCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVCommon;general;vtkIOCS; //Dependencies for the target vtkPVCommon_LIB_DEPENDS:STATIC=general;vtkIOCS;general;vtksys;general;vtkClientServer; //Dependencies for the target vtkPVFiltersCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVFilters;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS; //Dependencies for the target vtkPVFilters_LIB_DEPENDS:STATIC=general;vtkPVServerCommon;general;vtkPVServerCommonCS;general;vtkXdmfCS;general;vtkHybridCS;general;vtkParallelCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS;general;vtkViews;general;vtkViewsCS;general;vtkCharts;general;vtkChartsCS;general;KWCommon;general;vtksys;general;/usr/lib64/libGL.so;general;QVTK;general;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;vtkClientServer;general;IceTCore;general;IceTMPI;general;IceTGL; //Dependencies for the target vtkPVServerCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerCommon;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS; //Dependencies for the target vtkPVServerCommon_LIB_DEPENDS:STATIC=general;vtkHybridCS;general;vtkParallelCS;general;vtkInfovisCS;general;KWCommon;general;vtksys;general;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so;general;vtkClientServer;general;vtkPVCommandOptions; //Dependencies for the target vtkPVServerImplementationCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerImplementation;general;vtkPVClientServerCoreCS; //Dependencies for the target vtkPVServerImplementation_LIB_DEPENDS:STATIC=general;vtkPVClientServerCore;general;vtkPVClientServerCoreCS;general;protobuf; //Dependencies for the target vtkPVServerManager_LIB_DEPENDS:STATIC=general;vtkPVServerImplementationCS;general;vtkPVServerImplementation;general;vtkVisItDatabasesCS;general;vtkVisItDatabases; //Dependencies for the target vtkPVVTKExtensionsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVVTKExtensions;general;vtkPVCommonCS;general;vtkParallelCS;general;vtkHybridCS;general;vtkRenderingCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS; //Dependencies for the target vtkPVVTKExtensions_LIB_DEPENDS:STATIC=general;vtkPVCommon;general;vtkPVCommonCS;general;vtkXdmfCS;general;vtkHybridCS;general;vtkParallelCS;general;vtkVolumeRenderingCS;general;vtkWidgetsCS;general;vtkViews;general;vtkViewsCS;general;vtkCharts;general;vtkChartsCS;general;KWCommon;general;vtksys;general;IceTCore;general;IceTMPI;general;IceTGL;general;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;/usr/lib64/libGL.so;general;QVTK; //Dependencies for the target vtkParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkParallel;general;vtkRenderingCS; //Dependencies for the target vtkParallel_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;VPIC;general;Cosmo;general;/usr/lib64/libGL.so;general;vtkexoIIc;general;/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so; //Dependencies for the target vtkRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRendering;general;vtkGenericFilteringCS;general;vtkGraphicsCS;general;vtkImagingCS;general;vtkIOCS; //Dependencies for the target vtkRendering_LIB_DEPENDS:STATIC=general;vtkGraphics;general;vtkImaging;general;vtkIO;general;vtkftgl;general;vtkfreetype;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtGui.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtSql.so;optimized;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;debug;/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib/libQtCore.so;general;/usr/lib64/libGL.so;general;/usr/lib64/libXt.so;general;/usr/lib64/libSM.so;general;/usr/lib64/libICE.so;general;/usr/lib64/libX11.so;general;/usr/lib64/libXext.so; //Dependencies for the target vtkStreamingCS_LIB_DEPENDS:STATIC=general;vtkStreaming;general;vtkClientServer;general;vtkPVServerManager; //Value Computed by CMake vtkStreaming_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Plugins/StreamingView/VTK //Dependencies for the target vtkStreaming_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkGraphics;general;vtkFiltering;general;vtkCommon;general;vtkIO;general;vtkImaging;general;vtkNetCDF; //Value Computed by CMake vtkStreaming_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Plugins/StreamingView/VTK //Dependencies for the target vtkViewsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkViews;general;vtkInfovisCS;general;vtkFilteringCS; //Dependencies for the target vtkViews_LIB_DEPENDS:STATIC=general;vtkInfovis; //Dependencies for the target vtkVisItAVTAlgorithmsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkVisItAVTAlgorithms;general;vtkHybridCS;general;vtkRenderingCS; //Value Computed by CMake vtkVisItAVTAlgorithms_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/AvtAlgorithms //Dependencies for the target vtkVisItAVTAlgorithms_LIB_DEPENDS:STATIC=general;visitcommon;general;avtdatabase_par;general;avtpipeline_par;general;visit_vtk;general;avtivp; //Value Computed by CMake vtkVisItAVTAlgorithms_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/AvtAlgorithms //Dependencies for the target vtkVisItDatabasesCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkVisItDatabases;general;vtkHybridCS;general;vtkRenderingCS;general;vtkVisItAVTAlgorithmsCS; //Value Computed by CMake vtkVisItDatabases_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases //Dependencies for the target vtkVisItDatabases_LIB_DEPENDS:STATIC=general;vtkVisItAVTAlgorithms;general;vtkNetCDF;general;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;/usr/gapps/visit/silo/4.8/linux-x86_64_gcc-4.1/lib/libsiloh5.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;/usr/gapps/visit/cgns/3.0.8/linux-x86_64_gcc-4.1/lib/libcgns.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so;general;/usr/gapps/visit/mili/1.10.0/linux-x86_64_gcc-4.1/lib/libmili.a;general;/usr/gapps/visit/szip/2.1/linux-x86_64_gcc-4.1/lib/libsz.a;general;/usr/lib64/libz.so; //Value Computed by CMake vtkVisItDatabases_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases //Dependencies for the target vtkVolumeRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkVolumeRendering;general;vtkRenderingCS; //Dependencies for the target vtkVolumeRendering_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkIO;general;/usr/lib64/libGL.so; //Dependencies for the target vtkWidgetsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkWidgets;general;vtkRenderingCS;general;vtkHybridCS; //Dependencies for the target vtkWidgets_LIB_DEPENDS:STATIC=general;vtkRendering;general;vtkHybrid;general;vtkVolumeRendering;general;/usr/lib64/libGL.so; //Dependencies for the target vtkXdmfCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkXdmf;general;vtkRenderingCS; //Dependencies for the target vtkXdmf_LIB_DEPENDS:STATIC=general;vtkIO;general;Xdmf;general;vtkRendering; //Dependencies for target vtkalglib_LIB_DEPENDS:STATIC= //Dependencies for the target vtkexoIIc_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for target vtkexpat_LIB_DEPENDS:STATIC= //Dependencies for target vtkfreetype_LIB_DEPENDS:STATIC= //Dependencies for the target vtkftgl_LIB_DEPENDS:STATIC=general;/usr/lib64/libGL.so;general;vtkfreetype; //Dependencies for the target vtkhdf5_LIB_DEPENDS:STATIC=general;m;general;vtkzlib; //Dependencies for target vtkjpeg_LIB_DEPENDS:STATIC= //Value Computed by CMake vtklibxml2_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtklibxml2 //Dependencies for the target vtklibxml2_LIB_DEPENDS:STATIC=general;vtkzlib;general;dl;general;-lpthread;general;dl;general;m; //Value Computed by CMake vtklibxml2_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtklibxml2 //Value Computed by CMake vtkmetaio_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/vtkmetaio //Dependencies for the target vtkmetaio_LIB_DEPENDS:STATIC=general;vtkzlib; //Value Computed by CMake vtkmetaio_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/vtkmetaio //Dependencies for the target vtkpng_LIB_DEPENDS:STATIC=general;vtkzlib;general;-lm; //Dependencies for the target vtkproj4_LIB_DEPENDS:STATIC=general;m; //Dependencies for the target vtksqlite_LIB_DEPENDS:STATIC=general;-lpthread; //Value Computed by CMake vtksys_BINARY_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/kwsys //Dependencies for the target vtksys_LIB_DEPENDS:STATIC=general;dl; //Value Computed by CMake vtksys_SOURCE_DIR:STATIC=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/Utilities/kwsys //Dependencies for the target vtktiff_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtkjpeg;general;-lm; //Dependencies for target vtkverdict_LIB_DEPENDS:STATIC= //Dependencies for target vtkzlib_LIB_DEPENDS:STATIC= ######################## # INTERNAL cache entries ######################## ALGLIB_SHARED_LIB:INTERNAL=ON //Host Arcitecture : Linux IRIXN32 IRIX64 AIX CYGWIN ARCH_TO_BUILD:INTERNAL=Linux //ADVANCED property for variable: BUILD_DOCUMENTATION BUILD_DOCUMENTATION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BUILD_EXAMPLES BUILD_EXAMPLES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BUILD_TESTING BUILD_TESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BZRCOMMAND BZRCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Boost_INCLUDE_DIR Boost_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Boost_LIBRARY_DIRS Boost_LIBRARY_DIRS-ADVANCED:INTERNAL=1 //The library version string for boost libraries Boost_LIB_VERSION:INTERNAL=1_33_1 //The version number for boost libraries Boost_VERSION:INTERNAL=103301 //ADVANCED property for variable: CGNS_INCLUDE_DIR CGNS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CGNS_LIBRARY CGNS_LIBRARY-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_ANSI_FOR_SCOPE:INTERNAL=TRUE //Have include iostream CMAKE_ANSI_STREAM_HEADERS:INTERNAL=1 //ADVANCED property for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BACKWARDS_COMPATIBILITY CMAKE_BACKWARDS_COMPATIBILITY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/gmake //STRINGS property for variable: CMAKE_BUILD_TYPE CMAKE_BUILD_TYPE-STRINGS:INTERNAL=Debug;Release;MinSizeRel;RelWithDebInfo //This is the directory where this CMakeCache.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build //Major version of cmake used to create the current loaded cache CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache CMAKE_CACHE_MINOR_VERSION:INTERNAL=8 //Patch version of cmake used to create the current loaded cache CMAKE_CACHE_PATCH_VERSION:INTERNAL=3 //ADVANCED property for variable: CMAKE_COLOR_MAKEFILE CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1 //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/bin/cmake //Path to cpack program executable. CMAKE_CPACK_COMMAND:INTERNAL=/usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/bin/cpack //ADVANCED property for variable: CMAKE_CTEST_COMMAND CMAKE_CTEST_COMMAND-ADVANCED:INTERNAL=1 //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/bin/ctest //ADVANCED property for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_COMPILER_WITH_PATH CMAKE_CXX_COMPILER_WITH_PATH-ADVANCED:INTERNAL=1 CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_COMPILER_WITH_PATH CMAKE_C_COMPILER_WITH_PATH-ADVANCED:INTERNAL=1 CMAKE_C_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE //Path to cache edit program executable. CMAKE_EDIT_COMMAND:INTERNAL=/usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/bin/ccmake //Executable file format CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Result of TRY_COMPILE CMAKE_HAS_ANSI_STRING_STREAM:INTERNAL=TRUE //Is X11 around. CMAKE_HAS_X:INTERNAL=1 //Have function connect CMAKE_HAVE_CONNECT:INTERNAL=1 //Have function gethostbyname CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1 //Have include CMAKE_HAVE_LIMITS_H CMAKE_HAVE_LIMITS_H:INTERNAL=1 //Have library pthreads CMAKE_HAVE_PTHREADS_CREATE:INTERNAL= //Have library pthread CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1 //Have include CMAKE_HAVE_PTHREAD_H CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have function remove CMAKE_HAVE_REMOVE:INTERNAL=1 //Have function shmat CMAKE_HAVE_SHMAT:INTERNAL=1 //Have include CMAKE_HAVE_SYS_PRCTL_H CMAKE_HAVE_SYS_PRCTL_H:INTERNAL=1 //Have include CMAKE_HAVE_UNISTD_H CMAKE_HAVE_UNISTD_H:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView //ADVANCED