0012577 | ParaView | (No Category) | public | 2011-09-07 07:44 | 2016-08-12 09:58 | ||||
Reporter | Paul Edwards | ||||||||
Summary | 0012577: Parallel Coordinates bug with column visibility on selection | ||||||||
Description | The view will reset to showing all columns if you limit the number of columns to display using the "Display" tab in the "Object Inspector" and then select a range in the parallel co-ordinates view. | ||||||||
Project | TBD | ||||||||
(0038065) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-09-07 07:44 | Paul Edwards | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038065 | |
