0012535ParaView(No Category)public2011-08-17 15:282016-08-12 09:58
ReporterKen Moreland
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0012535: D3 divde cells mode broken
DescriptionThe D3 filter has stopped working when in divide cells mode. To replicate, do the following:
1. Run ParaView client/server or multicore with 8 process. (Less will probably also cause the failure, but I haven't tried.)
2. Open the attached CurvedCylinder.vtu. Apply.
3. Run D3, change to Divide cells boundary mode. Apply. (Note that there is a separate modification bug with D3 where if you change the boundary mode after the first apply, the filter will not re-execute.)
The result is wonky. (See the attached image.) This problem is not in ParaView 3.10, but it is in the latest master branch.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
Attached Files? file icon CurvedCylinder.vtu [^] (122,170 bytes) 2011-08-17 15:28
png file icon CurvedCylinderD3.png [^] (155,564 bytes) 2011-08-17 15:28
 Relationships
  Notes
(0038049)
Kitware Robot (administrator)
2016-08-12 09:58
Resolving issue as `moved`.
 Issue History
2011-08-17 15:28 Ken Moreland New Issue
2011-08-17 15:28 Ken Moreland File Added: CurvedCylinder.vtu
2011-08-17 15:28 Ken Moreland File Added: CurvedCylinderD3.png
2013-01-08 21:28 Alan Scott Project TBD => Sandia
2016-08-12 09:58 Kitware Robot Note Added: 0038049
2016-08-12 09:58 Kitware Robot Status backlog => closed
2016-08-12 09:58 Kitware Robot Resolution open => moved
2016-08-12 09:58 Kitware Robot Assigned To => Kitware Robot