property for variable: CMAKE_HP_PTHREADS CMAKE_HP_PTHREADS-ADVANCED:INTERNAL=1 //Install .so files without execute permission. CMAKE_INSTALL_SO_NO_EXE:INTERNAL=0 //Have library ICE CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1 //ADVANCED property for variable: CMAKE_LINKER CMAKE_LINKER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_NM CMAKE_NM-ADVANCED:INTERNAL=1 //Does the compiler support ansi for scope. CMAKE_NO_ANSI_FOR_SCOPE:INTERNAL=0 //ADVANCED property for variable: CMAKE_NO_ANSI_STREAM_HEADERS CMAKE_NO_ANSI_STREAM_HEADERS-ADVANCED:INTERNAL=1 //Does the compiler support headers like iostream. CMAKE_NO_ANSI_STREAM_HEADERS:INTERNAL=0 //Does the compiler support sstream CMAKE_NO_ANSI_STRING_STREAM:INTERNAL=0 //Does the compiler support std::. CMAKE_NO_STD_NAMESPACE:INTERNAL=0 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=245 //ADVANCED property for variable: CMAKE_OBJCOPY CMAKE_OBJCOPY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_OBJDUMP CMAKE_OBJDUMP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Test Support for 64 bit file systems CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/usr/gapps/visit/cmake/2.8.3/linux-x86_64_gcc-4.1/share/cmake-2.8 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(char) CMAKE_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) CMAKE_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) CMAKE_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) CMAKE_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) CMAKE_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) CMAKE_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(unsigned short) CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(void*) CMAKE_SIZEOF_VOID_P:INTERNAL=8 //ADVANCED property for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_STD_NAMESPACE:INTERNAL=TRUE //ADVANCED property for variable: CMAKE_STRIP CMAKE_STRIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_THREAD_LIBS CMAKE_THREAD_LIBS-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/bin/uname //ADVANCED property for variable: CMAKE_USE_PTHREADS CMAKE_USE_PTHREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_SPROC CMAKE_USE_SPROC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_USE_WIN32_THREADS CMAKE_USE_WIN32_THREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //Result of TEST_BIG_ENDIAN CMAKE_WORDS_BIGENDIAN:INTERNAL=0 //ADVANCED property for variable: CMAKE_X_CFLAGS CMAKE_X_CFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_X_LIBS CMAKE_X_LIBS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COMPRESSIONCOMMAND COMPRESSIONCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_DEB CPACK_BINARY_DEB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_NSIS CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_RPM CPACK_BINARY_RPM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_STGZ CPACK_BINARY_STGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TBZ2 CPACK_BINARY_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TGZ CPACK_BINARY_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TZ CPACK_BINARY_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TBZ2 CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TGZ CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TZ CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_ZIP CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_COUNT CTEST_SUBMIT_RETRY_COUNT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_DELAY CTEST_SUBMIT_RETRY_DELAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CXX_HAVE_OFFSETOF:INTERNAL=TRUE //ADVANCED property for variable: DART_BUILD_ERROR_REPORT_LIMIT DART_BUILD_ERROR_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_BUILD_WARNING_REPORT_LIMIT DART_BUILD_WARNING_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_ROOT DART_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_VERBOSE_BUILD DART_VERBOSE_BUILD-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DELIVER_CONTINUOUS_EMAIL DELIVER_CONTINUOUS_EMAIL-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE DEV_T_IS_SCALAR:INTERNAL=FALSE //ADVANCED property for variable: EXECUTABLE_OUTPUT_PATH EXECUTABLE_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all executables. EXECUTABLE_OUTPUT_PATH:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/bin //Have include malloc.h EX_HAVE_MALLOC_H:INTERNAL=1 //Details about finding HDF5 FIND_PACKAGE_MESSAGE_DETAILS_HDF5:INTERNAL=[debug;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5_hl.a;/usr/lib64/libz.so;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a;optimized;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5_hl.a;/usr/lib64/libz.so;/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/lib/libhdf5.a][/usr/gapps/visit/hdf5/1.8.4/linux-x86_64_gcc-4.1/include][v()] //Details about finding MPI FIND_PACKAGE_MESSAGE_DETAILS_MPI:INTERNAL=[/usr/local/tools/mvapich-gnu/lib/shared/libmpich.so][/usr/local/tools/mvapich-gnu/include][v()] //Details about finding Qt4 FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib][/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include][/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/moc][/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/uic][/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/rcc] //Details about finding Threads FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE][v()] //Details about finding X11 FIND_PACKAGE_MESSAGE_DETAILS_X11:INTERNAL=[/usr/lib64/libX11.so][/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include] //Details about finding ZLIB FIND_PACKAGE_MESSAGE_DETAILS_ZLIB:INTERNAL=[/usr/include][/usr/lib64/libz.so][v1.2.3()] //Result of TRY_COMPILE GETTIMEOFDAY_GIVES_TZ:INTERNAL=FALSE //ADVANCED property for variable: GITCOMMAND GITCOMMAND-ADVANCED:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddress GLX_DECLARES_FUNCTION_glXGetProcAddress:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB GLX_DECLARES_FUNCTION_glXGetProcAddressARB:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY:INTERNAL= //Test GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY:INTERNAL= //Test GLX_DEFINES_MACRO_GLX_ARB_get_proc_address GLX_DEFINES_MACRO_GLX_ARB_get_proc_address:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_1 GLX_DEFINES_MACRO_GLX_VERSION_1_1:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_2 GLX_DEFINES_MACRO_GLX_VERSION_1_2:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_3 GLX_DEFINES_MACRO_GLX_VERSION_1_3:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_4 GLX_DEFINES_MACRO_GLX_VERSION_1_4:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXFBConfig GLX_DEFINES_TYPE_GLXFBConfig:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr GLX_DEFINES_TYPE_GLXextFuncPtr:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY:INTERNAL= //Test GLX_INCLUDES_GLXEXT GLX_INCLUDES_GLXEXT:INTERNAL=1 GLX_USES_MACRO_GLX_GLXEXT_LEGACY:INTERNAL=TRUE //ADVANCED property for variable: GUNZIPCOMMAND GUNZIPCOMMAND-ADVANCED:INTERNAL=1 //Other test H5_CXX_HAVE_OFFSETOF:INTERNAL=1 //Other test H5_DEV_T_IS_SCALAR:INTERNAL= //Checking IF overflows normally converting floating-point to integer // values H5_FP_TO_INTEGER_OVERFLOW_WORKS:INTERNAL=1 //Result of TRY_COMPILE H5_FP_TO_INTEGER_OVERFLOW_WORKS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_INTEGER_OVERFLOW_WORKS_RUN:INTERNAL=0 //Checking IF accurately roundup converting floating-point to unsigned // long long values H5_FP_TO_ULLONG_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_FP_TO_ULLONG_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_ULLONG_ACCURATE_RUN:INTERNAL=0 //Checking IF right maximum converting floating-point to unsigned // long long values H5_FP_TO_ULLONG_RIGHT_MAXIMUM:INTERNAL= //Result of TRY_COMPILE H5_FP_TO_ULLONG_RIGHT_MAXIMUM_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_ULLONG_RIGHT_MAXIMUM_RUN:INTERNAL=1 //Other test H5_GETTIMEOFDAY_GIVES_TZ:INTERNAL= //Have function alarm H5_HAVE_ALARM:INTERNAL=1 //Other test H5_HAVE_ATTRIBUTE:INTERNAL=1 //Other test H5_HAVE_C99_DESIGNATED_INITIALIZER:INTERNAL=1 //Other test H5_HAVE_C99_FUNC:INTERNAL=1 //Have symbol tzname H5_HAVE_DECL_TZNAME:INTERNAL=1 //Have function difftime H5_HAVE_DIFFTIME:INTERNAL=1 //Have include H5_HAVE_DLFCN_H H5_HAVE_DLFCN_H:INTERNAL=1 //Have include H5_HAVE_FEATURES_H H5_HAVE_FEATURES_H:INTERNAL=1 //Have function fork H5_HAVE_FORK:INTERNAL=1 //Have function frexpf H5_HAVE_FREXPF:INTERNAL=1 //Have function frexpl H5_HAVE_FREXPL:INTERNAL=1 //Have function fseeko H5_HAVE_FSEEKO:INTERNAL=1 //Have function fstat64 H5_HAVE_FSTAT64:INTERNAL=1 //Have function ftello H5_HAVE_FTELLO:INTERNAL=1 //Other test H5_HAVE_FUNCTION:INTERNAL=1 //Have function gethostname H5_HAVE_GETHOSTNAME:INTERNAL=1 //Have function getpwuid H5_HAVE_GETPWUID:INTERNAL=1 //Have function getrusage H5_HAVE_GETRUSAGE:INTERNAL=1 //Have includes H5_HAVE_GLOBUS_COMMON_H H5_HAVE_GLOBUS_COMMON_H:INTERNAL= //Have include H5_HAVE_INTTYPES_H H5_HAVE_INTTYPES_H:INTERNAL=1 //Have function ioctl H5_HAVE_IOCTL:INTERNAL=1 //Have includes H5_HAVE_IO_H H5_HAVE_IO_H:INTERNAL= //Have library m; H5_HAVE_LIBM:INTERNAL=1 //Have library socket;m H5_HAVE_LIBSOCKET:INTERNAL= //Have library ucb;m H5_HAVE_LIBUCB:INTERNAL= //Have library ws2_32;m H5_HAVE_LIBWS2_32:INTERNAL= //Have library wsock32;m H5_HAVE_LIBWSOCK32:INTERNAL= //Have function longjmp H5_HAVE_LONGJMP:INTERNAL=1 //Have function lstat H5_HAVE_LSTAT:INTERNAL=1 //Have include H5_HAVE_MEMORY_H H5_HAVE_MEMORY_H:INTERNAL=1 //Have includes H5_HAVE_MFHDF_H H5_HAVE_MFHDF_H:INTERNAL= //Have include H5_HAVE_NETINET_IN_H H5_HAVE_NETINET_IN_H:INTERNAL=1 //Other test H5_HAVE_OFF64_T:INTERNAL= //Have includes H5_HAVE_PDB_H H5_HAVE_PDB_H:INTERNAL= //Have include H5_HAVE_PTHREAD_H H5_HAVE_PTHREAD_H:INTERNAL=1 //Have function random H5_HAVE_RANDOM:INTERNAL=1 //Have function rand_r H5_HAVE_RAND_R:INTERNAL=1 //Have function setjmp H5_HAVE_SETJMP:INTERNAL=1 //Have include H5_HAVE_SETJMP_H H5_HAVE_SETJMP_H:INTERNAL=1 //Have function setsysinfo H5_HAVE_SETSYSINFO:INTERNAL= //Have function sigaction H5_HAVE_SIGACTION:INTERNAL=1 //Have function siglongjmp H5_HAVE_SIGLONGJMP:INTERNAL=1 //Have function signal H5_HAVE_SIGNAL:INTERNAL=1 //Have function sigprocmask H5_HAVE_SIGPROCMASK:INTERNAL=1 //Have function sigsetjmp H5_HAVE_SIGSETJMP:INTERNAL= //Have function snprintf H5_HAVE_SNPRINTF:INTERNAL=1 //Other test H5_HAVE_SOCKLEN_T:INTERNAL=1 //Have function srandom H5_HAVE_SRANDOM:INTERNAL=1 //Have includes H5_HAVE_SRBCLIENT_H H5_HAVE_SRBCLIENT_H:INTERNAL= //Have function stat64 H5_HAVE_STAT64:INTERNAL=1 //Other test H5_HAVE_STAT_ST_BLOCKS:INTERNAL=1 //Have include H5_HAVE_STDDEF_H H5_HAVE_STDDEF_H:INTERNAL=1 //Have include H5_HAVE_STDINT_H H5_HAVE_STDINT_H:INTERNAL=1 //Have include stdint.h H5_HAVE_STDINT_H_CXX:INTERNAL=1 //Have include H5_HAVE_STDLIB_H H5_HAVE_STDLIB_H:INTERNAL=1 //Have function strdup H5_HAVE_STRDUP:INTERNAL=1 //Have include H5_HAVE_STRINGS_H H5_HAVE_STRINGS_H:INTERNAL=1 //Have include H5_HAVE_STRING_H H5_HAVE_STRING_H:INTERNAL=1 //Other test H5_HAVE_STRUCT_TIMEZONE:INTERNAL= //Other test H5_HAVE_STRUCT_TM_TM_ZONE:INTERNAL=1 //Have function symlink H5_HAVE_SYMLINK:INTERNAL=1 //Have function system H5_HAVE_SYSTEM:INTERNAL=1 //Have include H5_HAVE_SYS_IOCTL_H H5_HAVE_SYS_IOCTL_H:INTERNAL=1 //Have includes H5_HAVE_SYS_PROC_H H5_HAVE_SYS_PROC_H:INTERNAL= //Have include H5_HAVE_SYS_RESOURCE_H H5_HAVE_SYS_RESOURCE_H:INTERNAL=1 //Have include H5_HAVE_SYS_SOCKET_H H5_HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include H5_HAVE_SYS_STAT_H H5_HAVE_SYS_STAT_H:INTERNAL=1 H5_HAVE_SYS_SYSINFO_H:INTERNAL= //Have include H5_HAVE_SYS_TIMEB_H H5_HAVE_SYS_TIMEB_H:INTERNAL=1 //H5_HAVE_SYS_TIME_GETTIMEOFDAY H5_HAVE_SYS_TIME_GETTIMEOFDAY:INTERNAL=1 //Have include H5_HAVE_SYS_TIME_H H5_HAVE_SYS_TIME_H:INTERNAL=1 //Have include H5_HAVE_SYS_TYPES_H H5_HAVE_SYS_TYPES_H:INTERNAL=1 //Other test H5_HAVE_TIMEZONE:INTERNAL=1 //Have include H5_HAVE_TIME_H H5_HAVE_TIME_H:INTERNAL=1 //Have symbol TIOCGETD H5_HAVE_TIOCGETD:INTERNAL=1 //Have symbol TIOCGWINSZ H5_HAVE_TIOCGWINSZ:INTERNAL=1 //Other test H5_HAVE_TM_GMTOFF:INTERNAL=1 //Other test H5_HAVE_TM_ZONE:INTERNAL=1 //Have include H5_HAVE_UNISTD_H H5_HAVE_UNISTD_H:INTERNAL=1 //Have function