0013046 | ParaView | (No Category) | public | 2012-03-29 12:40 | 2016-08-12 09:59 | ||||
Reporter | David Doria | ||||||||
Summary | 0013046: Selection tools don't work for images | ||||||||
Description | If I open an image, the "Select points through" type of tools are disabled. It seems like you should be able to select a rectangular region of an image the same way you would select any other type of points. The benefit is the ability to select and extract a region and then rescale the colors so that the local variation in the region can be more easily interpreted. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0038174) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-03-29 12:40 | David Doria | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038174 | |
