0012082 | ParaView | Bug | public | 2011-04-14 03:57 | 2016-08-12 09:58 | ||||
Reporter | Paul Thompson | ||||||||
Platform | Linux | OS | OS Version | ||||||
Product Version | 3.10 | ||||||||
Summary | 0012082: Paraview loss of precision for ascii load of polydata | ||||||||
Description | When loading a polydata file with ascii values, for large coordinate values it appears the points are loaded with a loss of precision. I'm using files with coordinates such as: [x,y,z] = [779091.061000 6167357.363000 616.540987]; Sure, I can offset all the coordinates back towards zero in my program, which of course makes sense numerically. | ||||||||
Steps To Reproduce | See attached files in problemReport.tar.gz input.vtk exhibits the error. input_offset.vtk works fine (values are offset closer to zero). I've tried with the XML .vtp file format (but still using ascii numbers) and the problem is the same. | ||||||||
Attached Files | problemReport.tar.gz [^] (571,955 bytes) 2011-04-14 03:57 | ||||||||
(0037955) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-04-14 03:57 | Paul Thompson | New Issue | |
2011-04-14 03:57 | Paul Thompson | File Added: problemReport.tar.gz | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037955 | |
