0012123 | ParaView | Bug | public | 2011-04-26 13:08 | 2016-08-12 09:58 | ||||
Reporter | James Whitby | ||||||||
Platform | PC | OS | MS Windows XP Professional | OS Version | SP3 | ||||
Product Version | 3.10 | ||||||||
Summary | 0012123: bug importing raw data when multicore support enabled | ||||||||
Description | Importing a RAW dataset (binary) fails silently when Multi-Core support is enabled i both 3.10.0 and 3.10.1 (32 bit). i.e. load operation appears to have succeeded (no error messages) but dataset is identically zero. | ||||||||
Steps To Reproduce | Enable or disable Multi-Core support under Edit/Settings, exit, relaunch, try and load dataset... | ||||||||
Attached Files | Shortened_ nickel_3D.mtx [^] (655,360 bytes) 2011-04-29 11:59 xy_slice_nickel_PV3.10.1_test.png [^] (17,616 bytes) 2011-04-29 12:00 PView_test_slice_mcore.png [^] (6,753 bytes) 2011-05-09 05:19 | ||||||||
(0026265) Utkarsh Ayachit (administrator) 2011-04-27 14:54 |
What do you mean by "identically zero"? I could not reproduce this. I see an nice outline when I open the image data with multi-core support enabled. Are you trying to volume render and then you don't see anything but the wireframe and that's the issue here? If so, yes, that's a limitation. Currently volume rendering is not supported in multi-core mode. |
(0026274) James Whitby (reporter) 2011-04-28 09:51 |
Thank you for your attempt to reproduce the bug, and for your comments. By 'identically zero' I mean that the range of values shown in the Data Array section of the Information tab of the Object Inspector shows [0,0] instead of the expected [0.0046875, 0.276562]. Similarly the histogram view etc all indicate that the imported data array elements are all zero, instead of the expected values. Not unsurprisingly, none of the rendering options then give me an image of may data. In the import filter list there are filters both for 'RAW' and for 'Raw (binary)' files, I am referring to the latter. (To import a 128x128x179 matrix of little endian floats, which works fine when multi-core support is not enabled). I hadn't realised that volume rendering is not supported by the multi-core mode (even having reread the documentation and Wiki this is not clear, but thank you for letting me know), and I had indeed been trying to use this amongst other viewing options. That volume rendering is not supported does not seem however to explain the symptoms that I am observing. |
(0026275) Utkarsh Ayachit (administrator) 2011-04-28 10:06 |
Thanks for getting back. James, can you give me the sample dataset? feel free to email me directly if you cannot upload it to the public wiki. |
(0026286) James Whitby (reporter) 2011-04-29 12:10 |
I shortened my datafile to make it more portable. A bug remains, but now instead of being zero, the array reports a range of (false) values when loaded with the multi-core option enabled (when the full-size array (18 time bigger) was loaded, Paraview reported only zeroes). See the uploaded file shortened_nickel_3D.mtx for test data that should enable you to reproduce the problem (load using raw (binary) reader as little endian floats, with data extents 0..127, 0..127, 0..9). The uploaded file xy_slice_nickel_PV3.10.1_test.png is an image from Paraview of an xy slice of the dataset correctly loaded without multi-core support enabled. (In case you're interested, this is secondary ion mass spectrometry data, in this case for nickel ions showing of part of a nickel electron microscope finder grid. We are trying to find a good way of handling medium-large 4-D datasets for visualization e.g. by colour coding different masses, and using volume rendering or segmentation followed by rendering or surface shading). |
(0026449) Utkarsh Ayachit (administrator) 2011-05-06 11:39 |
Alas. I still can't reproduce this. In both cases the "ImageFloat" range goes from [0, 0.171875] for me. Is that not correct? Can you also post the incorrect image that you see when using multi-core? Thanks |
(0026460) James Whitby (reporter) 2011-05-09 05:26 |
Strange. The range of data values you report is correct, but I do not obtain those values when mutlicore support is enabled (with the test dataset mentioned above, I see the range [-1.58456e+29,5.8486e+35] which is clearly false, and the resulting slice image is appended Pview_test_slice_mcore.png). To reiterate, this is observed for the 32 bit version of Paraview 3.10.1 (and 3.10.0) on Windows XP. I also did some testing with the 64 bit version of Paraview on a Mac, using the Darwin pre-compiled version from Kitware. Version 3.10.1 worked as expected with and without multicore. Version 3.10.0 however reported the range of values to be [0, 0.015625] with multicore support on, but [0, 0.171875] without multicore support. There is definitely something odd happening when multicore support is enabled, but I have no idea what nor why you can not reproduce the bug that I see on two different operating systems. Could it be some kind of data alignment problem? What architecture/OS are you testing on? Regards, James |
(0026551) Utkarsh Ayachit (administrator) 2011-05-19 09:07 |
I've been testing on 64 bit linux. Let me try on a Mac (Snow Leopard) and see if that changes anything. |
(0037964) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-04-26 13:08 | James Whitby | New Issue | |
2011-04-27 14:54 | Utkarsh Ayachit | Note Added: 0026265 | |
2011-04-27 14:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2011-04-27 14:54 | Utkarsh Ayachit | Status | backlog => @20@ |
2011-04-28 09:51 | James Whitby | Note Added: 0026274 | |
2011-04-28 09:51 | James Whitby | Status | @20@ => tabled |
2011-04-28 10:06 | Utkarsh Ayachit | Note Added: 0026275 | |
2011-04-29 11:59 | James Whitby | File Added: Shortened_ nickel_3D.mtx | |
2011-04-29 12:00 | James Whitby | File Added: xy_slice_nickel_PV3.10.1_test.png | |
2011-04-29 12:10 | James Whitby | Note Added: 0026286 | |
2011-05-06 11:39 | Utkarsh Ayachit | Note Added: 0026449 | |
2011-05-06 11:39 | Utkarsh Ayachit | Status | tabled => @20@ |
2011-05-09 05:19 | James Whitby | File Added: PView_test_slice_mcore.png | |
2011-05-09 05:26 | James Whitby | Note Added: 0026460 | |
2011-05-09 05:26 | James Whitby | Status | @20@ => tabled |
2011-05-19 09:07 | Utkarsh Ayachit | Note Added: 0026551 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037964 | |
