0012085ParaViewBugpublic2011-04-14 09:452011-05-02 21:45
ReporterSebastien Jourdain
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version4.0Fixed in Version3.12
Summary0012085: Auto load plugin does not work properly
DescriptionWhen used in an install context auto-load plugin do not work properly
This start happening after the merge of Collaboration branch
Steps To ReproduceThe issue of missing objects in customized panels of plugins has raised its head
again, but fortunately this time I think I do have a better recipe to reproduce.
At least it worked for me again and again and again; I hope you can reproduce, too.
Consider the ConePanel plugin I send you (and to the mailing list) (30/Mar/2011
01:17am):
* compile it against a post-Collaboration-merge build of ParaView
* move plugin library (libGUIConePanel.so) to the
 - either the "bin" directory of your ParaView build directory
 - or the lib directory created by 'cpack':
_CPack_Packages/Linux-x86_64/TGZ/ParaView-3.11.1-Linux-x86_64/lib/paraview-3.11
* add the following line to the file ".plugins" in the very same directory:
    <Plugin name="GUIConePanel" auto_load="1"/>
* and finally start ParaView from that build directory - disabling the registry (!):
    paraview -dr
Under Tools - Manage Plugins you'll notice that the GUIConePanel plugin did get
loaded, no surprise there.
* Create a cone source. VoilĂ : the text the plugin should add to the Cone panel
is *not* there.
Now, disable autoloading the plugin again by editing ".plugins". Start ParaView
anew - again disabling the registry
    paraview -dr
* Manually load the GUIConePanel from Tools - Manage Plugins.
* Create a cone source. VoilĂ : this time the text got added.
Once again, I hope you can reproduce this time.
TagsNo tags attached.
Project
Topic Name
Type
Attached Fileszip file icon conepanel.zip [^] (1,340 bytes) 2011-04-14 09:45
 Relationships
  Notes
(0026179)
2011-04-14 14:00
commit ce0b50bc71f1bfc5942964f28574680f96586844
Date: Thu Apr 14 13:58:33 2011 -0400
    Fixed BUG 0012085. Ensure autoloaded plugins are processed by Qt code.
(0026417)
Alan Scott (manager)
2011-05-02 21:45
Taking Utkarsh's word on it.
 Issue History
2011-04-14 09:45 Sebastien Jourdain New Issue
2011-04-14 09:45 Sebastien Jourdain Status backlog => tabled
2011-04-14 09:45 Sebastien Jourdain Assigned To => Utkarsh Ayachit
2011-04-14 09:45 Sebastien Jourdain File Added: conepanel.zip
2011-04-14 14:00 Utkarsh Ayachit Note Added: 0026179
2011-04-14 14:00 Utkarsh Ayachit Status tabled => @80@
2011-04-14 14:00 Utkarsh Ayachit Fixed in Version => 3.12
2011-04-14 14:00 Utkarsh Ayachit Resolution open => fixed
2011-05-02 21:45 Alan Scott Note Added: 0026417
2011-05-02 21:45 Alan Scott Status @80@ => closed