vasprintf H5_HAVE_VASPRINTF:INTERNAL=1 //Have function vsnprintf H5_HAVE_VSNPRINTF:INTERNAL=1 //Have function waitpid H5_HAVE_WAITPID:INTERNAL=1 //Have includes H5_HAVE_WINSOCK_H H5_HAVE_WINSOCK_H:INTERNAL= //Other test H5_INLINE_TEST___inline:INTERNAL=1 //Other test H5_INLINE_TEST___inline__:INTERNAL=1 //Other test H5_INLINE_TEST_inline:INTERNAL=1 //checking IF accurately converting from integers to long double H5_INTEGER_TO_LDOUBLE_ACCURATE:INTERNAL=1 //checking IF converting from long double to integers is accurate H5_LDOUBLE_TO_INTEGER_ACCURATE:INTERNAL=1 //Checking IF converting from long double to integers works H5_LDOUBLE_TO_INTEGER_WORKS:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_INTEGER_WORKS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_INTEGER_WORKS_RUN:INTERNAL=0 //Checking IF correctly converting long double to (unsigned) long // long values H5_LDOUBLE_TO_LLONG_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_LLONG_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_LLONG_ACCURATE_RUN:INTERNAL=0 //Checking IF correctly converting long double to unsigned int // values H5_LDOUBLE_TO_UINT_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_UINT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_UINT_ACCURATE_RUN:INTERNAL=0 //Checking IF compiling long long to floating-point typecasts work H5_LLONG_TO_FP_CAST_WORKS:INTERNAL=1 //Checking IF correctly converting (unsigned) long long to long // double values H5_LLONG_TO_LDOUBLE_CORRECT:INTERNAL=1 //Result of TRY_COMPILE H5_LLONG_TO_LDOUBLE_CORRECT_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LLONG_TO_LDOUBLE_CORRECT_RUN:INTERNAL=0 //Checking IF alignment restrictions are strictly enforced H5_NO_ALIGNMENT_RESTRICTIONS:INTERNAL=1 //Result of TRY_COMPILE H5_NO_ALIGNMENT_RESTRICTIONS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_NO_ALIGNMENT_RESTRICTIONS_RUN:INTERNAL=0 //Width for printf for type `long long' or `__int64', us. `ll H5_PRINTF_LL_WIDTH:INTERNAL="ll" //CHECK_TYPE_SIZE: sizeof(char) H5_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) H5_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) H5_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) H5_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int16_t) H5_SIZEOF_INT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int32_t) H5_SIZEOF_INT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int64_t) H5_SIZEOF_INT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int8_t) H5_SIZEOF_INT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_fast16_t) H5_SIZEOF_INT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast32_t) H5_SIZEOF_INT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast64_t) H5_SIZEOF_INT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast8_t) H5_SIZEOF_INT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_least16_t) H5_SIZEOF_INT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int_least32_t) H5_SIZEOF_INT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int_least64_t) H5_SIZEOF_INT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_least8_t) H5_SIZEOF_INT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(long) H5_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long double) H5_SIZEOF_LONG_DOUBLE:INTERNAL=16 //CHECK_TYPE_SIZE: sizeof(long long) H5_SIZEOF_LONG_LONG:INTERNAL=8 //SizeOf for off64_t H5_SIZEOF_OFF64_T:INTERNAL=0 //CHECK_TYPE_SIZE: sizeof(off_t) H5_SIZEOF_OFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) H5_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(size_t) H5_SIZEOF_SIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ssize_t) H5_SIZEOF_SSIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint16_t) H5_SIZEOF_UINT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint32_t) H5_SIZEOF_UINT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint64_t) H5_SIZEOF_UINT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint8_t) H5_SIZEOF_UINT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_fast16_t) H5_SIZEOF_UINT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast32_t) H5_SIZEOF_UINT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast64_t) H5_SIZEOF_UINT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast8_t) H5_SIZEOF_UINT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_least16_t) H5_SIZEOF_UINT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint_least32_t) H5_SIZEOF_UINT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint_least64_t) H5_SIZEOF_UINT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_least8_t) H5_SIZEOF_UINT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(unsigned) H5_SIZEOF_UNSIGNED:INTERNAL=4 //SizeOf for __int64 H5_SIZEOF___INT64:INTERNAL=0 //Other test H5_STDC_HEADERS:INTERNAL=1 //Other test H5_SYSTEM_SCOPE_THREADS:INTERNAL=1 //Other test H5_TIME_WITH_SYS_TIME:INTERNAL=1 //Checking IF compiling unsigned long long to floating-point typecasts // work H5_ULLONG_TO_FP_CAST_WORKS:INTERNAL=1 //Checking IF converting unsigned long long to long double with // precision H5_ULLONG_TO_LDOUBLE_PRECISION:INTERNAL=1 //Result of TRY_COMPILE H5_ULLONG_TO_LDOUBLE_PRECISION_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULLONG_TO_LDOUBLE_PRECISION_RUN:INTERNAL=0 //Checking IF accurately converting unsigned long to float values H5_ULONG_TO_FLOAT_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_ULONG_TO_FLOAT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULONG_TO_FLOAT_ACCURATE_RUN:INTERNAL=0 //Checking IF accurately converting unsigned long long to floating-point // values H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE:INTERNAL= //Result of TRY_COMPILE H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE_RUN:INTERNAL=1 //Other test H5_VSNPRINTF_WORKS:INTERNAL=1 //Have symbol alloca HAVE_ALLOCA:INTERNAL=1 //Have include HAVE_ALLOCA_H HAVE_ALLOCA_H:INTERNAL=1 //Have include HAVE_ANSIDECL_H HAVE_ANSIDECL_H:INTERNAL=1 //Have include HAVE_ARPA_INET_H HAVE_ARPA_INET_H:INTERNAL=1 //Have include HAVE_ARPA_NAMESER_H HAVE_ARPA_NAMESER_H:INTERNAL=1 //Have include HAVE_ASSERT_H HAVE_ASSERT_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_ATTRIBUTE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_C99_DESIGNATED_INITIALIZER:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_C99_FUNC:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have include HAVE_CTYPE_H HAVE_CTYPE_H:INTERNAL=1 //Have include HAVE_DIRENT_H HAVE_DIRENT_H:INTERNAL=1 //Have include HAVE_DLFCN_H HAVE_DLFCN_H:INTERNAL=1 //Have library dl;-lpthread;dl;m HAVE_DLOPEN:INTERNAL=1 //Have includes HAVE_DL_H HAVE_DL_H:INTERNAL= //Have include HAVE_ERRNO_H HAVE_ERRNO_H:INTERNAL=1 //Have include HAVE_FCNTL_H HAVE_FCNTL_H:INTERNAL=1 //Have include fenv.h HAVE_FENV_H:INTERNAL=1 //Have symbol finite HAVE_FINITE:INTERNAL=1 //Have include HAVE_FLOAT_H HAVE_FLOAT_H:INTERNAL=1 //Have function floor HAVE_FLOOR:INTERNAL= //Have symbol fpclass HAVE_FPCLASS:INTERNAL= //Have symbol fprintf HAVE_FPRINTF:INTERNAL=1 //Have symbol fp_class HAVE_FP_CLASS:INTERNAL= //Have includes HAVE_FP_CLASS_H HAVE_FP_CLASS_H:INTERNAL= //Have symbol ftime HAVE_FTIME:INTERNAL=1 //NetCDF test HAVE_FTRUNCATE:INTERNAL=1 //Result of TRY_COMPILE HAVE_FUNCTION:INTERNAL=TRUE //Test HAVE_GCC_ERROR_RETURN_TYPE HAVE_GCC_ERROR_RETURN_TYPE:INTERNAL= //Test HAVE_GCC_VISIBILITY HAVE_GCC_VISIBILITY:INTERNAL=1 //Result of TRY_COMPILE HAVE_GETADDRINFO_COMPILED:INTERNAL=TRUE //Have function getopt HAVE_GETOPT:INTERNAL=1 //Have symbol gettimeofday HAVE_GETTIMEOFDAY:INTERNAL=1 //Result of TRY_COMPILE HAVE_H5_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_OFF64_T:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_H5_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UNSIGNED:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF___INT64:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF___INT64:INTERNAL=FALSE //Have includes HAVE_IEEEFP_H HAVE_IEEEFP_H:INTERNAL= //Have include HAVE_INTTYPES_H HAVE_INTTYPES_H:INTERNAL=1 //Have function isascii HAVE_ISASCII:INTERNAL=1 //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF___INT64:INTERNAL=FALSE //Have library dl; HAVE_LIBDL:INTERNAL=1 //Have include HAVE_LIMITS_H HAVE_LIMITS_H:INTERNAL=1 //Have symbol localtime HAVE_LOCALTIME:INTERNAL=1 //Have include HAVE_MALLOC_H HAVE_MALLOC_H:INTERNAL=1 //Have include HAVE_MATH_H HAVE_MATH_H:INTERNAL=1 //Have function memmove HAVE_MEMMOVE:INTERNAL=1 //Have include HAVE_MEMORY_H HAVE_MEMORY_H:INTERNAL=1 //Have function memset HAVE_MEMSET:INTERNAL=1 //Have function mmap HAVE_MMAP:INTERNAL=1 //Have includes HAVE_NAN_H HAVE_NAN_H:INTERNAL= //Have includes HAVE_NDIR_H HAVE_NDIR_H:INTERNAL= //Have include HAVE_NETDB_H HAVE_NETDB_H:INTERNAL=1 //Have include HAVE_NETINET_IN_H HAVE_NETINET_IN_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_OFF64_T:INTERNAL=FALSE //Have function pow HAVE_POW:INTERNAL= //Have symbol printf HAVE_PRINTF:INTERNAL=1 //Have include HAVE_PTHREAD_H HAVE_PTHREAD_H:INTERNAL=1 //Have include HAVE_RESOLV_H HAVE_RESOLV_H:INTERNAL=1 //Have library dld;dl HAVE_SHLLOAD:INTERNAL= //Have symbol signal HAVE_SIGNAL:INTERNAL=1 //Have include HAVE_SIGNAL_H HAVE_SIGNAL_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_PTRDIFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UCHAR:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF__BOOL:INTERNAL=TRUE //Have symbol snprintf HAVE_SNPRINTF:INTERNAL=1 //support for socklen_t HAVE_SOCKLEN_T:INTERNAL=1 //Result of TRY_COMPILE HAVE_SOCKLEN_T_COMPILED:INTERNAL=TRUE //Have symbol sprintf HAVE_SPRINTF:INTERNAL=1 //Have function sqrt HAVE_SQRT:INTERNAL= //Have symbol sscanf HAVE_SSCANF:INTERNAL=1 //Have symbol stat HAVE_STAT:INTERNAL=1 //Result of TRY_COMPILE HAVE_STAT_ST_BLOCKS:INTERNAL=TRUE //Have include HAVE_STDARG_H HAVE_STDARG_H:INTERNAL=1 //Have include HAVE_STDBOOL_H HAVE_STDBOOL_H:INTERNAL=1 //Have include stddef.h HAVE_STDDEF_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H:INTERNAL=1 //Have include HAVE_STDIO_H HAVE_STDIO_H:INTERNAL=1 //Have include HAVE_STDLIB_H HAVE_STDLIB_H:INTERNAL=1 //Have function strcasecmp HAVE_STRCASECMP:INTERNAL=1 //Have function strchr HAVE_STRCHR:INTERNAL=1 //Have symbol strdup HAVE_STRDUP:INTERNAL=1 //Have symbol strerror HAVE_STRERROR:INTERNAL=1 //Have symbol strftime HAVE_STRFTIME:INTERNAL=1 //Have include HAVE_STRINGS_H HAVE_STRINGS_H:INTERNAL=1 //Have include HAVE_STRING_H HAVE_STRING_H:INTERNAL=1 //Have symbol strndup HAVE_STRNDUP:INTERNAL=1 //Have function strrchr HAVE_STRRCHR:INTERNAL=1 //Have function strstr HAVE_STRSTR:INTERNAL=1 //Have function strtol HAVE_STRTOL:INTERNAL=1 //Have function strtoll HAVE_STRTOLL:INTERNAL=1 //Have function areroul HAVE_STRTOUL:INTERNAL= //Result of TRY_COMPILE HAVE_STRUCT_TIMEZONE:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_STRUCT_TM_TM_ZONE:INTERNAL=TRUE //NetCDF test HAVE_ST_BLKSIZE:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_DIR_H_COMPILED:INTERNAL=TRUE //Have include HAVE_SYS_MMAN_H HAVE_SYS_MMAN_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_NDIR_H_COMPILED:INTERNAL=FALSE //Have include HAVE_SYS_SELECT_H HAVE_SYS_SELECT_H:INTERNAL=1 //Have include HAVE_SYS_SOCKET_H HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include HAVE_SYS_STAT_H HAVE_SYS_STAT_H:INTERNAL=1 //Have include HAVE_SYS_TIMEB_H HAVE_SYS_TIMEB_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_TIME_GETTIMEOFDAY:INTERNAL=TRUE //Have include HAVE_SYS_TIME_H HAVE_SYS_TIME_H:INTERNAL=1 //Have include sys/types.h HAVE_SYS_TYPES_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_TIMEZONE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_TIME_GETTIMEOFDAY:INTERNAL=FALSE //Have include HAVE_TIME_H HAVE_TIME_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_TM_GMTOFF:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_TM_ZONE:INTERNAL=TRUE //Have include HAVE_UNISTD_H HAVE_UNISTD_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_VA_COPY_COMPILED:INTERNAL=TRUE //Have symbol vfprintf HAVE_VFPRINTF:INTERNAL=1 //Have symbol vsnprintf HAVE_VSNPRINTF:INTERNAL=1 //Have symbol vsprintf HAVE_VSPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF___INT64:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_VTK_UINTPTR_T:INTERNAL=TRUE //Have includes HAVE_WINDOWS_H