0012350 | ParaView | (No Category) | public | 2011-07-11 05:59 | 2016-08-12 09:58 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012350: Regression since 3.10.0: Line Series list empty after switching Attribute Mode | ||||||||
Description | Sources - Time Source - Y Amplitude: 1 - Apply Edit - Find Data - Find Cell from TimeSource1 - Global ID is 0 - Run Selection Query Extract Selection - Apply Filters - Plot Selection Over Time Object Inspector - Display tab - Attribute Mode: Row Data => Object Inspector - Display tab - Line Series GUI element contains a couple of variables: "Cell Value", "Cell X", "Cell Y", ... Object Inspector - Display tab - Attribute Mode: Change to Point Data => Line Series GUI element not cleared (another symptom, probably same bug) Object Inspector - Display tab - Attribute Mode: Change to Cell Data => Line Series GUI element now empty Object Inspector - Display tab - Attribute Mode: Change back to Row Data => Line Series GUI element still empty It only gets repopulated when changing to another active source and then back again to the PlotSelectionOverTime source in the pipeline browser. Tested with ParaView 3.10.0, 3.10.1 and git master branch as of now. Does not occur with ParaView 3.8.1. | ||||||||
Project | TBD | ||||||||
(0038000) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-07-11 05:59 | Sven Buijssen | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038000 | |
