0012346 | ParaView | (No Category) | public | 2011-07-08 15:19 | 2016-08-12 09:58 | ||||
Summary | 0012346: Coloring bug in quad planar view | ||||||||
Description | subject: Bug in gradient filter "I have found a bug similar to what was going on in the new quad planar view. If you try to open this attached image and apply the gradient filter to it (set the dimensionality of the gradient filter to 2). You will get a gray square, but if you then open a new 2d or 3d view, you will see the correct gradient image. I have a number of filter that work similar to this filter and they are all affected by this bug." | ||||||||
Project | CAWorks | ||||||||
Attached Files | sample.vti [^] (103,994 bytes) 2011-07-08 15:19 | ||||||||
(0037999) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-07-08 15:19 | Utkarsh Ayachit | New Issue | |
2011-07-08 15:19 | Utkarsh Ayachit | File Added: sample.vti | |
2011-07-08 15:19 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2016-08-12 09:58 | Kitware Robot | Note Added: 0037999 | |
