0012443 | ParaView | (No Category) | public | 2011-08-01 10:35 | 2016-08-12 09:58 | ||||
Summary | 0012443: Running the "macro" provided by ParaView by default raises errors on the slave | ||||||||
Description | Running the "macro" provided by ParaView by default raises errors on the slave The implicit plane proxy was not properly detected. | ||||||||
Project | Collaboration | ||||||||
(0027218) Sebastien Jourdain (manager) 2011-08-03 14:21 |
The main issue was related to ProxyDomainList that was not properly updated. When executing the same thing through the python console, it is now working. But when we execute the macro, we fall into a MPIMoveData issue that deadlock the slave client. |
(0027223) Utkarsh Ayachit (administrator) 2011-08-03 17:04 |
I tried different combinations of rendering (both remote rendering, slave local render, both local render) but could not reproduce the deadlock. |
(0027305) Utkarsh Ayachit (administrator) 2011-08-08 13:31 |
Need to try this on faster machine. |
(0038023) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-08-01 10:35 | Utkarsh Ayachit | New Issue | |
2011-08-02 09:44 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
2011-08-02 13:04 | Sebastien Jourdain | Status | backlog => todo |
2011-08-02 13:04 | Sebastien Jourdain | Status | todo => active development |
2011-08-03 14:19 | Sebastien Jourdain | Assigned To | Sebastiennn Jourdain => Utkarsh Ayachit |
2011-08-03 14:21 | Sebastien Jourdain | Note Added: 0027218 | |
2011-08-03 14:21 | Sebastien Jourdain | Status | active development => todo |
2011-08-03 17:04 | Utkarsh Ayachit | Note Added: 0027223 | |
2011-08-08 13:31 | Utkarsh Ayachit | Note Added: 0027305 | |
2014-02-27 15:09 | Utkarsh Ayachit | Status | todo => backlog |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038023 | |
