0012850 | ParaView | (No Category) | public | 2012-01-08 12:07 | 2016-08-12 09:59 | ||||
Reporter | Stephen J. Bespalko | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0012850: pvblot crashes after database file is selected on OS X Lion | ||||||||
Description | After selecting a file in the "Open Blot File" dialog window, and selecting "OK" the following text appears in the a window titled "Dialog": Traceback (most recent call last): File "<string>", line 1, in <module> TypeError: __init__() takes exactly 3 arguments (2 given) Traceback (most recent call last): File "<string>", line 1, in <module> AttributeError: 'NoneType' object has no attribute 'SetHost' Traceback (most recent call last): File "<string>", line 1, in <module> File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/simple.py", line 1027, in <module> Connect() File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/simple.py", line 56, in Connect session = servermanager.Connect(ds_host, ds_port, rs_host, rs_port) File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 1825, in Connect raise RuntimeError, "Cannot create a session through python. Use the GUI to setup the connection." RuntimeError: Cannot create a session through python. Use the GUI to setup the connection. Traceback (most recent call last): File "<string>", line 1, in <module> File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 1891, in GetRenderView for aProxy in ProxyManager(): File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 1706, in next self.AProxy = _getPyProxy(self.SMIterator.GetProxy()) File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 2227, in _getPyProxy classForProxy = _findClassForProxy(_make_name_valid(xmlName), smproxy.GetXMLGroup()) File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 2298, in _findClassForProxy elif xmlName in rendering.__dict__: NameError: global name 'rendering' is not defined Traceback (most recent call last): File "<string>", line 1, in <module> File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 2003, in load_module exec code in module.__dict__ File "<pvblot>", line 31, in <module> File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 2003, in load_module exec code in module.__dict__ File "<blotish>", line 33, in <module> File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/simple.py", line 1027, in <module> Connect() File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/simple.py", line 56, in Connect session = servermanager.Connect(ds_host, ds_port, rs_host, rs_port) File "/Volumes/dev/paraview-support/ParaView-3.12.0-build/_CPack_Packages/Darwin-i386/DragNDrop/ParaView-3.12.0-Darwin-i386/ParaView 3.12.0.app/Contents/Python/paraview/servermanager.py", line 1825, in Connect raise RuntimeError, "Cannot create a session through python. Use the GUI to setup the connection." RuntimeError: Cannot create a session through python. Use the GUI to setup the connection. Traceback (most recent call last): File "<string>", line 1, in <module> NameError: name 'pvblot' is not defined >>> ======== at lease here, the file does not matter. | ||||||||
Project | Collaboration | ||||||||
Type | crash | ||||||||
(0038122) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-01-08 12:07 | Stephen J. Bespalko | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038122 | |
