0012487 | ParaView | (No Category) | public | 2011-08-08 13:37 | 2016-08-12 09:58 | ||||
Reporter | iman | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012487: ComputeDerivative filter crashes in x86, 64 bit linux binaries | ||||||||
Description | I have installed paraview with Linux x86, 64 bit binaries. When we use ComptueDerivative filter to calculate vorticity it crashes with the error segmentation fault. The windows binaries do not have the same problem when I apply this filter to the same database. | ||||||||
Project | TBD | ||||||||
Attached Files | Result00_00600.tar.gz [^] (20,480 bytes) 2011-08-10 16:33 Result00_00610.tar.gz [^] (947,240 bytes) 2011-08-10 16:37 | ||||||||
(0027322) Utkarsh Ayachit (administrator) 2011-08-10 09:47 |
Is it possible to share the dataset on which this crash can be reproduced? Thanks. |
(0027329) iman (reporter) 2011-08-10 16:41 edited on: 2011-08-10 16:43 |
I choose the output vector type as vorticity and the output tensor type as nothing (I only need voritcity). Then hit apply and it crashes and gives a segmentation fault on the command line. p.s. I think the Result00_00600.tar.gz did not upload well. The other one should be fine. These are normal vtk files. |
(0038034) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-08-08 13:37 | iman | New Issue | |
2011-08-10 09:47 | Utkarsh Ayachit | Note Added: 0027322 | |
2011-08-10 16:33 | iman | File Added: Result00_00600.tar.gz | |
2011-08-10 16:37 | iman | File Added: Result00_00610.tar.gz | |
2011-08-10 16:41 | iman | Note Added: 0027329 | |
2011-08-10 16:43 | iman | Note Edited: 0027329 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038034 | |
