0012530 | ParaView | (No Category) | public | 2011-08-16 21:53 | 2016-08-12 09:58 | ||||
Product Version | 4.0 | ||||||||
Summary | 0012530: Contour of 2d strips variables | ||||||||
Description | I will use Sources/Mandlebrot, but need to make another variable. Thus, calculator below. ParaView development (as of about a week ago), local server, windows. * Sources/Mandlebrot * Calculator. Iterations*coordsY. Apply. * Contour. Iterations. 50. Apply. >> Now, if you try to color by Result (output from the Calculator), it is not available | ||||||||
Project | Sandia | ||||||||
(0036445) Alan Scott (manager) 2016-07-13 21:08 |
Still an issue in 5.1.1, Linux. |
(0038046) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-08-16 21:53 | Alan Scott | New Issue | |
2016-07-13 21:08 | Alan Scott | Note Added: 0036445 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038046 | |
