0012279 | ParaView | Bug | public | 2011-06-15 10:47 | 2016-08-12 09:58 | ||||
Reporter | Stephane P | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012279: histogram view not initially refreshed when loading state file or playing animation | ||||||||
Description | On the given use cases (see below), the histogram view is empty when it should display some result. | ||||||||
Steps To Reproduce | Load the given tank.pvsm file. The histogram view is empty. It should display the "bin_values" array. It can be forced to display it by unselecting the array on the display tab and reselecting it. After having displayed the histogram, add an animation on the "Clip" filter (on Origin(2) from -24 to 274). When playing the animation, the histogram goes blank. It can also be forced to display the good result using the same trick as above. Additionaly, when playing the animation, an error is displayed when the cutting plane goes out of range (because the histogram cannot find any array to work on). Could this error be silent? | ||||||||
Project | ParaViS | ||||||||
Attached Files | tank.tar.gz [^] (964,701 bytes) 2011-06-15 10:47 | ||||||||
(0032869) Tristan Coulange (developer) 2014-06-17 07:10 |
It was tested with the attached file on the version 4.1 and there are problems, but after saving and reloading the PVSM there is no problem any more. So the bug must be fixed since the version 3.10.1. However, a problem with the animation remains: when resetting the animation, the series are selected in the histogram but they are not in the interface. What do you expect from us on this issue? Tristan |
(0037983) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-06-15 10:47 | Stephane P | New Issue | |
2011-06-15 10:47 | Stephane P | File Added: tank.tar.gz | |
2011-06-23 11:43 | Utkarsh Ayachit | Project | => ParaViS |
2014-06-17 07:10 | Tristan Coulange | Note Added: 0032869 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037983 | |
