0012391 | ParaView | (No Category) | public | 2011-07-22 05:15 | 2016-08-12 09:58 | ||||
Reporter | Oldrich | ||||||||
Product Version | 3.8.1 | ||||||||
Summary | 0012391: vti files do not enlarge their domain in the time series (file_1.vti, file_2.vti...) | ||||||||
Description | I produce a time series of vti files (lbm_0.vti, lbm_30.vti ...) which change their domain size in time. For example, lbm_0.vti has <Piece Extent="0 60 0 60 0 61"> and lbm_1020.vti has <Piece Extent="0 86 0 86 0 61">. When I load the series into the Paraview, the domain does not enlarge and stays at its initial size. When I load lbm_1020.vti separately, it has the correct domain size. I enclose the two sample files where you can observe the problem. Comment by Biddiscombe, John A: Oldrich I've seen another report of a similar bug. What must be happening is that when the UPDATE_TIME is changed inside the pipeline, for whatever reason, RequestInformation is not changing the WholeExtent of the output data and so you are not seeing the imagedata change size. You should file a bug report and attach your observations and my comment. If you have a dataset that can be shared which I can have a copy of, please contact me off list and I'll try to look at it. JB | ||||||||
Project | TBD | ||||||||
Attached Files | vtk.zip [^] (829 bytes) 2011-07-22 05:15 | ||||||||
(0038012) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-07-22 05:15 | Oldrich | New Issue | |
2011-07-22 05:15 | Oldrich | File Added: vtk.zip | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038012 | |
