0012162 | ParaView | Bug | public | 2011-05-06 10:19 | 2011-07-29 16:16 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Summary | 0012162: benchmark.py not working anymore | ||||||||
Description | benchmark.py not working anymore | ||||||||
Project | Collaboration | ||||||||
Topic Name | fix-benchmark-script | ||||||||
(0026957) Sebastien Jourdain (manager) 2011-07-05 10:56 |
Update the used API with the current one |
(0026958) Sebastien Jourdain (manager) 2011-07-05 11:02 |
Push the changes to the stage/next and test to call each benchmark.py method inside ParaView python shell or simply run it inside pvpython. All that went well except inside the ParaView python shell, we get an error when we call benchmark.run(). The application fails to create the Sphere()... I don;t know if that should be fixed or if its expected. |
(0026961) Sebastien Jourdain (manager) 2011-07-05 11:15 |
As the run method is not fully working in the ParaView shell, I have to check that with Dave DeMarle. |
(0027006) Sebastien Jourdain (manager) 2011-07-15 14:43 |
As we are not supposed to use the run command in the ParaView python shell, everything else is working. |
(0027007) David Partyka (developer) 2011-07-15 14:44 |
merged to master. |
(0027027) David Partyka (developer) 2011-07-19 16:33 |
merged into master on 7/15/2011 |
2011-05-06 10:19 | Utkarsh Ayachit | New Issue | |
2011-07-04 15:29 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
2011-07-04 15:29 | Utkarsh Ayachit | Project | => Collaboration |
2011-07-04 15:29 | Utkarsh Ayachit | Type | => incorrect functionality |
2011-07-04 15:29 | Utkarsh Ayachit | Status | backlog => todo |
2011-07-05 10:56 | Sebastien Jourdain | Note Added: 0026957 | |
2011-07-05 10:56 | Sebastien Jourdain | Status | todo => active development |
2011-07-05 11:02 | Sebastien Jourdain | Topic Name | => fix-benchmark-script |
2011-07-05 11:02 | Sebastien Jourdain | Note Added: 0026958 | |
2011-07-05 11:02 | Sebastien Jourdain | Status | active development => gatekeeper review |
2011-07-05 11:02 | Sebastien Jourdain | Resolution | open => fixed |
2011-07-05 11:02 | Sebastien Jourdain | Assigned To | Sebastiennn Jourdain => Utkarsh Ayachit |
2011-07-05 11:13 | Sebastien Jourdain | Assigned To | Utkarsh Ayachit => Sebastiennn Jourdain |
2011-07-05 11:15 | Sebastien Jourdain | Note Added: 0026961 | |
2011-07-05 11:15 | Sebastien Jourdain | Status | gatekeeper review => backlog |
2011-07-05 11:15 | Sebastien Jourdain | Resolution | fixed => reopened |
2011-07-15 14:42 | Sebastien Jourdain | Status | backlog => todo |
2011-07-15 14:42 | Sebastien Jourdain | Status | todo => active development |
2011-07-15 14:43 | Sebastien Jourdain | Note Added: 0027006 | |
2011-07-15 14:43 | Sebastien Jourdain | Status | active development => gatekeeper review |
2011-07-15 14:43 | Sebastien Jourdain | Resolution | reopened => fixed |
2011-07-15 14:44 | David Partyka | Note Added: 0027007 | |
2011-07-19 16:33 | David Partyka | Note Added: 0027027 | |
2011-07-19 16:33 | David Partyka | Status | gatekeeper review => customer review |
2011-07-29 16:16 | Utkarsh Ayachit | Status | customer review => closed |
