0013006 | ParaView | (No Category) | public | 2012-03-16 10:39 | 2016-08-12 09:59 | ||||
Reporter | Mattijs | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 3.12 | ||||||||
Summary | 0013006: box selection hard to use | ||||||||
Description | In e.g. 'Extract Cells By Region' when you select 'Box' the box can be resized by moving the end points. It would be really nice if this could happen bi-directional so the centre does not change. In the current behaviour it can be quite hard to e.g. select a few triangles on a complex surface since the centre shifts any time you move one of the endpoints. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0036653) Cory Quammen (developer) 2016-08-01 10:10 |
In ParaView 5.1, one can hold down the control key while resizing the box to maintain the box center. This performs a uniform scaling of the box. Tested ParaView 5.1, Mac OS, built-in server Add Sphere Source Filters -> Extract Cells By Region Change "Intersect With" to "Box". Hold down control key, click and hold mouse on box, then move up and down. |
(0038159) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-03-16 10:39 | Mattijs | New Issue | |
2016-08-01 10:10 | Cory Quammen | Note Added: 0036653 | |
2016-08-01 10:10 | Cory Quammen | Status | backlog => customer review |
2016-08-01 10:10 | Cory Quammen | Resolution | open => fixed |
2016-08-01 10:10 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038159 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
