0012622 | ParaView | (No Category) | public | 2011-09-30 06:20 | 2016-08-12 09:58 | ||||
Reporter | Mark S. Bentley | ||||||||
Summary | 0012622: Allow field data to be displayed as text source | ||||||||
Description | Data stored as field data should be accessible to e.g. the text source in order to display. An example usage is a particle simulation containing global field data such as thermal energy. It should be possible to display this data per timestep in the same way as with Annotate Time. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0038075) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-09-30 06:20 | Mark S. Bentley | New Issue | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038075 | |
