0012361 | ParaView | (No Category) | public | 2011-07-12 13:32 | 2016-08-12 09:58 | ||||
Reporter | Hal Canary | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012361: client-server ParaView rendering errors. | ||||||||
Description | I'm getting some weird behavior from ParaView when I run it in client-server mode. Let me describe the setup I'm using. I'm running ParaView-3.10.1/lib/paraview-3.10/mpirun -np 4 \ ParaView-3.10.1/bin/pvserver \ --server-port=50870 -display ":0" on a RHEL 6.1 workstation. This is the binary release of ParaView. On a Windows 7 laptop connected via ethernet, I'm running ParaView 3.10.1 and connecting to the server. Attached a screenshot of the errors that sometimes happen when I move the camera around. | ||||||||
Project | TBD | ||||||||
Attached Files | 2011-07-11-buggypvserverclient.png [^] (171,121 bytes) 2011-07-12 13:32
(0027209) Hal Canary (reporter) 2011-08-02 20:35 |
"--use-offscreen-rendering" seems to have fixed this bug. |
(0036626) Cory Quammen (developer) 2016-07-27 11:01 |
Reporter solved the problem himself. Can close. |
(0038005) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-07-12 13:32 | Hal Canary | New Issue | |
2011-07-12 13:32 | Hal Canary | File Added: 2011-07-11-buggypvserverclient.png | |
2011-08-02 20:35 | Hal Canary | Note Added: 0027209 | |
2016-07-27 11:01 | Cory Quammen | Note Added: 0036626 | |
2016-07-27 11:01 | Cory Quammen | Status | backlog => customer review |
2016-07-27 11:01 | Cory Quammen | Resolution | open => no change required |
2016-07-27 11:01 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038005 | |
2016-08-12 09:58 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:58 | Kitware Robot | Resolution | no change required => moved |
