0012112 | ParaView | Feature | public | 2011-04-20 10:54 | 2016-08-12 09:58 | ||||
Reporter | Gil | ||||||||
Summary | 0012112: Possibility to enable/disable rendering ( en then stay in brute mesh mode/style ) | ||||||||
Description | When moving a mesh, the NonInteractiveRenderDelay timer begin to decrease. If we could set the NonInteractiveRenderDelay to -1 and then have infinite time to move the mesh and then use a force-render button that will make the mesh to render. Once disabled, the widget must update when making modification of the mesh ( like points representation, changing color ) but the render must stay in brute state ). I ask for this features because my mesh are big > 10Go and it's hard to work when it try to render the mesh each time. Paraview Mailing list subject : http://comments.gmane.org/gmane.comp.science.paraview.user/11741 [^] | ||||||||
(0037962) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-04-20 10:54 | Gil | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037962 | |
