0012666 | ParaView | (No Category) | public | 2011-10-20 06:07 | 2016-08-12 09:59 | ||||
Reporter | John Biddiscombe | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0012666: Wrong Extents used by Translator | ||||||||
Description | The Extent Translator values used by int vtkStreamingDemandDrivenPipeline::SetUpdateExtent can be completely wrong. Example : Create a wavelet source. Default params. (extent, -10,10...) Add a Mask Points filter, with vertices enabled. Add a Gaussian resample filter with default params. On a small piece of the output is generated. The Update request for the Gaussian resample uses the extent translator that was bound to the Wavelt. It has extents {-10,10,-10,10,-10,10} which are clamped by {0,50,0,50,0,50} to give {0,10,0,10,0,10) and so only 1/5 of the output is generated. Very nasty to work with mixture of image and polygon datasets. | ||||||||
Project | TBD | ||||||||
(0038089) Kitware Robot (administrator) 2016-08-12 09:59 |
2011-10-20 06:07 | John Biddiscombe | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038089 | |