HAVE_WINDOWS_H:INTERNAL= //Result of TRY_COMPILE HAVE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have symbol _stat HAVE__STAT:INTERNAL= //Result of TRY_COMPILE HAVE___VA_COPY_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: HDF5_BUILD_CPP_LIB HDF5_BUILD_CPP_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_BUILD_HL_LIB HDF5_BUILD_HL_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_CXX_COMPILER_EXECUTABLE HDF5_CXX_COMPILER_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_C_COMPILER_EXECUTABLE HDF5_C_COMPILER_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_C_INCLUDE_DIR HDF5_C_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_DIFF_EXECUTABLE HDF5_DIFF_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_DISABLE_COMPILER_WARNINGS HDF5_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_HSIZET HDF5_ENABLE_HSIZET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_LARGE_FILE HDF5_ENABLE_LARGE_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_PARALLEL HDF5_ENABLE_PARALLEL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_SZIP_SUPPORT HDF5_ENABLE_SZIP_SUPPORT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_ENABLE_Z_LIB_SUPPORT HDF5_ENABLE_Z_LIB_SUPPORT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_Enable_Clear_File_Buffers HDF5_Enable_Clear_File_Buffers-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_Enable_Instrument HDF5_Enable_Instrument-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_INCLUDE_DIR HDF5_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_IS_PARALLEL HDF5_IS_PARALLEL-ADVANCED:INTERNAL=1 //Used to pass variables between directories HDF5_LIBRARIES_TO_EXPORT:INTERNAL=vtkhdf5 //ADVANCED property for variable: HDF5_LIBRARY HDF5_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_METADATA_TRACE_FILE HDF5_METADATA_TRACE_FILE-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE HDF5_PRINTF_LL_TEST_COMPILE:INTERNAL=TRUE //Result of TRY_RUN HDF5_PRINTF_LL_TEST_RUN:INTERNAL=0 //ADVANCED property for variable: HDF5_STRICT_FORMAT_CHECKS HDF5_STRICT_FORMAT_CHECKS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_16_API_DEFAULT HDF5_USE_16_API_DEFAULT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_FILTER_FLETCHER32 HDF5_USE_FILTER_FLETCHER32-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_FILTER_NBIT HDF5_USE_FILTER_NBIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_FILTER_SCALEOFFSET HDF5_USE_FILTER_SCALEOFFSET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_FILTER_SHUFFLE HDF5_USE_FILTER_SHUFFLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_USE_H5DUMP_PACKED_BITS HDF5_USE_H5DUMP_PACKED_BITS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_WANT_DATA_ACCURACY HDF5_WANT_DATA_ACCURACY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_WANT_DCONV_EXCEPTION HDF5_WANT_DCONV_EXCEPTION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_LIBRARY HDF5_hdf5_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_LIBRARY_DEBUG HDF5_hdf5_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_LIBRARY_RELEASE HDF5_hdf5_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_hl_LIBRARY HDF5_hdf5_hl_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_hl_LIBRARY_DEBUG HDF5_hdf5_hl_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDF5_hdf5_hl_LIBRARY_RELEASE HDF5_hdf5_hl_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HGCOMMAND HGCOMMAND-ADVANCED:INTERNAL=1 //HTMLDocumentation files generated from ServerManager HTMLDocumentation_FILES:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Documentation/ParaViewSources.html;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Documentation/ParaViewFilters.html;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Documentation/ParaViewReaders.html;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Documentation/ParaViewWriters.html //ADVANCED property for variable: ICET_BUILD_TESTING ICET_BUILD_TESTING-ADVANCED:INTERNAL=1 //This is set from VTK_MPIRUN_EXE. ICET_MPIRUN_EXE:INTERNAL=/usr/local/bin/mpirun //ADVANCED property for variable: ICET_MPI_MAX_NUMPROCS ICET_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //This is set from VTK_MPI_MAX_NUMPROCS. ICET_MPI_MAX_NUMPROCS:INTERNAL=2 //This is set from VTK_MPI_POSTFLAGS. ICET_MPI_POSTFLAGS:INTERNAL= //This is set from a combination of VTK_MPI_PREFLAGS VTK_MPI_NUMPROC_FLAG // VTK_MPI_MAX_NUMPROCS VTK_MPI_PREFLAGS. ICET_MPI_PREFLAGS:INTERNAL=;-np;2; //CHECK_TYPE_SIZE: sizeof(char) ICET_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) ICET_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) ICET_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) ICET_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) ICET_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) ICET_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) ICET_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(void*) ICET_SIZEOF_VOID_P:INTERNAL=8 //CHECK_TYPE_SIZE: __int64 unknown ICET_SIZEOF___INT64:INTERNAL= //Whether streams support 64-bit types ICE_HAVE_64BIT_STREAMS:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_FCNTL ICE_HAVE_FCNTL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_MMAN ICE_HAVE_MMAN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICE_HAVE_NETINET ICE_HAVE_NETINET-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE INLINE_TEST___inline:INTERNAL=TRUE //Result of TRY_COMPILE INLINE_TEST___inline__:INTERNAL=TRUE //Result of TRY_COMPILE INLINE_TEST_inline:INTERNAL=TRUE //ADVANCED property for variable: JAVACOMMAND JAVACOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: KWCommon_BUILD_TESTING KWCommon_BUILD_TESTING-ADVANCED:INTERNAL=1 //include paths for KWCommon KWCommon_INCLUDE_PATH:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Common/KWCommon //libraries for KWCommon KWCommon_LIBRARIES:INTERNAL=KWCommon //Result of TRY_RUN KWSYS_CHAR_IS_SIGNED:INTERNAL=0 //Result of TRY_COMPILE KWSYS_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ARGUMENT_DEPENDENT_LOOKUP_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDDEF_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDIO_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_FULL_SPECIALIZATION_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_MEMBER_TEMPLATES_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_NULL_TEMPLATE_ARGS_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_C_HAS_PTRDIFF_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_C_HAS_SSIZE_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_C_TYPE_MACROS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_BINARY_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_ANSI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_SSTREAM_COMPILED:INTERNAL=TRUE //Result of TRY_RUN KWSYS_LFS_WORKS:INTERNAL=0 //Result of TRY_COMPILE KWSYS_LFS_WORKS_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(char) KWSYS_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int) KWSYS_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) KWSYS_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) KWSYS_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) KWSYS_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: __int64 unknown KWSYS_SIZEOF___INT64:INTERNAL= //Result of TRY_COMPILE KWSYS_STAT_HAS_ST_MTIM_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_MAX_SIZE_ARGUMENT_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_OBJECTS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_REBIND_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_TEMPLATE_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ITERATOR_TRAITS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_STRING_HAVE_NEQ_CHAR_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: LIBRARY_OUTPUT_PATH LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1 //Single output directory for building all libraries. LIBRARY_OUTPUT_PATH:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/bin //ADVANCED property for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //Path to vtkMaterialLibraryMacro.h MATERIAL_LIBRARY_MATERIAL_MACRO_HEADER:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/MaterialLibrary/vtkMaterialLibraryMacro.h //Path to vtkShaderCodeLibraryMacro.h MATERIAL_LIBRARY_SHADER_MACRO_HEADER:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/MaterialLibrary/vtkShaderCodeLibraryMacro.h //ADVANCED property for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MILI_INCLUDE_DIR MILI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MILI_LIBRARY MILI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC MPIEXEC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_MAX_NUMPROCS MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_NUMPROC_FLAG MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_POSTFLAGS MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_PREFLAGS MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_COMPILER MPI_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_COMPILE_FLAGS MPI_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_EXTRA_LIBRARY MPI_EXTRA_LIBRARY-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_INCLUDE_PATH MPI_INCLUDE_PATH-ADVANCED:INTERNAL=0 //Scratch variable for MPI detection MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND //ADVANCED property for variable: MPI_LIBRARY MPI_LIBRARY-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_LINK_FLAGS MPI_LINK_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF_DISABLE_COMPILER_WARNINGS NETCDF_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //Have library c NOT_NEED_LIBNSL:INTERNAL=1 //ADVANCED property for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ALWAYS_SECURE_CONNECTION PARAVIEW_ALWAYS_SECURE_CONNECTION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_AdiosReader PARAVIEW_BUILD_PLUGIN_AdiosReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIReaderWriter-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_CoProcessingScriptGenerator PARAVIEW_BUILD_PLUGIN_CoProcessingScriptGenerator-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_EyeDomeLighting PARAVIEW_BUILD_PLUGIN_EyeDomeLighting-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_ForceTime PARAVIEW_BUILD_PLUGIN_ForceTime-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_H5PartReader PARAVIEW_BUILD_PLUGIN_H5PartReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Manta PARAVIEW_BUILD_PLUGIN_Manta-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Moments PARAVIEW_BUILD_PLUGIN_Moments-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_NetDMFReader PARAVIEW_BUILD_PLUGIN_NetDMFReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PacMan PARAVIEW_BUILD_PLUGIN_PacMan-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PointSprite PARAVIEW_BUILD_PLUGIN_PointSprite-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Prism PARAVIEW_BUILD_PLUGIN_Prism-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SLACTools PARAVIEW_BUILD_PLUGIN_SLACTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SierraPlotTools PARAVIEW_BUILD_PLUGIN_SierraPlotTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_StreamingView PARAVIEW_BUILD_PLUGIN_StreamingView-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SurfaceLIC PARAVIEW_BUILD_PLUGIN_SurfaceLIC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VRPNPlugin PARAVIEW_BUILD_PLUGIN_VRPNPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VRUIPlugin PARAVIEW_BUILD_PLUGIN_VRUIPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VaporPlugin PARAVIEW_BUILD_PLUGIN_VaporPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_ParaView PARAVIEW_BUILD_ParaView-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_WITH_ADAPTOR PARAVIEW_BUILD_WITH_ADAPTOR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_CLIENT_RENDER_SERVER_TESTS PARAVIEW_CLIENT_RENDER_SERVER_TESTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_DISABLE_VTK_TESTING PARAVIEW_DISABLE_VTK_TESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ENABLE_COPROCESSING PARAVIEW_ENABLE_COPROCESSING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ENABLE_FPE PARAVIEW_ENABLE_FPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_EXTERNAL_PLUGINS_FILE PARAVIEW_EXTERNAL_PLUGINS_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_EXTRA_EXTERNAL_MODULES