0012501 | ParaView | (No Category) | public | 2011-08-11 09:06 | 2016-08-12 09:58 | ||||
Reporter | Eelco van Vliet | ||||||||
Product Version | 3.10.1 | ||||||||
Summary | 0012501: PythonCalculator crashes when running on multiple core with mpirun | ||||||||
Description | PythonCalculor causes a crashes when mpirun -np 2 pvbatch --use-offscreen-rendering pythoncalcmpibug.py is issued. without mpirun and with mpirun with only 1 core the scripts works. ------------------- start pythoncalcmpibug.py from paraview.simple import * view=CreateRenderView() view.ViewSize = [400, 400] view.ResetCamera() view.Background=[0.7,0.7,0.7] view.CameraViewUp = [0,1,0] Sphere(PhiResolution = 1024, ThetaResolution = 1024); Elevation(LowPoint=[-0.5, -0.5, -0.5],HighPoint=[0.5, 0.5, 0.5]) PythonCalculator(Expression='Elevation*Elevation') rep = Show() lut = MakeBlueToRedLT(0,1) lut.NumberOfTableValues=100 rep.LookupTable=lut rep.ColorAttributeType='POINT_DATA' rep.ColorArrayName='Elevation' bar=CreateScalarBar(LookupTable=lut,Title='Elevation') bar.TitleColor=[0,0,0] bar.LabelColor=[0,0,0] bar.NumberOfLabels=3 view.Representations.append(bar) view.StillRender() WriteImage("elevationsphere.png",view=view,Writer="vtkPNGWriter") | ||||||||
Project | Kitware | ||||||||
Type | crash | ||||||||
Attached Files | pythoncalcmpibug.py [^] (732 bytes) 2011-08-11 09:06 | ||||||||
(0038036) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-08-11 09:06 | Eelco van Vliet | New Issue | |
2011-08-11 09:06 | Eelco van Vliet | File Added: pythoncalcmpibug.py | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038036 | |
