0012294 | ParaView | Bug | public | 2011-06-20 17:12 | 2016-08-12 09:58 | ||||
Reporter | Arno Mayrhofer | ||||||||
Platform | x86_64 | OS | Fedora | OS Version | 15 | ||||
Product Version | 3.10.1 | ||||||||
Summary | 0012294: Scatter plot not showing Result of Calculator | ||||||||
Description | When reproducing the steps as outlined below the field "Result" is not shown in the listing of possible x-axis data. If you would exchange steps 3 and 2 and apply the Scatter Plot filter not to the object but to the Calculator then you would get Result listed (Step 4 is obviously not necessary then). Best, Arno Steps To Reproduce: 1. Create any object (e.g. Box) 2. Apply Scatter Plot filter to object 3. Apply Calculator to object, do any calculation 4. Change input of Scatter Plot to Calculator 5. Go to Display tab of Scatter Plot 6. Choose "Use Data Array" 7. View listing for possible x-axis data | ||||||||
Project | TBD | ||||||||
(0037985) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-06-20 17:12 | Zack Galbreath | New Issue | |
2011-06-20 17:12 | Zack Galbreath | Reporter | Zack Galbreath => Arno Mayrhofer |
2011-06-20 17:12 | Zack Galbreath | OS | => Fedora |
2011-06-20 17:12 | Zack Galbreath | OS Version | => 15 |
2011-06-20 17:12 | Zack Galbreath | Platform | => x86_64 |
2011-06-23 10:15 | Utkarsh Ayachit | Project | to be decided => TBD |
2011-07-11 12:56 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2011-07-12 11:43 | Kyle Lutz | Status | backlog => todo |
2011-07-21 14:32 | Kyle Lutz | Status | todo => active development |
2011-07-22 09:51 | Kyle Lutz | Status | active development => todo |
2011-07-22 16:01 | Kyle Lutz | Status | todo => active development |
2011-07-26 14:25 | Kyle Lutz | Status | active development => todo |
2014-02-27 15:09 | Utkarsh Ayachit | Assigned To | Kyle Lutz => |
2014-02-27 15:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-02-27 15:09 | Utkarsh Ayachit | Status | todo => backlog |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037985 | |