PARAVIEW_EXTRA_EXTERNAL_MODULES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_EXTRA_INSTALL_RULES_FILE PARAVIEW_EXTRA_INSTALL_RULES_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_FIXUP_BUNDLE_SEARCH_PATHS PARAVIEW_FIXUP_BUNDLE_SEARCH_PATHS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_GENERATE_PROXY_DOCUMENTATION PARAVIEW_GENERATE_PROXY_DOCUMENTATION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_INSTALL_DEVELOPMENT PARAVIEW_INSTALL_DEVELOPMENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_INSTALL_MPIEXEC PARAVIEW_INSTALL_MPIEXEC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_MINIMAL_BUILD PARAVIEW_MINIMAL_BUILD-ADVANCED:INTERNAL=1 //List of configured plugins PARAVIEW_PLUGINLIST:INTERNAL=Moments;PrismServerPlugin;PrismClientPlugin;PacMan;PointSprite_Plugin;SierraPlotTools;SLACTools;StreamingView;SurfaceLIC;H5PartReader;AnalyzeReader;AnalyzeWriter;NIfTIReader;NIfTIWriter //ADVANCED property for variable: PARAVIEW_TESTING_WITH_PYTHON PARAVIEW_TESTING_WITH_PYTHON-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USERS_GUIDE PARAVIEW_USERS_GUIDE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_ICE_T PARAVIEW_USE_ICE_T-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_MPI_SSEND PARAVIEW_USE_MPI_SSEND-ADVANCED:INTERNAL=1 //Have symbol atanh PROJ_HAVE_ATANH:INTERNAL=1 //Have symbol csin PROJ_HAVE_COMPLEX:INTERNAL=1 //ADVANCED property for variable: PROJ_LIST_EXTERNAL PROJ_LIST_EXTERNAL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROJ_USE_GSL PROJ_USE_GSL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROJ_USE_PTHREADS PROJ_USE_PTHREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROTOBUF_DISABLE_COMPILER_WARNINGS PROTOBUF_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_CLEAN_COMMAND PV_TEST_CLEAN_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_CLIENT PV_TEST_CLIENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_INIT_COMMAND PV_TEST_INIT_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_SERVER_ROOT PV_TEST_SERVER_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_EXECUTABLE PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1 QT_BINARY_DIR:INTERNAL=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin //ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DESIGNER_EXECUTABLE QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DOC_DIR QT_DOC_DIR-ADVANCED:INTERNAL=1 QT_HEADERS_DIR:INTERNAL=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/include //ADVANCED property for variable: QT_HELP_GENERATOR QT_HELP_GENERATOR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_IMPORTS_DIR QT_IMPORTS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LIBRARY_DIR QT_LIBRARY_DIR-ADVANCED:INTERNAL=1 //Qt library dir QT_LIBRARY_DIR:INTERNAL=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/lib //ADVANCED property for variable: QT_LINGUIST_EXECUTABLE QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LRELEASE_EXECUTABLE QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LUPDATE_EXECUTABLE QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MKSPECS_DIR QT_MKSPECS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MOC_EXECUTABLE QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_INCLUDE_DIR QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PLUGINS_DIR QT_PLUGINS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1 QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/global/tools/Kitware/Paraview/3.10/chaos_4_x86_64_ib/bin/qmake //ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_INCLUDE_DIR QT_QTMOTIF_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY QT_QTMOTIF_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_DEBUG QT_QTMOTIF_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_RELEASE QT_QTMOTIF_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_INCLUDE_DIR QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_RCC_EXECUTABLE QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TESTING_EVENT_PLAYBACK_DELAY QT_TESTING_EVENT_PLAYBACK_DELAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TRANSLATIONS_DIR QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC3_EXECUTABLE QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC_EXECUTABLE QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1 //Have symbol Q_WS_MAC Q_WS_MAC:INTERNAL= //Have symbol Q_WS_QWS Q_WS_QWS:INTERNAL= //Have symbol Q_WS_WIN Q_WS_WIN:INTERNAL= //Have symbol Q_WS_X11 Q_WS_X11:INTERNAL=1 //ADVANCED property for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE SHARED_LIBRARY_PATH_INFO_COMPILED:INTERNAL=TRUE //Result of TRY_RUN SHARED_LIBRARY_PATH_TYPE:INTERNAL=0 //runtime library path variable name. SHARED_LIBRARY_PATH_VAR_NAME:INTERNAL=LD_LIBRARY_PATH //ADVANCED property for variable: SILO_INCLUDE_DIR SILO_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SILO_LIBRARY SILO_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SITE SITE-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(off64_t) SIZEOF_OFF64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(off_t) SIZEOF_OFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ptrdiff_t) SIZEOF_PTRDIFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(size_t) SIZEOF_SIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ssize_t) SIZEOF_SSIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: uchar unknown SIZEOF_UCHAR:INTERNAL= //CHECK_TYPE_SIZE: sizeof(_Bool) SIZEOF__BOOL:INTERNAL=1 //ADVANCED property for variable: SLURM_SBATCH_COMMAND SLURM_SBATCH_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SLURM_SRUN_COMMAND SLURM_SRUN_COMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE STDC_HEADERS:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED_MAP:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED_SET:INTERNAL=TRUE //Result of TRY_COMPILE SUPPORT_IP6_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE SYSTEM_SCOPE_THREADS:INTERNAL=TRUE //ADVANCED property for variable: TCL_LIBRARY TCL_LIBRARY-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE TIME_WITH_SYS_TIME:INTERNAL=TRUE //ADVANCED property for variable: TK_LIBRARY TK_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_BUILD_DOC VERDICT_BUILD_DOC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_ENABLE_TESTING VERDICT_ENABLE_TESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_MANGLE VERDICT_MANGLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_MANGLE_PREFIX VERDICT_MANGLE_PREFIX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_USE_FLOAT VERDICT_USE_FLOAT-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VISIT_COMPILER_FSTREAM_WORKAROUND:INTERNAL=FALSE //include directories VISIT_DB_INC_DIRS:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ANALYZE;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ANSYS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/AUXFile;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/BOV;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CEAucd;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CMAT;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CTRL;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Curve2D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Dyna3D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Enzo;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Fluent;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Gadget;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GTC;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GULP;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/H5Nimrod;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/LAMMPS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/LAMMPS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Lines;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/MM5;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Nek5000;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/OpenFOAM;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/OVERFLOW;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PATRAN;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PFLOTRAN;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Pixie;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PLOT2D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PLOT3D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Point3D;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/RAW;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAR;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Spheral;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tetrad;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/TFT;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/TSurf;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/UNIC;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Velodyne;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/XYZ;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Claw;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CGNS;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Mili //visit sources for readers VISIT_DB_SOURCES:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ANALYZE/avtANALYZEFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ANALYZE/DSRObject.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ANSYS/avtANSYSFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/AUXFile/avtAUXFileFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/AUXFile/avtAUXFileFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/BOV/avtBOVFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CEAucd/avtCEAucdFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CEAucd/FichierU.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CEAucd/vtkCEAucdReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/avtChomboFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/avtChomboFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/avtChomboOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/avtChomboOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/ChomboPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/ChomboPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/ChomboEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/ChomboMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Chombo/ChomboCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CMAT/avtCMATFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CTRL/avtCTRLFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Curve2D/avtCurve2DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD/avtDDCMDFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD/object.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD/object.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD/error.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/DDCMD/error.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Dyna3D/avtDyna3DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Enzo/avtEnzoFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Enzo/avtEnzoFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/avtExtrudedVolFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/avtExtrudedVolWriter.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/avtExtrudedVolOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/avtExtrudedVolOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/ExtrudedVolPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/ExtrudedVolPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/ExtrudedVolEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/ExtrudedVolMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ExtrudedVol/ExtrudedVolCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/avtFLASHFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/avtFLASHFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/avtFLASHOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/avtFLASHOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/FLASHPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/FLASHPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/FLASHEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/FLASHMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/FLASH/FLASHCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Fluent/avtFluentFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Fluent/avtFluentFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Gadget/avtGadgetFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/avtGGCMFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/avtGGCMOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/GGCMCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/GGCMEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/GGCMMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/GGCMPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/GGCMPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/ggcm_grid.