0012429 | ParaView | (No Category) | public | 2011-07-29 13:24 | 2012-02-08 17:21 | ||||
Assigned To | Dave DeMarle | ||||||||
Product Version | 3.12 | ||||||||
Target Version | Fixed in Version | 3.14 | |||||||
Summary | 0012429: Upgrade netcdf | ||||||||
Description | Work work Nathan to upgrade netcdf since that's need for newer version of Exodus. | ||||||||
Project | Sandia | ||||||||
Topic Name | 0012429-netcdf++ | ||||||||
Relationships | ||||||
(0027872) Dave DeMarle (administrator) 2011-12-21 09:14 |
Disregarding merges and submodule bumps, there were no ParaView level commits. These were the commit to VisItBridge (in reverse order): 82b7653 Revert "ENH: Construct AMR metadata" 9e5d079 Find updated and restructured vtknetcdf library These were the commits at the VTK-master level (in reverse order): f930577 Fix obscure bug in 64 bit netcdf4. 9a665d5 Fix SLAC reader on 64 bit platforms with new netcdf. 693c012 Fix SLAC reader on 64 bit platforms with new netcdf. e4d8b2f Fix clang compiler warning. 1ed55f1 Handle case of null filename. e851c6e Fix netcdf on windows. 496db18 Fix netcdf4's compilation dependency on hdf5. 18372c5 Correct logic for hdf5 export e8db4c4 fix install rule to reflect new location of netcdf headers 81bf8b3 don't export the the hl lib unless we build it ce52300 Fix MinGW compile 9ddcd35 Make it compile on VisStudio2008 express. a017852 Backport compiler and warnings fixes from old netcdf. 5ce1531 Update netcdf to support netcdf4 functionality. bd9536e Revert "Update netcdf to support netcdf4 functionality." c62e78b Revert "Backport compiler and warnings fixes from old netcdf." dfe6ecd Revert "Make it compile on VisStudio2008 express." 48c6951 Revert "Fix MinGW compile" aebf12c Revert "don't export the the hl lib unless we build it" 9d719fb Revert "fix install rule to reflect new location of netcdf headers" 7c72526 Revert "Correct logic for hdf5 export" c6af932 Correct logic for hdf5 export af72db1 fix install rule to reflect new location of netcdf headers 3fbab3c don't export the the hl lib unless we build it f5847a4 Fix MinGW compile b5a0f32 Make it compile on VisStudio2008 express. 378d8a0 Backport compiler and warnings fixes from old netcdf. bb8da93 Update netcdf to support netcdf4 functionality. |
(0027968) Alan Scott (manager) 2012-01-24 19:27 |
Tested using exodus datasets. Master, remote server, Linux. |
2011-07-29 13:24 | Utkarsh Ayachit | New Issue | |
2011-07-29 13:24 | Utkarsh Ayachit | Assigned To | => David Partyka |
2011-07-29 13:25 | Utkarsh Ayachit | Relationship added | child of 0012425 |
2011-10-28 17:17 | Dave DeMarle | Assigned To | David Partyka => Dave DeMarle |
2011-10-28 17:31 | Dave DeMarle | Status | backlog => todo |
2011-10-28 17:31 | Dave DeMarle | Status | todo => active development |
2011-12-21 09:14 | Dave DeMarle | Topic Name | => 0012429-netcdf++ |
2011-12-21 09:14 | Dave DeMarle | Note Added: 0027872 | |
2011-12-21 09:14 | Dave DeMarle | Status | active development => gatekeeper review |
2011-12-21 09:14 | Dave DeMarle | Fixed in Version | => git-next |
2011-12-21 09:14 | Dave DeMarle | Resolution | open => fixed |
2011-12-31 17:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2011-12-31 17:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-01-24 19:27 | Alan Scott | Note Added: 0027968 | |
2012-01-24 19:27 | Alan Scott | Status | customer review => closed |
2012-02-08 17:21 | Utkarsh Ayachit | Fixed in Version | git-master => 3.14 |
