0012199 | ParaView | Bug | public | 2011-05-17 14:05 | 2016-08-12 09:58 | ||||
Reporter | Dave DeMarle | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0012199: server mode with plugins, crash on shutdown | ||||||||
Description | This test ( http://www.cdash.org/CDash/testSummary.php?project=9&name=pypvcs.StreamingServerSideTest&date=2011-05-17 [^] ) fails on metaland and the hooperlab machines because of a crash on shutdown. Researching the problem on metaland, it appears that most plugins do too. | ||||||||
Steps To Reproduce | connect to single process server (client vs server side rendering doesn't matter) load a plugin (most will do it) quit paraview results in: Inconsistency detected by ld.so: dl-close.c: 737: _dl_close: Assertion `map->l_init_called' failed! | ||||||||
(0037978) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-05-17 14:05 | Dave DeMarle | New Issue | |
2011-05-17 14:05 | Dave DeMarle | Status | backlog => tabled |
2011-05-17 14:05 | Dave DeMarle | Assigned To | => Dave DeMarle |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037978 | |
