Attached Files | fix_QSpinBox_issue.patch [^] (3,973 bytes) 2011-12-01 15:29 [Show Content] [Hide Content]From 9999691af2c69e2aee7068d2cac50391139f415b Mon Sep 17 00:00:00 2001
Date: Tue, 22 Nov 2011 09:12:02 -0500
Subject: [PATCH] Fix all the QSpinBox issues - Close #88
pqSpinBoxEventTranslator.cxx | 71 +++++++++++++++++++++--------------------
pqSpinBoxEventTranslator.h | 6 +++
2 files changed, 42 insertions(+), 35 deletions(-)
diff --git a/pqSpinBoxEventTranslator.cxx b/pqSpinBoxEventTranslator.cxx
index 9529304..ffee69c 100644
--- a/pqSpinBoxEventTranslator.cxx
+++ b/pqSpinBoxEventTranslator.cxx
@@ -41,6 +41,7 @@ SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
pqSpinBoxEventTranslator::pqSpinBoxEventTranslator(QObject* p)
: pqWidgetEventTranslator(p)
+ this->CurrentObject = 0;
bool pqSpinBoxEventTranslator::translateEvent(QObject* Object, QEvent* Event, bool& /*Error*/)
@@ -54,49 +55,49 @@ bool pqSpinBoxEventTranslator::translateEvent(QObject* Object, QEvent* Event, bo
if(!object)
- return false;
- switch(Event->type())
+ return false;
+ if(Event->type() == QEvent::Enter && Object==object)
- case QEvent::MouseButtonPress:
+ if(this->CurrentObject != Object)
- QMouseEvent* me = static_cast<QMouseEvent*>(Event);
- if(me->button() == Qt::LeftButton)
+ if(this->CurrentObject)
- QStyle* style = object->style();
- QStyleOptionSpinBox option;
- option.initFrom(object);
- option.subControls = QStyle::SC_All;
- QStyle::SubControl sub = style->hitTestComplexControl(
- QStyle::CC_SpinBox, &option, me->pos(), object);
- if(sub == QStyle::SC_SpinBoxUp)
- emit recordEvent(object, "spin", "up");
- else if(sub == QStyle::SC_SpinBoxDown)
- emit recordEvent(object, "spin", "down");
+ disconnect(this->CurrentObject, 0, this, 0);
+ this->CurrentObject = Object;
+ this->Value = object->value();
+ connect(object, SIGNAL(valueChanged(int)),this, SLOT(onValueChanged(int)));
+ connect(object, SIGNAL(destroyed(QObject*)), this, SLOT(onDestroyed(QObject*)));
- break;
- case QEvent::KeyRelease:
+ if(Event->type() == QEvent::KeyRelease && Object == object)
+ QKeyEvent* ke = static_cast<QKeyEvent*>(Event);
+ QString keyText = ke->text();
+ if(keyText.length() && keyText.at(0).isLetterOrNumber())
- QKeyEvent* ke = static_cast<QKeyEvent*>(Event);
- QString keyText = ke->text();
- if(keyText.length() && keyText.at(0).isLetterOrNumber())
- emit recordEvent(object, "set_int", QString("%1").arg(object->value()));
- else
- emit recordEvent(object, "key", QString("%1").arg(ke->key()));
+ emit recordEvent(object, "set_int", QString("%1").arg(object->value()));
+ else
+ emit recordEvent(object, "key", QString("%1").arg(ke->key()));
- default:
- break;
return true;
+void pqSpinBoxEventTranslator::onDestroyed(QObject* /*Object*/)
+void pqSpinBoxEventTranslator::onValueChanged(int number)
+ QString sens = (number - this->Value > 0) ? "up" : "down";
+ this->Value = number;
+ emit recordEvent(this->CurrentObject, "spin", sens);
diff --git a/pqSpinBoxEventTranslator.h b/pqSpinBoxEventTranslator.h
index 65d8b00..b284e8e 100644
--- a/pqSpinBoxEventTranslator.h
+++ b/pqSpinBoxEventTranslator.h
@@ -55,6 +55,12 @@ private:
pqSpinBoxEventTranslator(const pqSpinBoxEventTranslator&);
pqSpinBoxEventTranslator& operator=(const pqSpinBoxEventTranslator&);
+ int Value;
+ QObject* CurrentObject;
+private slots:
+ void onDestroyed(QObject*);
+ void onValueChanged(int number);
#endif // !_pqSpinBoxEventTranslator_h
1.7.4.1
