0012789 | ParaView | (No Category) | public | 2011-12-12 13:45 | 2016-08-12 09:59 | ||||
Reporter | Sebastien Jourdain | ||||||||
Summary | 0012789: Plugin changing property after Apply (SurfaceLIC + PointSprite) | ||||||||
Description | Plugin Qt widget are not supposed to change property value after the apply button get clicked. This induce invalid changes that get pushed to the UndoStack. To reproduce that: build static or load plugins before executing those steps: - Create sphere - Apply - Mouse over Undo (The tooltip showing the undo name should show "Apply" and not vtkSMRepresentation...) | ||||||||
Project | TBD | ||||||||
(0038112) Kitware Robot (administrator) 2016-08-12 09:59 |
2011-12-12 13:45 | Sebastien Jourdain | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038112 | |