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/ggcm_grid_gse.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/ggcm_field_matrix.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/ggcm_mhd_gse.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/ggcm_read_mhd.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GGCM/matrix.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GTC/avtGTCFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/GULP/avtGULPFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/H5Nimrod/avtH5NimrodFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/H5Nimrod/H5utils.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/vtkStimulateReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/avtImageFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/avtImageOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/avtImagePluginWriter.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/ImageMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/ImagePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/ImageCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Image/ImageEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/LAMMPS/avtLAMMPSStructureFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/LAMMPS/avtLAMMPSDumpFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Lines/avtLinesFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3D/avtM3DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/avtM3DC1FileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/avtM3DC1FileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/avtM3DC1Options.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/avtM3DC1Options.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/M3DC1PluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/M3DC1PluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/M3DC1EnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/M3DC1MDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/M3DC1/M3DC1CommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/avtMirandaFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/avtMirandaFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/avtMirandaOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/avtMirandaOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/MirandaPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/MirandaPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/MirandaEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/MirandaMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Miranda/MirandaCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/MM5/avtMM5FileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/MM5/MM5.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/avtNASTRANFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/avtNASTRANFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/avtNASTRANOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/avtNASTRANOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/NASTRANPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/NASTRANPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/NASTRANEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/NASTRANMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NASTRAN/NASTRANCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtBasicNETCDFFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtADAPTFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtLODIFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtLODIParticleFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtFVCOM_STSDFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtFVCOMParticleFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtFVCOM_MTSDFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtFVCOM_MTMDFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtCCSMFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtNETCDFReaderBase.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtBasicNETCDFReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtCCSMReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/avtFVCOMReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/NETCDF/NETCDFFileObject.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Nek5000/avtNek5000FileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/OpenFOAM/avtOpenFOAMFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/OVERFLOW/avtOVERFLOWFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/avtparaDISFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/avtparaDISOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDISCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDISEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDISMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDISPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDISPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDIS_lib/paradis.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/paraDIS_lib/paradis_c_interface.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/args.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/debugutil.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/fileutils.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/inventor.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/RangeList.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/timer.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/pathutil.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/avtparaDIS_tecplotFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/args.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/debugutil.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/signals.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/fileutils.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_c_lib/inventor.c;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/RangeList.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/timer.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/paraDIS/RC_cpp_lib/pathutil.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PATRAN/avtPATRANFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PFLOTRAN/avtPFLOTRANFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Pixie/avtPixieFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Pixie/avtPixieFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/avtPlainTextFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/avtPlainTextFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/avtPlainTextOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/avtPlainTextOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/PlainTextPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/PlainTextPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/PlainTextEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/PlainTextMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PlainText/PlainTextCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PLOT2D/avtPLOT2DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/PLOT3D/avtPLOT3DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Point3D/avtPoint3DFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/avtProteinDataBankFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/avtProteinDataBankFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/avtProteinDataBankOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/avtProteinDataBankOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/ProteinDataBankPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/ProteinDataBankPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/ProteinDataBankEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/ProteinDataBankMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/ProteinDataBank/ProteinDataBankCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/RAW/avtRAWFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/avtSAMRAIFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/avtSAMRAIFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/AutoArray.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/SAMRAIEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/SAMRAIPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/SAMRAIPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/SAMRAICommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAMRAI/SAMRAIMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAR/avtSARFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/SAS/avtSASFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Spheral/avtSpheralFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot/avtTecplotFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot/TecplotFile.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot/TecplotFile.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot/avtTecplotBinaryFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tecplot/TecplotFile.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tetrad/avtTetradFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Tetrad/avtTetradFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/TFT/avtTFTFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/TSurf/avtTSurfFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/UNIC/avtUNICFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP/avtOUTCARFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP/avtPOSCARFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/VASP/avtCHGCARFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Velodyne/avtVelodyneFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Velodyne/VelodyneReader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/avtVsFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/avtVsFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsFilter.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsH5Reader.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsSchema.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Vs/VsUtils.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvWriter.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/avtXmdvWriter.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/XmdvPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/XmdvPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/XmdvEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/XmdvMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Xmdv/XmdvCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/XYZ/avtXYZFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Claw/avtClawFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/avtSiloWriter.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/avtSiloFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/avtSiloFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/avtSiloOptions.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/avtSiloOptions.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/SiloPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/SiloPluginInfo.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/SiloCommonPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/SiloEnginePluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Silo/SiloMDServerPluginInfo.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CGNS/avtCGNSFileFormat.C;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/CGNS/avtCGNSFileFormat.