0012864 | ParaView | (No Category) | public | 2012-01-19 20:53 | 2016-08-12 09:59 | ||||
Summary | 0012864: Building ParaView with VTK_USE_SYSTEM_HDF5 =ON fails when HDF5 in not installed globally. | ||||||||
Description | The problem appears to be that HDF5_INCLUDE_DIR is not set correctly in ParaViewCommon.cmake. <begin snippet> ######################################################################### # Configure HDF5 IF(VTK_USE_SYSTEM_HDF5) SET(PARAVIEW_HDF5_LIBRARIES ${VTK_HDF5_LIBRARIES}) SET(HDF5_INCLUDE_DIR ${VTK_HDF5_INCLUDE_DIRS}) ELSE() ... ENDIF() <end snippet> It seems to be using a VTK_HDF5_INCLUDE_DIRS variable that's never set, it seems. | ||||||||
Project | Release | ||||||||
(0028001) Utkarsh Ayachit (administrator) 2012-01-29 14:33 |
The problems continue...VTK doesn't seem to locate (or use) hdf5_hl library. |
(0038124) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-01-19 20:53 | Utkarsh Ayachit | New Issue | |
2012-01-29 14:33 | Utkarsh Ayachit | Note Added: 0028001 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038124 | |