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/Utilities/VisItBridge/databases/Mili/avtMiliFileFormat.C //ADVANCED property for variable: VISIT_DISABLE_COMPILER_WARNINGS VISIT_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //vtk classes to wrap for client server VISIT_SERVER_SOURCES:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItANALYZEReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItANALYZEReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItANSYSReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItANSYSReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItAuxFileReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItAuxFileReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItBOVReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItBOVReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCEAucdReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCEAucdReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItChomboReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItChomboReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCMATReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCMATReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCTRLReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCTRLReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCurve2DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCurve2DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItDDCMDReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItDDCMDReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItDyna3DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItDyna3DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItEnzoReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItEnzoReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItExtrudedVolReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItExtrudedVolReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFLASHReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFLASHReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFluentReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFluentReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGadgetReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGadgetReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGGCMReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGGCMReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGTCReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGTCReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGULPReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItGULPReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItH5NimrodReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItH5NimrodReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItImageReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItImageReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLAMMPSStructureReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLAMMPSStructureReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLAMMPSDumpReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLAMMPSDumpReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLinesReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLinesReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItM3DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItM3DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItM3DC1Reader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItM3DC1Reader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMirandaReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMirandaReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMM5Reader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMM5Reader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItNASTRANReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItNASTRANReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItADAPTReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItADAPTReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLODIReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLODIReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLODIParticleReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItLODIParticleReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_STSDReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_STSDReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_MTMDReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_MTMDReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_MTSDReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOM_MTSDReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOMParticleReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItFVCOMParticleReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCCSM_MTSD_Reader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCCSM_MTSD_Reader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCCSM_STSD_Reader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCCSM_STSD_Reader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItNek5000Reader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItNek5000Reader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOpenFOAMReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOpenFOAMReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOVERFLOWReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOVERFLOWReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItParaDISReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItParaDISReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItParaDISTecplotReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItParaDISTecplotReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPATRANReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPATRANReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPFLOTRANReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPFLOTRANReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPixieReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPixieReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPlainTextReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPlainTextReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPLOT2DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPLOT2DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPLOT3DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPLOT3DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPoint3DReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPoint3DReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItProteinDataBankReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItProteinDataBankReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItRAWReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItRAWReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSAMRAIReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSAMRAIReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSARReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSARReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSASReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSASReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSpheralReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSpheralReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTecplotReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTecplotReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTecplotBinaryReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTecplotBinaryReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTetradReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTetradReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTFTReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTFTReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTSurfReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItTSurfReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItUNICReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItUNICReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOUTCARReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItOUTCARReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPOSCARReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItPOSCARReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCHGCARReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCHGCARReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItVelodyneReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItVelodyneReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItVsReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItVsReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItXmdvReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItXmdvReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItXYZReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItXYZReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItClawReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItClawReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSiloReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItSiloReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCGNSReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItCGNSReader.h;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMiliReader.cxx;/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/Utilities/VisItBridge/databases/vtkVisItMiliReader.h //ADVANCED property for variable: VLI_LIBRARY_FOR_VP1000 VLI_LIBRARY_FOR_VP1000-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VSNPRINTF_WORKS:INTERNAL=TRUE //Result of TRY_COMPILE VTK_ANSI_STREAM_EOF_COMPILED:INTERNAL=TRUE //Result of TRY_RUN VTK_ANSI_STREAM_EOF_RESULT:INTERNAL=0 VTK_CMAKE_DIR:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/VTK/CMake //Support for C++ type bool VTK_COMPILER_HAS_BOOL:INTERNAL=1 //Support for full template specialization syntax VTK_COMPILER_HAS_FULL_SPECIALIZATION:INTERNAL=1 //Test VTK_CONST_REVERSE_ITERATOR_COMPARISON VTK_CONST_REVERSE_ITERATOR_COMPARISON:INTERNAL=1 //ADVANCED property for variable: VTK_DATA_ROOT VTK_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_DEBUG_LEAKS VTK_DEBUG_LEAKS-ADVANCED:INTERNAL=1 //The directory in which code for Shaders is provided. VTK_DEFAULT_SHADERS_DIR:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK/Utilities/MaterialLibrary/Repository VTK_DIR:INTERNAL=/nfs/tmp2/rcook/Paraview/3.10/build/Paraview-310-clone/ParaView/build/VTK //Support for C++ explict templates VTK_EXPLICIT_TEMPLATES:INTERNAL=1 //ADVANCED property for variable: VTK_GLEXT_FILE VTK_GLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_GLXEXT_FILE VTK_GLXEXT_FILE-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS:INTERNAL=TRUE //OpenGL includes used to test glXGetProcAddressARB prototype. VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_INCLUDES:INTERNAL=/usr/include //Already set VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_TESTED:INTERNAL=1 //Have symbol feenableexcept VTK_HAS_FEENABLEEXCEPT:INTERNAL=1 //Have symbol isinf VTK_HAS_ISINF:INTERNAL= //Have symbol isnan VTK_HAS_ISNAN:INTERNAL= //Have symbol _isnan VTK_HAS__ISNAN:INTERNAL= //Have include iosfwd VTK_HAVE_ANSI_STREAMS:INTERNAL=1 //Support for getsockname with socklen_t VTK_HAVE_GETSOCKNAME_WITH_SOCKLEN_T:INTERNAL=1 //Have library socket VTK_HAVE_LIBSOCKET:INTERNAL= //Have include iostream.h VTK_HAVE_OLD_STREAMS:INTERNAL=1 //Have include strstream.h VTK_HAVE_OLD_STRSTREAM_H:INTERNAL= //Have include strstrea.h VTK_HAVE_OLD_STRSTREA_H:INTERNAL= //Have symbol SO_REUSEADDR VTK_HAVE_SO_REUSEADDR:INTERNAL=1 //ADVANCED property for variable: VTK_IGNORE_BTX VTK_IGNORE_BTX-ADVANCED:INTERNAL=1 //Whether istream supports long long VTK_ISTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //ADVANCED property for variable: VTK_LARGE_DATA_ROOT VTK_LARGE_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_REMOVE VTK_LEGACY_REMOVE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_SILENT VTK_LEGACY_SILENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MATERIALS_DIRS VTK_MATERIALS_DIRS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MAX_THREADS VTK_MAX_THREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPIRUN_EXE VTK_MPIRUN_EXE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_MAX_NUMPROCS VTK_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_NUMPROC_FLAG VTK_MPI_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_POSTFLAGS VTK_MPI_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PREFLAGS VTK_MPI_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PRENUMPROC_FLAGS VTK_MPI_PRENUMPROC_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_NO_PYTHON_THREADS VTK_NO_PYTHON_THREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-ADVANCED:INTERNAL=1 //Whether ostream supports long long VTK_OSTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //ADVANCED property for variable: VTK_QT_USE_WEBKIT VTK_QT_USE_WEBKIT-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(long long) VTK_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: __int64 unknown VTK_SIZEOF___INT64:INTERNAL= VTK_TCL_TK_STATIC:INTERNAL=ON //ADVANCED property for variable: VTK_TESTING_LOCALE VTK_TESTING_LOCALE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_TESTING_USE_FPE VTK_TESTING_USE_FPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_TESTING_USE_LOCALE VTK_TESTING_USE_LOCALE-ADVANCED:INTERNAL=1 //Whether char is signed. VTK_TYPE_CHAR_IS_SIGNED:INTERNAL=1 //Result of TRY_COMPILE VTK_TYPE_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(uintptr_t) VTK_UINTPTR_T:INTERNAL=8 //ADVANCED property for variable: VTK_USE_64BIT_IDS VTK_USE_64BIT_IDS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_BOOST VTK_USE_BOOST-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_CG_SHADERS VTK_USE_CG_SHADERS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_CHARTS VTK_USE_CHARTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_DISPLAY VTK_USE_DISPLAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_FFMPEG_ENCODER VTK_USE_FFMPEG_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GCC_VISIBILITY VTK_USE_GCC_VISIBILITY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GEOVIS VTK_USE_GEOVIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GL2PS VTK_USE_GL2PS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GLSL_SHADERS VTK_USE_GLSL_SHADERS-ADVANCED:INTERNAL=1 //Have function glXGetProcAddressARB VTK_USE_GLX_GET_PROC_ADDRESS_ARB:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GNU_R VTK_USE_GNU_R-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GUISUPPORT VTK_USE_GUISUPPORT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_INFOVIS VTK_USE_INFOVIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MANGLED_MESA VTK_USE_MANGLED_MESA-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MATLAB_MEX VTK_USE_MATLAB_MEX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MATROX_IMAGING VTK_USE_MATROX_IMAGING-ADVANCED:INTERNAL=1 //Use Matrox Imaging Library for video input. VTK_USE_MATROX_IMAGING:INTERNAL=OFF //ADVANCED property for variable: VTK_USE_METAIO VTK_USE_METAIO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MPEG2_ENCODER VTK_USE_MPEG2_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_MPI VTK_USE_MPI-ADVANCED:INTERNAL=0 //Build VTK with MPI support VTK_USE_MPI:INTERNAL=ON //ADVANCED property for variable: VTK_USE_MYSQL VTK_USE_MYSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_NVCONTROL VTK_USE_NVCONTROL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_N_WAY_ARRAYS VTK_USE_N_WAY_ARRAYS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_ODBC VTK_USE_ODBC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_OGGTHEORA_ENCODER VTK_USE_OGGTHEORA_ENCODER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_POSTGRES VTK_USE_POSTGRES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_QT VTK_USE_QT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_QTCHARTS VTK_USE_QTCHARTS-ADVANCED:INTERNAL=1 //Build QVTK widget and plugin for Qt VTK_USE_QVTK:INTERNAL=ON //ADVANCED property for variable: VTK_USE_QVTK_QTOPENGL VTK_USE_QVTK_QTOPENGL-ADVANCED:INTERNAL=1 //Build the vtkRendering kit. Needed for displaying data or using // widgets. VTK_USE_RENDERING:INTERNAL=ON //ADVANCED property for variable: VTK_USE_SYSTEM_EXPAT VTK_USE_SYSTEM_EXPAT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_FREETYPE VTK_USE_SYSTEM_FREETYPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_HDF5 VTK_USE_SYSTEM_HDF5-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_JPEG VTK_USE_SYSTEM_JPEG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_LIBPROJ4 VTK_USE_SYSTEM_LIBPROJ4-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_LIBXML2 VTK_USE_SYSTEM_LIBXML2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_PNG VTK_USE_SYSTEM_PNG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_TIFF VTK_USE_SYSTEM_TIFF-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_ZLIB VTK_USE_SYSTEM_ZLIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TDX VTK_USE_TDX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TEXT_ANALYSIS VTK_USE_TEXT_ANALYSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TK VTK_USE_TK-ADVANCED:INTERNAL=1 //Build VTK with Tk support VTK_USE_TK:INTERNAL=OFF //ADVANCED property for variable: VTK_USE_VIEWS VTK_USE_VIEWS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_VOLUMEPRO_1000 VTK_USE_VOLUMEPRO_1000-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WGLEXT_FILE VTK_WGLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_HINTS VTK_WRAP_HINTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_JAVA VTK_WRAP_JAVA-ADVANCED:INTERNAL=1 //Wrap VTK classes into the Python language. VTK_WRAP_PYTHON:INTERNAL=OFF //Wrap VTK classes into the TCL language. VTK_WRAP_TCL:INTERNAL=OFF //Result of TEST_BIG_ENDIAN WORDS_BIGENDIAN:INTERNAL=0 //ADVANCED property for variable: X11_ICE_INCLUDE_PATH X11_ICE_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_ICE_LIB X11_ICE_LIB-ADVANCED:INTERNAL=1 //Have library /usr/lib64/libX11.so;/usr/lib64/libXext.so X11_LIB_X11_SOLO:INTERNAL=1 //ADVANCED property for variable: X11_SM_LIB X11_SM_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_INCLUDE_PATH X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_LIB X11_X11_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XShm_INCLUDE_PATH X11_XShm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_INCLUDE_PATH X11_XTest_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_LIB X11_XTest_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessrules_INCLUDE_PATH X11_Xaccessrules_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessstr_INCLUDE_PATH X11_Xaccessstr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_INCLUDE_PATH X11_Xau_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_LIB X11_Xau_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_INCLUDE_PATH X11_Xcomposite_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_LIB X11_Xcomposite_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_INCLUDE_PATH X11_Xcursor_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_LIB X11_Xcursor_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_INCLUDE_PATH X11_Xdamage_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_LIB X11_Xdamage_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_INCLUDE_PATH X11_Xdmcp_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_LIB X11_Xdmcp_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xext_LIB X11_Xext_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_INCLUDE_PATH X11_Xfixes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_LIB X11_Xfixes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_INCLUDE_PATH X11_Xft_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_LIB X11_Xft_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_INCLUDE_PATH X11_Xi_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_LIB X11_Xi_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_INCLUDE_PATH X11_Xinerama_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_LIB X11_Xinerama_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_INCLUDE_PATH X11_Xinput_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_LIB X11_Xinput_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkb_INCLUDE_PATH X11_Xkb_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkblib_INCLUDE_PATH X11_Xkblib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xlib_INCLUDE_PATH X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_INCLUDE_PATH X11_Xpm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_LIB X11_Xpm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_INCLUDE_PATH X11_Xrandr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_LIB X11_Xrandr_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_INCLUDE_PATH X11_Xrender_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_LIB X11_Xrender_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_INCLUDE_PATH X11_Xscreensaver_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_LIB X11_Xscreensaver_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xshape_INCLUDE_PATH X11_Xshape_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_INCLUDE_PATH X11_Xt_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_LIB X11_Xt_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xutil_INCLUDE_PATH X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_INCLUDE_PATH X11_Xv_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_LIB X11_Xv_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86misc_LIB X11_Xxf86misc_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_dpms_INCLUDE_PATH X11_dpms_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86misc_INCLUDE_PATH X11_xf86misc_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86vmode_INCLUDE_PATH X11_xf86vmode_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_BUILD_UTILS XDMF_BUILD_UTILS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAS_NDGM XDMF_HAS_NDGM-ADVANCED:INTERNAL=1 //Whether streams support 64-bit types XDMF_HAVE_64BIT_STREAMS:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Have include malloc.h XDMF_HAVE_MALLOC_H:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_MMAN XDMF_HAVE_MMAN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_NETINET XDMF_HAVE_NETINET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_REGENERATE_WRAPPERS XDMF_REGENERATE_WRAPPERS-ADVANCED:INTERNAL=1 //Regenerate XdmfPython.cxx XDMF_REGENERATE_WRAPPERS:INTERNAL=OFF //ADVANCED property for variable: XDMF_REGENERATE_YACCLEX XDMF_REGENERATE_YACCLEX-ADVANCED:INTERNAL=1 //Regenerate XdmfExprYacc.cxx and XdmfExprLex.cxx XDMF_REGENERATE_YACCLEX:INTERNAL=OFF //ADVANCED property for variable: XDMF_USE_BZIP2 XDMF_USE_BZIP2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_USE_GZIP XDMF_USE_GZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_USE_MYSQL XDMF_USE_MYSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_WRAP_CSHARP XDMF_WRAP_CSHARP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_WRAP_PYTHON XDMF_WRAP_PYTHON-ADVANCED:INTERNAL=1 //Build a Python wrapping interface XDMF_WRAP_PYTHON:INTERNAL=OFF XDMF_WRAP_TCL:INTERNAL=OFF //ADVANCED property for variable: ZLIB_INCLUDE_DIR ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ZLIB_LIBRARY ZLIB_LIBRARY-ADVANCED:INTERNAL=1 //Have function _isinf float.h:INTERNAL= | ||||||||
Relationships | ||||||
(0027652) Robert Maynard (developer) 2011-11-02 13:46 |
This has been fixed as far as I am aware. |
(0027785) Utkarsh Ayachit (administrator) 2011-12-09 14:20 |
merged in master (wherever applicable) |
(0028217) Utkarsh Ayachit (administrator) 2012-02-08 17:27 |
Closing bugs sitting in "customer review" for a long time. |
2011-04-13 17:17 | Rich | New Issue | |
2011-04-13 17:17 | Rich | File Added: CMakeCache.txt | |
2011-04-14 07:49 | Robert Maynard | Assigned To | => Robert Maynard |
2011-04-14 07:49 | Robert Maynard | Status | backlog => tabled |
2011-06-16 13:10 | Zack Galbreath | Category | CMake => (No Category) |
2011-07-07 14:24 | Robert Maynard | Relationship added | duplicate of 0012292 |
2011-11-02 13:46 | Robert Maynard | Note Added: 0027652 | |
2011-11-02 13:46 | Robert Maynard | Status | backlog => gatekeeper review |
2011-11-02 13:46 | Robert Maynard | Fixed in Version | => 3.12 |
2011-11-02 13:46 | Robert Maynard | Resolution | open => no change required |
2011-12-09 14:20 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-12-09 14:20 | Utkarsh Ayachit | Note Added: 0027785 | |
2011-12-09 14:21 | Utkarsh Ayachit | Fixed in Version | 3.12 => git-master |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
2012-02-08 17:27 | Utkarsh Ayachit | Status | customer review => closed |
2012-02-08 17:27 | Utkarsh Ayachit | Note Added: 0028217 |
